Apple Color OneScanner Documentation
Apple's Service Source has two chapters for the Apple Color OneScanner, one for each revision of the scanner. Both come from the Service Source 2.5 CD of 1997.
Service Source: Color OneScanner (Revision A)
The Color OneScanner chapter covers the Revision A scanner, the version with a lamp access door on its right side. It is 76 PDF pages; the PDF was made in November 1995.
Contents
Page numbers are PDF pages.
  • Basics: overview and features (pp. 3-4)
  • Specifications: characteristics, electrical, physical, environmental (pp. 6-9)
  • Troubleshooting: general notes, scanner lamp versions (8-bit and colour lamps), LED error messages, miscellaneous symptom charts (pp. 11-19)
  • Take Apart: top cover, glass cover assembly, optical assembly, inverter assembly, carrier motor, transformer, power supply board, logic board (pp. 21-61)
  • Additional Procedures: selecting voltage (international models), power supply fuses FU1-FU3, lamp replacement, voltage conversion (pp. 63-74)
  • Exploded View with service part numbers (p. 76)
Service Source: Color OneScanner/B (Revision B)
The Color OneScanner/B chapter covers the Revision B scanner, which has no lamp access door. It is 63 PDF pages; the PDF was made in January 1996.
Contents
  • Specifications (pp. 3-6)
  • Troubleshooting: general notes, LED error messages, miscellaneous symptom charts (pp. 8-14)
  • Take Apart: top cover, glass cover assembly, scan start board, lid hinge assembly, optical assembly, carrier motor, logic board, power supply board (pp. 16-54)
  • Additional Procedures: power supply fuse FU1, lamp replacement (pp. 56-61)
  • Exploded View with service part numbers (p. 63)
What these chapters do not contain
Both chapters work at module level. They have no schematics, no component values, no voltage test points and no lamp or inverter specification. The Revision B chapter has no voltage selection or conversion procedure. Neither covers the later Apple Color OneScanner 600/27 or Apple Color OneScanner 1200/30, which have their own chapters.
Download: Apple Color OneScanner Service Source (1995).pdf
Download: Apple Color OneScanner B Service Source (1996).pdf
Pages that cite these documents
