Apple Ethernet cards
Apple Ethernet cards are the network interface cards Apple sold to put Macintosh computers without built-in Ethernet onto 10 Mbit/s Ethernet. The first was the EtherTalk Interface Card for the Macintosh II, introduced with EtherTalk 1.0 software in August 1987 and later renamed the EtherTalk NB Card.[1] It was followed by the Ethernet NB Card for NuBus, the Ethernet LC Card for the LC processor-direct slot, and cards for the communications slots of the LC 575, 630, 5200 and later families.
| Card | Slot | Order number | Service part | Network connector |
| EtherTalk Interface Card / EtherTalk NB Card | NuBus | M0410LL/A | 661-0414 (Rev. A-K), 661-0496 | BNC and 15-pin AUI |
| Ethernet NB Card | NuBus | M0417LL/A, M0417LL/B | 661-0619 | Apple Ethernet (AAUI) |
| Ethernet NB Twisted-Pair Card | NuBus | M1768Z/A | 661-0869 | RJ-45 (10BASE-T) |
| Ethernet LC Card | LC PDS | M0443LL/A to /C | 661-0621 | Apple Ethernet |
| Ethernet LC Twisted-Pair Card | LC PDS | M2460Z/A | 661-0226 | RJ-45 (10BASE-T) |
| Ethernet CS Twisted Pair Card | Comm slot I | M3065Z/A | 661-0888 | 10BASE-T |
| Ethernet CS Thin Coax Card | Comm slot I | M2708Z/A | 661-0036 | Thin coax (10BASE2) |
| Ethernet CS AAUI Card | Comm slot I | M3066Z/A | 661-0889 | AAUI |
| Ethernet CS II cards | Comm slot II | M4772ZM/A, M4773ZM/A, M4774ZM/A | – | 10BASE-T, 10BASE2 or AAUI |
Order numbers are from Apple's Tech Info Library and service parts from its 1994 module identification manual.[2][3][4][5][6][7][8]
EtherTalk cards
[edit | edit source]Apple bought the EtherTalk card from 3Com and sold it under its own name; 3Com sold the same board as the EtherLink NB.[9] The card has a BNC connector for thin Ethernet with an on-board transceiver, selected by a jumper, and a 15-pin AUI connector for an external transceiver on thick Ethernet. Apple gives the power as 6.5 W maximum from +5 V and 3.6 W from +12 V, with 32K of ROM.[10][11] Its two specification sheets give 16K and 64K of dual-ported packet buffer RAM; the revision history says the larger 64K buffers came with revision L.[11][10][1] Each card carries its own Ethernet address, stored on the card and printed on a label on the back of the board.[12]
Revisions
[edit | edit source]| Revision | Date | Apple assembly | Change |
| A to D | 1987 | – | First production |
| J | March 1988 | 2680-06 | Fixed rare data corruption when the card retransmitted a packet after a collision, and a clash with NuBus cards using addresses in the $xxxFxxx range. Reworked earlier cards were relabelled G to J (A became G, B became H and so on). |
| K | January 1989 | 2680-07 | Fixed timing that assumed a six-slot NuBus machine, which upset three-slot machines such as the IIcx |
| L | December 1989 | 2680-08 | New layout with new ROMs and no cuts and jumpers; larger buffers; NuBus fixes needed by the IIfx |
| M | November 1990 | 2680-08 | Manufacturing process change only |
Dates and changes are from Apple's EtherTalk history; assembly numbers from its revision list.[1][9][13] Apple offered a free upgrade to revision J from May to October 1988, but no upgrade to K or L.[1]
Apple's articles do not agree on which revisions suit which machine. All accept J, K, L or M in the Macintosh II and IIx, and K or later in the IIcx. The 1991 revision list asks for L or M in the IIfx, IIsi and IIci; the EtherTalk history and the System 7 note also accept K in the IIfx, and K in the IIci only without on-board video.[9][1][2] On a IIci a revision K card with EtherTalk 2.0.1 or 2.0.2 runs slowly when on-board video is set to 4 colours or more. Fit a revision L or M card, use a video card, or run on-board video in black and white.[14]
Software
