Apple Color OneScanner Troubleshooting Guide
Rear panel of the Color OneScanner: two SCSI connectors, power switch and mains inlet (photo: Akbkuku, CC BY 4.0)
Apple serviced the Apple Color OneScanner by swapping modules: lamp, optical assembly, logic board, power supply board, transformer, carrier motor and belt. Its Service Source chapters give a power-on LED error code table and symptom charts for each revision, with cures listed most likely first. If a module swap does not cure the fault, refit the original before trying the next cure.[1][2] Neither chapter has a schematic or component values.
Power-on LED error codes
At power-on the scanner tests itself and reports a failure by flashing its error light.[1][2]
LED error messages and Apple's cures
Flashes Revision A Revision B
One Check whether the lamp light is green (wrong, 8-bit lamp) or white; replace the lamp if green; replace the logic board; replace the power supply; replace the power supply cable Replace the logic board
Two (lamp) Clean the glass cover assembly; check the lamp holder connector; check that the lamp's label faces down into the holder; replace the lamp; replace the optical assembly
Three Check the carrier motor assembly, drive belt, gears and pulleys, limit switch, home position switch, and that the carrier shaft is not bent
None, but images are wrong Replace the optical assembly
Apple's Tech Info Library adds that for the two-flash error a vendor examined a scanner and 20 optical assemblies and found the optical assembly can be at fault even when a new lamp and logic board do not cure it.[3]
Symptom charts
Miscellaneous symptoms (Service Source, both revisions unless marked)
Symptom Cures, most likely first
Power lamp not on; scanner dead Plug in the power cord; close the lamp cover and turn the button clockwise; check the voltage selector (international models, Revision A); check the interlock switch with a meter and replace it if it does not open and close; check the power supply fuses (FU1-FU3 on Revision A, FU1 on Revision B); replace the logic board; replace the power supply; replace the transformer (Revision A)
Optical assembly does not move Check the SCSI connection and SCSI ID; check, clean or replace the belt; check the belt is tight with no slack; check the gears for damage or debris
Optical assembly moves once, then stops Check the limit switch for continuity; check the drive belt and pulleys; check the carrier motor
Scanning program crashes or the computer hangs Check the scanning application and driver versions and that the driver is present; check the SCSI connection, ID and termination; check the computer has enough memory and System 7.0 or later; switch the scanner on and restart the computer; replace the logic board
Lamp will not light or is dim Check the lamp holder connector and that the lamp label faces down; replace the lamp; replace the flexible cable (Revision A); replace the optical assembly; replace the logic board
Scan command does nothing Check the external cables; set the scanner's SCSI select switch to an unused ID (factory setting 2; do not use 7, 8, 9 or 0); check SCSI termination; check the logic board fuse (Revision A); replace the logic board
Dark or light spots Clean the glass with water and a soft lint-free cloth; adjust contrast or threshold in the application; replace the lamp; replace the optical assembly; replace the logic board
Scan runs but the image does not reach the computer Check the interface connector; replace the optical assembly; check fuse FU1 on the logic board; replace the logic board
Wrong image on screen Clean the glass; replace the optical assembly
Source: Service Source symptom charts.[1][2]
Other notes
  • The scan-in-progress light that the manual describes worked only on early units. A dark light during scanning is not a fault.[4]
  • The lamp lock button operates the interlock switches. If the scanner is dead after lamp work, check that the button is tight before suspecting the power supply; Apple's chart for a dead scanner lists it second, after the power cord.[1]
  • Where the lamp casts a green light, it is the grey-scale OneScanner's 8-bit lamp, not the colour lamp. See Apple Color OneScanner General Maintenance.[1]
  1. ↑ 1.0 1.1 1.2 1.3 1.4 Apple Computer, Service Source: Color OneScanner (Revision A scanner), PDF dated November 1995, from the Service Source 2.5 CD of 1997. Hosted as File:Apple Color OneScanner Service Source (1995).pdf. Basics PDF pp. 3-4; Specifications pp. 6-9; Troubleshooting pp. 11-19 (lamp versions, LED error messages, miscellaneous symptom charts); Take Apart pp. 21-61; Additional Procedures pp. 63-74 (voltage selection, power supply fuses, lamp replacement, voltage conversion); Exploded View p. 76.
  2. ↑ 2.0 2.1 2.2 Apple Computer, Service Source: Color OneScanner/B (Revision B scanner), PDF dated January 1996, from the Service Source 2.5 CD of 1997. Hosted as File:Apple Color OneScanner B Service Source (1996).pdf. Specifications PDF pp. 3-6; Troubleshooting pp. 8-14; Take Apart pp. 16-54 (including scan start board and lid hinge); Additional Procedures pp. 56-61 (power supply fuse FU1, lamp replacement); Exploded View p. 63.
  3. ↑ Apple Computer, Tech Info Library article 13785, "Apple Color OneScanner: LED Error Flashes Twice", created 26 October 1993. Copy at absurdengineering.org. The two-flash LED lamp error can be caused by the optical assembly when a new lamp and logic board do not cure it; clean the glass, check the lamp holder and lamp orientation, replace the lamp, then the optical assembly.
  4. ↑ Apple Computer, Tech Info Library article 15052, "Apple OneScanner: Scan-in-progress LED Doesn't Function", created 4 April 1994. Copy at absurdengineering.org. The scan-in-progress LED described in the Color OneScanner and OneScanner manuals operated only on early units; it has no function on later units and does not indicate a fault.