[edit | edit source]EtherTalk 2.0 (June 1989) added AppleTalk Phase 2 and changed the packet format, so 2.0 nodes cannot see 1.x nodes without a router running both. EtherTalk 2.0.1 (October 1989) and 2.0.2 (March 1990) only changed the .ENET driver in the System file, adding delays to suit the faster IIcx, IIci and IIfx; the EtherTalk file in the System Folder kept the same version.[1] Apple gave a limit of 254 active EtherTalk users, bridges included, on one Ethernet. A Macintosh II with an EtherTalk card cannot bridge LocalTalk and Ethernet by itself.[12]
Testing
[edit | edit source]Apple's bench test is MacTest II, which has a one-card test and a two-card test against a known-good card. Set the jumper to thin cable and fit a BNC T-connector with two terminators from kit 077-0256 as a loopback. For the two-card test, link the two cards with thin net test cable 077-0257, with a T-connector and terminator at each end. The two-card test finds faults the one-card test misses, and neither test checks the 15-pin thick Ethernet connector. Reset the jumper before the card goes back into use.[15] The later MacTest MP test for the EtherTalk NB card runs on the II, IIx, IIcx and IIfx but not the IIci or IIsi.[16]
Ethernet NB Card
[edit | edit source]The Ethernet NB Card is a NuBus bus-master card with its own Motorola 68000 at 10 MHz, memory and real-time multitasking operating system, and a National Semiconductor DP83932 SONIC controller.[17][18] It has 512K of RAM as four surface-mounted 256K × 4 SOJ chips, and four ZIP sockets for a further 512K (four 256K × 4 chips) or 2 MB (four 1M × 4 chips), at 120 ns or faster; Apple's own upgrade was M0145LL/A and its suggested part the Toshiba TC514400AZ.[19][18] The card works internally on a 16-bit path, and its processor mostly manages DMA.[20] Apple put the built-in Ethernet of a Quadra at 15 to 20 per cent faster, because it uses DMA to main memory, avoids NuBus transfers and runs at the system bus clock.[21] Remove the RAM chips from the ZIP sockets before returning a card to Apple for exchange.[8]
The network connector is Apple's Ethernet port, the 14-position AAUI. A media adapter plugs into it: the Apple Ethernet Thin Coax Transceiver (M0329LL/A), the Twisted-Pair Transceiver (M0437LL/A) or the AUI Adapter (M0432LL/A) for thick coax and other media.[17][22] Keep AAUI cables under 1.5 m.[23]
Apple's power figures differ between sheets: 3.96 W at 5 V in one note, and 7.5 W maximum with a 4 W average in the 1993 specification. The same note gives 13.9 W as the recommended limit per NuBus slot and 1.165 A as the card's total draw with an external AAUI transceiver.[23][3] The card needs a NuBus slot, or the NuBus adapter in a IIsi or Quadra 610, System 6.0.4 or later or A/UX 2.0, and AppleTalk Phase 2 on the network.[18][3]
[edit | edit source]The NB Twisted-Pair Card has a built-in RJ-45 10BASE-T port, 128K of RAM and a DP83934 SONIC-T controller, and draws 3.75 W at most (2 W average). It needs an IEEE 802.3 10BASE-T hub.[3]
Ethernet LC Card
[edit | edit source]The Ethernet LC Card fits the processor-direct slot of the Macintosh LC family, the Color Classic and the Quadra 605. It uses the DP83932 SONIC, draws under 4 W and has the same Apple Ethernet port and media adapters as the Ethernet NB Card.[24][4][5] Like the NB card it uses a 16-bit data path.[20] In the 630 family it goes in the LC PDS slot, which lets a 630 have an internal modem in the communications slot as well as Ethernet.[25]
The card needs a newer ROM in later machines. The LC II needs a ROM upgrade carrying a new driver.[26] In the LC III and LC 575 an old card gives "could not switch to EtherTalk" when Ethernet is selected; the cure is a card with the new ROM and EtherTalk installed from System 7.1 or later disks.[27] The new card is board assembly 670-2008 and the old one 670-4443 with ROM 341-0842. Apple's Tech Info Library gives the new ROM as 341-0470 and its module identification manual as 341-4070, introduced in March 1992.[27][8] The Macintosh Processor Upgrade cannot be fitted while an LC-style card such as this one is in place.[28]
The LC Twisted-Pair Card has a built-in RJ-45 10BASE-T port and a DP83934 SONIC-T controller, and draws 1.5 W at most (1 W average).[4]
Twisted-pair and thin coax cards
[edit | edit source]Apple's cards reach the three Ethernet media in two ways. Cards with the Apple Ethernet port (Ethernet NB, Ethernet LC, Ethernet CS AAUI) take an external transceiver: thin coax (10BASE2) through the Thin Coax Transceiver, unshielded twisted pair (10BASE-T) through the Twisted-Pair Transceiver, and thick coax or fibre through the AUI Adapter. Other cards have the transceiver built in: the NB and LC Twisted-Pair cards have an RJ-45 port, the CS Twisted Pair card connects to 10BASE-T, and the CS Thin Coax card connects straight to 10BASE2 thin coax.[17][3][4][6] The comm slot II range repeats the choice with a 10BASE-T, a 10BASE2 and an AAUI card.[7]
On thin coax, the Thin Coax Transceiver terminates the cable itself when one of its two BNC connectors is free, and Apple's 5 m and 13 m cables terminate when an end is left unconnected. An older EtherTalk NB card at the end of a segment needs a terminator on its T-connector.[29] Apple's NB hardware has no way to turn off the 10BASE-T link beat signal, so it will not work with early twisted-pair hubs that cannot handle link beat.[30]
Communications slot cards
[edit | edit source]The communications slot first appeared in the Macintosh LC 575, where Apple's developer note calls it a socket for a communications interface that is not a general expansion connector.[31] It is a 112-pin slot with a 32-bit data path, used in the 575, 630, 5200 and 5300 families and the Performa 6200 and 6300 series. Apple made four cards for it: the Ethernet CS Twisted Pair Card, the Ethernet CS Thin Coax Card, the Ethernet CS AAUI Card and the Express Fax/Modem.[6] All of them work in the Performa 575.[32] A machine has only one communications slot, so it takes either the modem or an Ethernet card there.[25] The Apple IIe Card does not work in an LC 575 with anything fitted in the communications slot.[33]
Apple later named this slot comm slot I to tell it apart from the PCI-based slot in the Power Macintosh 5400.[6]
Comm slot II cards
[edit | edit source]Comm slot II, in the Power Macintosh 5400, 5500, 6400 and 6500 and the Performa 6360 and 6400, is a PCI-based 112-pin slot. It is keyed at the opposite end from comm slot I, so a comm slot I card lined up with the notches would face the wrong way, and the two slots are not fully signal compatible. Only serial modem cards built with both cut-outs work in either.[7][34] The Ethernet CS II range has 10BASE-T (M4772ZM/A), 10BASE2 (M4773ZM/A) and AAUI (M4774ZM/A) cards; the 5400/120 and 6400/200 shipped with the 10BASE-T card.[7] The cards and their software work only under Open Transport.[35]
| IIcx fails to boot, crashes or runs the network very slowly, often with no other card fitted | EtherTalk card older than revision K | Fit a revision K or later card[1] |
| IIci network slow with on-board video at 4 colours or more | Revision K EtherTalk card with EtherTalk 2.0.1 or 2.0.2 | Use a revision L or M card, a video card, or 1-bit on-board video[14] |
| Ethernet NB card installed under System 7.0 or 7.0.1 but not working | EtherTalk on those system disks has no Ethernet NB driver | Install EtherTalk 2.5.1 or later[36] |
| "Could not switch to EtherTalk" with an Ethernet LC card in an LC III or LC 575 | Card with the old ROM | Use a card with the new ROM and install EtherTalk from System 7.1 or later[27] |
| Ethernet LC card not working in an LC II | Old ROM and driver | Fit the ROM upgrade[26] |
| No link to an old twisted-pair hub | Card sends link beat, which the hub cannot handle | Use a 10BASE-T hub[30] |
| Thin coax segment unreliable | Missing termination at the end of the segment | Leave a transceiver connector or cable end free, or fit a terminator to the T-connector[29] |
| Power Macintosh 5400 or 6400 cannot select EtherTalk | Classic AppleTalk in use; the CS II card needs Open Transport | Switch to Open Transport, restart and select Ethernet[35] |
| MacIPX error −43 on a comm slot II machine | Missing Ethernet support for MacIPX | Install the 6360/64xx/54xx Update or Mac OS 7.6[37] |
For an EtherTalk card suspected of a hardware fault, run the loopback tests described under Testing.[15]
[edit | edit source]- Apple Ethernet transceivers and cables
- Apple LocalTalk cabling
- Macintosh LC
- Macintosh LC 575
- Macintosh LC 630
- Macintosh IIci
- Macintosh IIcx
- Power Macintosh 5400
[edit | edit source]- ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 Apple Computer, "EtherTalk: History and User's Guide (3/95)", Tech Info Library article 5510 (TA42160), created 21 May 1990, revised 22 March 1995, in the archive.org collection APPLE_TIL_ARTICLES, file TIL00001_to_TIL09432.pdf. Source for: the EtherTalk Interface Card (later EtherTalk NB Card) and EtherTalk 1.0 introduced for the Macintosh II in August 1987; revisions A to D, J (March 1988), K (January 1989), L (December 1989); what each revision fixed; the free revision J upgrade of May to October 1988 and the G to J relabelling of reworked cards; EtherTalk software 1.2, 2.0, 2.0.1 and 2.0.2; the compatibility table by Macintosh model.
- ↑ 2.0 2.1 Apple Computer, "EtherTalk NB Card: System 7 and Compatibility Issues", Tech Info Library article 8296 (TA46748), created 13 June 1991, in the archive.org collection APPLE_TIL_ARTICLES, file TIL00001_to_TIL09432.pdf. Source for: no System 7 issues; order numbers M0410LL/A (EtherTalk NB) and M0417LL/A (Ethernet NB); revisions by model, with K, L or M given for the IIfx and Rev. J not working there.
- ↑ 3.0 3.1 3.2 3.3 3.4 Apple Computer, "Ethernet and Twisted-Pair NB Card: Specifications (10/93)", Tech Info Library article 13725 (TA30407), created 21 October 1993, in the archive.org collection APPLE_TIL_ARTICLES, file TIL09433_to_TIL17062.pdf. Source for: Ethernet NB power 7.5 W or less (average 4 W); NuBus adapters needed in the IIsi and Quadra 610; the NB Twisted-Pair Card's RJ-45 port, 128K RAM, DP83934 SONIC-T and 3.75 W (average 2 W); order numbers M0417LL/B and M1768Z/A.
- ↑ 4.0 4.1 4.2 4.3 Apple Computer, "Apple Ethernet LC and LC Twisted-Pair Card Descriptions (1/94)" and "Specifications (1/94)", Tech Info Library articles 14357 (TA30940) and 14358 (TA30941), created 5 January 1994, in the archive.org collection APPLE_TIL_ARTICLES, file TIL09433_to_TIL17062.pdf. Source for: support for all Macintosh LC models, the Color Classic and the Quadra 605; the LC Twisted-Pair Card's RJ-45 port, DP83934 SONIC-T and 1.5 W maximum (1 W average); order numbers M0443 and M2460Z/A; an LC-compatible processor-direct slot.
- ↑ 5.0 5.1 Apple Computer, "Color Classic: Apple IIe, Macintosh LC, & Ethernet Cards (2/93)", Tech Info Library article 11452, in the archive.org collection APPLE_TIL_ARTICLES, file TIL09433_to_TIL17062.pdf. Source for: the Ethernet LC Card (M0443LL/B) fitting the Color Classic, with a transceiver needed as well.
- ↑ 6.0 6.1 6.2 6.3 Apple Computer, "Communication Slot: Specifications (5/96)", Tech Info Library article 15081 (TA31498), revised 29 May 1996, in the archive.org collection APPLE_TIL_ARTICLES, file TIL09433_to_TIL17062.pdf. Source for: the computers with the slot; 112 pins and a 32-bit data path; the pinout; the four cards (Express Fax/Modem M2480LL/A, Ethernet CS Twisted Pair M3065Z/A, Ethernet CS Thin Coax M2708Z/A, Ethernet CS AAUI M3066Z/A); the names comm slot I and comm slot II.
- ↑ 7.0 7.1 7.2 7.3 Apple Computer, "Power Macintosh 5400 & Performa 6400: Communications Slot (11/96)", Tech Info Library article 19591, in the archive.org collection APPLE_TIL_ARTICLES, file TIL17065_to_TIL60496.pdf. Source for: the PCI-based 112-pin comm slot II; comm slot I cards not fitting because the slot is keyed at the opposite end, and the slots not being fully signal compatible; dual-keyed serial modem cards; the Ethernet CS II cards M4772ZM/A (10BASE-T), M4773ZM/A (10BASE2) and M4774ZM/A (AAUI); the 10BASE-T card fitted to the 5400/120 and 6400/200.
- ↑ 8.0 8.1 8.2 Apple Computer, Module Identification, part number 072-8124, June 1994, hosted as File:Apple Service Module Identification Manual (June 1994).pdf, "Interface Cards": EtherTalk Card (Rev. A-K) 661-0414 p. 4.2.1; EtherTalk NB Card 661-0496 p. 4.2.2; Ethernet NB Card 661-0619 p. 4.2.3 (remove the RAM chips before returning it); Ethernet NB Twisted Pair Card 661-0869 p. 4.2.9; Ethernet LC/LC II card 661-0621 p. 4.3.3 (new version with ROM 341-4070 and board assembly 670-2008, ROM introduced March 1992; older version ROM 341-0842, assembly 670-4443); LC 575 comm slot cards: 10BASE-T 661-0888 p. 4.3.6, AAUI 661-0889 p. 4.3.7, thin-net 661-0036 p. 4.3.8; Ethernet LC Twisted Pair Card 661-0226 p. 4.3.9.
- ↑ 9.0 9.1 9.2 Apple Computer, "EtherTalk NB and EtherLink NB: Revision Numbers", Tech Info Library article 6760 (TA45205), created 6 February 1991, in the archive.org collection APPLE_TIL_ARTICLES, file TIL00001_to_TIL09432.pdf. Source for: Apple buying the card from 3Com; Apple assembly numbers 2680-06 (Rev. J), 2680-07 (Rev. K) and 2680-08 (Rev. L and M) against 3Com EtherLink NB assemblies 4042-02 to 4042-04; the compatibility list (II and IIx: J, K, L or M; IIcx: K, L or M; IIfx, IIsi and IIci: L or M).
- ↑ 10.0 10.1 Apple Computer, "Apple EtherTalk NB Card: Specifications (Discontinued)", Tech Info Library article 6948, created 14 March 1991, in the archive.org collection APPLE_TIL_ARTICLES, file TIL00001_to_TIL09432.pdf. Source for: BNC and 15-pin AUI connectors; on-board thin Ethernet transceiver, jumper-selectable; 64K of dual-ported packet RAM; 32K of ROM; +5 V 6.5 W and +12 V 3.6 W maximum; 0 to 55 °C.
- ↑ 11.0 11.1 Apple Computer, "Macintosh II EtherTalk NB Interface Card: Specs (Discontinued)", Tech Info Library article 6992, created 15 March 1991, in the archive.org collection APPLE_TIL_ARTICLES, file TIL00001_to_TIL09432.pdf. Source for: the same connectors and power figures with 16K of dual-ported packet memory.
- ↑ 12.0 12.1 Apple Computer, "EtherTalk: Ethernet Connectivity for the Macintosh II", Tech Info Library article 916 (TA47502), created 16 October 1987, in the archive.org collection APPLE_TIL_ARTICLES (retrieved 2026-10-04), file TIL00001_to_TIL09432.pdf. Source for: a unique Ethernet address on each card, also printed on a label on the back of the board; up to 10 Mbit/s; configuration for thick or thin Ethernet; a limit of 254 active EtherTalk users on one Ethernet; a Macintosh II with EtherTalk cannot act as a LocalTalk-to-Ethernet bridge, and no bridging software was included.
- ↑ Apple Computer, "EtherTalk NB Card: Revisions L and M Are Functionally Identical", Tech Info Library article 6332 (TA44898), created 15 November 1990, in the archive.org collection APPLE_TIL_ARTICLES, file TIL00001_to_TIL09432.pdf. Source for: revision M shipping from 14 November 1990, changed only for a manufacturing process change.
- ↑ 14.0 14.1 Apple Computer, "EtherTalk NB Revision K card: Problem with Macintosh IIci", Tech Info Library article 5320 (TA41077), created 21 March 1990, in the archive.org collection APPLE_TIL_ARTICLES, file TIL00001_to_TIL09432.pdf. Source for: degraded Ethernet performance with a Rev. K card, EtherTalk 2.0.1 or 2.0.2 and IIci on-board video at 2 bits or more; the workarounds; Rev. L shipping since December 1989.
- ↑ 15.0 15.1 Apple Computer, "EtherTalk Interface Card: General Troubleshooting", Tech Info Library articles 1270 (part 1) and 1261 (part 2), last reviewed 16 November 1987, in the archive.org collection APPLE_TIL_ARTICLES, file TIL00001_to_TIL09432.pdf. Source for: the MacTest II one-card and two-card tests, terminator kit 077-0256 and thin net test cable 077-0257, setting the jumper for thin cable during testing, and neither test checking the DB-15 thick Ethernet connector.
- ↑ Apple Computer, Apple Service Technical Procedures: Macintosh Family, Volume Two (March 1992), "Multiple-Product Diagnostics", MacTest MP p. 1.6 (rev. Nov 1991): MacTest MP's EtherTalk NB Card test works on the Macintosh II, IIx, IIcx and IIfx but not the IIci and IIsi. Archive.org item bitsavers_appleserviviceTechnicalProceduresMacintoshFamilyVo_19357769 (retrieved 2026-10-04).
- ↑ 17.0 17.1 17.2 Apple Computer, "Apple Ethernet NB Card: Description (Discontinued)", Tech Info Library article 10274, created 26 May 1992, in the archive.org collection APPLE_TIL_ARTICLES, file TIL09433_to_TIL17062.pdf. Source for: a bus master NuBus card with its own 68000, memory and real-time multitasking operating system; the Apple Ethernet port and media adapters for thin coax, thick coax and twisted pair; order numbers M0417LL/A, M0432LL/A, M0329LL/A, M0833LL/A, M0436LL/A, M0437LL/A.
- ↑ 18.0 18.1 18.2 Apple Computer, "Apple Ethernet NB Card: Specifications", Tech Info Library article 10792, created 29 September 1992, in the archive.org collection APPLE_TIL_ARTICLES, file TIL09433_to_TIL17062.pdf. Source for: 68000 at 10 MHz; 512K RAM, expandable to 1 MB with M0145LL/A or 2.5 MB with third-party modules; DP83932 SONIC controller; one NuBus slot or the IIsi NuBus Adapter Card; System 6.0.4 or A/UX 2.0; AppleTalk Phase 2.
- ↑ Apple Computer, "Apple Ethernet NB Card: Expansion RAM Specifications (4/95)", Tech Info Library article 11116, in the archive.org collection APPLE_TIL_ARTICLES, file TIL09433_to_TIL17062.pdf. Source for: 512K of surface-mounted DRAM as four 256K × 4 SOJ chips; four ZIP sockets; upgrades of four 256K × 4 or four 1M × 4 ZIP chips at 120 ns or faster; Toshiba TC514400AZ; 16-bit access by the 68000 and SONIC.
- ↑ 20.0 20.1 Apple Computer, "Apple Ethernet NB Card: 16-bit Bus Path and Tasks (10/91)", Tech Info Library article 9151 (TA47496), and "Ethernet NB Card and Quadra Built-in Ethernet: Bus Width", article 11027, in the archive.org collection APPLE_TIL_ARTICLES, files TIL00001_to_TIL09432.pdf and TIL09433_to_TIL17062.pdf. Source for: the 16-bit data path of the Ethernet NB and Ethernet LC cards; few tasks downloaded to the card, its processor mostly managing DMA.
- ↑ Apple Computer, "Built-In and NuBus Ethernet Maximum Transfer Rate (3/96)", Tech Info Library article 12000, in the archive.org collection APPLE_TIL_ARTICLES, file TIL09433_to_TIL17062.pdf. Source for: built-in Ethernet being about 15 to 20 per cent faster than the Ethernet NB card.
- ↑ Apple Computer, "Ethernet: AAUI Connector Pinouts (3/96)", Tech Info Library article 8863 (TA47266), in the archive.org collection APPLE_TIL_ARTICLES, file TIL00001_to_TIL09432.pdf. Source for: the 14-position 0.050-inch AAUI connector on Quadra computers, the Ethernet NB card and the LaserWriter IIg, and its pinout.
- ↑ 23.0 23.1 Apple Computer, "Apple Ethernet NB Card: Power Consumption", Tech Info Library article 7914 (TA46485), in the archive.org collection APPLE_TIL_ARTICLES, file TIL00001_to_TIL09432.pdf. Source for: 3.96 W at 5 V; 13.9 W recommended limit per NuBus slot; 1.165 A overall including an external AAUI transceiver; AAUI cable no longer than 1.5 m.
- ↑ Apple Computer, "Apple Ethernet LC Card: Description (Discontinued)" and "Apple Ethernet LC Card: Specifications", Tech Info Library articles 10272 and 10273, created 26 May 1992, in the archive.org collection APPLE_TIL_ARTICLES, file TIL09433_to_TIL17062.pdf. Source for: the card for the Macintosh LC; order number M0443LL/A; the Apple Ethernet connector and media adapters; DP83932 SONIC; under 4 W; 10 to 40 °C; AppleTalk Phase 2.
- ↑ 25.0 25.1 Apple Computer, "Macintosh 630 Family of Computers: Modems and Ethernet (8/94)", Tech Info Library article 16018 (TA32256), revised 25 April 1995, in the archive.org collection APPLE_TIL_ARTICLES, file TIL09433_to_TIL17062.pdf. Source for: one communications slot only; a modem and Ethernet together needing the Express Fax/Modem in the comm slot and an LC Ethernet card in the LC PDS slot.
- ↑ 26.0 26.1 Apple Computer, "Macintosh LC II: LC Ethernet Card Requires New Driver", Tech Info Library article 9944 (TA48266), in the archive.org collection APPLE_TIL_ARTICLES, file TIL09433_to_TIL17062.pdf. Source for: the card needing a ROM upgrade with a new driver for the LC II.
- ↑ 27.0 27.1 27.2 Apple Computer, "LC III & LC 575: Use Latest ROMs in Ethernet LC Card (12/94)", Tech Info Library article 11577, in the archive.org collection APPLE_TIL_ARTICLES, file TIL09433_to_TIL17062.pdf. Source for: the "could not switch to EtherTalk" error with an old card; new card assembly 670-2008 with ROM 341-0470, old assembly 670-4443 with ROM 341-0842; installing EtherTalk from System 7.1 or later.
- ↑ Apple Computer, "Macintosh Processor Upgrade: PDS and Comm Slot Usage (4/97)", Tech Info Library article 16298 (TA32507), in the archive.org collection APPLE_TIL_ARTICLES, file TIL09433_to_TIL17062.pdf. Source for: the Macintosh Processor Upgrade not fitting with an LC-style card such as the Ethernet LC card; the communications slot remaining usable.
- ↑ 29.0 29.1 Apple Computer, "Ethernet NB Card: Cables, Connections, Termination (11/94)", Tech Info Library article 9149 (TA47493), in the archive.org collection APPLE_TIL_ARTICLES, file TIL00001_to_TIL09432.pdf. Source for: termination by the Thin Coax Transceiver and self-terminating cables only when a connector or cable end is free; a T connector at the end of the network on an EtherTalk NB card needing a terminator; EtherTalk NB and Ethernet NB cards mixing on one network.
- ↑ 30.0 30.1 Apple Computer, "Apple Ethernet NB Card: No Option to Disable Link Beat Signal", Tech Info Library article 9693 (TA48077), in the archive.org collection APPLE_TIL_ARTICLES, file TIL09433_to_TIL17062.pdf. Source for: no way to turn off link beat; early hubs that cannot work with it.
- ↑ Apple Computer, Macintosh LC 575 Developer Note (1994), hosted as File:Macintosh LC 575 Developer Note.pdf (see Macintosh LC 575 Developer Note), "Communications Options". Source for: the internal communications interface socket taking a 14.4 modem, an AUI Ethernet interface or a 10BASE-T Ethernet interface, and the socket not being an expansion connector.
- ↑ Apple Computer, "Performa 575: Using LC 575 Communication Cards (5/94)", Tech Info Library article 15356 (TA31706), in the archive.org collection APPLE_TIL_ARTICLES, file TIL09433_to_TIL17062.pdf. Source for: all LC 575 communication slot options being supported in the Performa 575.
- ↑ Apple Computer, "Apple IIe Card: Can't Use Comm slot device With Card (9/96)", Tech Info Library article 15065 (TA31483), in the archive.org collection APPLE_TIL_ARTICLES, file TIL09433_to_TIL17062.pdf. Source for: the Apple IIe Card not working when any device is fitted in the comm slot of the LC 575.
- ↑ Apple Computer, Power Macintosh 5500 and 6500 Computers Developer Note (1997), hosted as File:Power Macintosh 5500 and 6500 Computers Developer Note (1997).pdf (see Power Macintosh 5500 and 6500 Computers Developer Note), "Communications" and "Compatibility Issues". Source for: the PCI-based comm slot II, the same as in the Performa 6400 and Power Macintosh 5400; the cards supported (10BASE-T, 10BASE2 and AAUI Ethernet cards and a 28.8 or 33.6 modem); comm slot I cards not compatible.
- ↑ 35.0 35.1 Apple Computer, "Power Macintosh 5400 & 6400: Switching to Ethernet (10/96)", Tech Info Library article 19921 (TA35608), in the archive.org collection APPLE_TIL_ARTICLES, file TIL17065_to_TIL60496.pdf. Source for: the Apple Ethernet CS II card and software working only under Open Transport.
- ↑ Apple Computer, "Ethernet NB Card: Install EtherTalk 2.5.1 or Later", Tech Info Library article 9801 (TA48143), in the archive.org collection APPLE_TIL_ARTICLES, file TIL09433_to_TIL17062.pdf. Source for: the EtherTalk software on the System 7.0 and 7.0.1 disks installing no driver for the Ethernet NB card; the NSI 1.1 disk.
- ↑ Apple Computer, "MacIPX and Comm Slot II Ethernet Errors (4/97)", Tech Info Library article 20175 (TA35801), in the archive.org collection APPLE_TIL_ARTICLES, file TIL17065_to_TIL60496.pdf. Source for: error −43 when selecting Ethernet in MacIPX on the 5400, 6400 and 6360; the 6360/64xx/54xx Update, rolled into Mac OS 7.6.
