AppleCD 300i
(Redirected from AppleCD 300 Plus)
AppleCD 300i
AppleCD 300i in a Macintosh, from Apple's 1992 user's guide
Type Internal double-speed SCSI CD-ROM drive
Release date 1992 (300i); 1994 (300i Plus)
Interface Internal SCSI
Model M3152LL/A (300i Plus); service part 661-1646 (300i)
Power +5 V DC 350 mA maximum; +12 V DC 750 mA average, 1.5 A peak (300i)
Storage 656 MB (Mode 1), 748 MB (Mode 2) per disc
Media 12 cm discs in a CD caddy (300i); 8 cm or 12 cm discs in a powered tray (300i Plus)
The AppleCD 300i is Apple's internal double-speed CD-ROM drive of 1992, a caddy-loading SCSI drive fitted in the removable-media bay of a Macintosh. The AppleCD 300i Plus of 1994 replaced the caddy with a powered tray, and Apple's service manuals for several 1993-1995 machines call the tray-loading internal drive the AppleCD 300 Plus or AppleCD 300+.[1][2] The external counterparts are the AppleCD 300 and the AppleCD 300e Plus.
AppleCD 300i
The 300i reads HFS, ISO 9660 and High Sierra discs, plays audio CDs and opens Kodak multisession Photo CD discs, which need QuickTime and the Photo CD extension. It works with CD-ROM XA, CD+G and CD+MIDI discs when suitable software is installed. Its SCSI ID is 3.[1] Apple's AppleCD 300 Speed Switch control panel switches it between Faster and Standard Speed for programs that do not work correctly at double speed.[1] The drive motor stops when the caddy is ejected or when the disc has not been used for a few minutes, and starts again when the drive is accessed or a disc is inserted.[1]
Apple's Service Sources list the AppleCD 300i as the CD-ROM drive of the Macintosh LC 520, the Performa 550 and 560, and the Macintosh TV, and give its service part number as 661-1646 in the Macintosh IIvx family.[3][4][5][6]
AppleCD 300i and 300i Plus specifications[1][7]
Item AppleCD 300i (1992) AppleCD 300i Plus (1994)
Loading CD caddy Powered tray
Average access time 360 ms normal, 295 ms double speed 410 ms normal, 295 ms double speed
Data-streaming rate Normal 150K/s (Mode 1), 171.1K/s (Mode 2); double 300K/s, 342.2K/s
Rotational speed About 530-230 rpm normal, 1,060-460 rpm double
SCSI burst rate 2.5 MB/s 2.5 MB/s asynchronous, 2.1 MB/s synchronous
Blocks per disc 270,000 typical 336,150
Supply tolerance +5 V ±5%, +12 V ±10%
Power consumption +5 V 350 mA maximum; +12 V 750 mA average, 1.5 A peak +5 V 450 mA typical; +12 V 420 mA typical
Noise (maximum) Seek under 50 dB; non-seek under 46 dB As the 300i; tray open/close under 55 dB
Operating temperature +5 to +50 °C 5-55 °C
The 300i Plus guide gives the laser as a semiconductor GaAlAs laser of 790 ± 25 nm and 0.2 mW output, a Class 1 laser product.[7]
AppleCD 300i Plus
The 300i Plus is the internal version of the AppleCD 300e Plus: double speed, a 256K cache, SCSI-2 and a powered tray that takes 8 cm and 12 cm discs. Apple sold it as order number M3152LL/A for Macintosh models with a half-height 5.25-inch removable-drive bay; it needed an adapter kit and installation by an authorised Apple service provider. The data sheet gives its size as 4.25 × 14.8 × 21.0 cm and its weight as 0.95 kg, and its supply requirement as 5 V DC at 350 mA maximum and 12 V DC at 1.5 A maximum.[2]
AppleCD 300 Plus
Apple used several names for the internal tray-loading double-speed drive in its Service Sources. The Macintosh LC 520/550/575 manual calls the LC 550 and LC 575 drive the "caddyless CD 300+" and the "AppleCD 300+", and the Performa 500 Series manual calls the Performa 575, 577 and 578 drive the "AppleCD 300+i, double-speed CD-ROM drive (trayloading, caddyless)".[3][4] The Power Macintosh 6100/WS 6150 manual lists an "Internal AppleCD 300 Plus CD-ROM drive" in the 6100/60AV and in some 6100/66 and 6100/66AV models.[8]
The tray drive does not fit every chassis that took the caddy drive. In the LC 520/550/575 manual, the earlier chassis harness assemblies (922-1824 and 922-0557) place the CD-ROM connector bridge about 1½ inches above the drive bay and support only drives earlier than the 300i+, while chassis 661-1094, with the bridge 1/2 inch above the bay, is the one for the 300i+.[3]
Care and troubleshooting
The internal AppleCD 600i, the quad-speed successor, from the front and rear (llamamusic.com)
Apple's guides give these rules and fixes. The drive is serviced as part of the host Macintosh; see the Service Source for the machine.[1][7]
  • Never move the computer with a disc or caddy in the drive. Dust on the lens can stop the drive reading discs.
  • 300i Plus: do not leave the tray open, put nothing on it, and do not force it open by hand. Do not wipe the lens with a paper towel or anything abrasive; Apple referred owners to an authorised service provider for a lens cleaner.
  • 300i caddy jammed or only partly ejected: switch the computer off, straighten at least 3 inches of a large paper clip and push it firmly and horizontally into the pinhole below and to the right of the drive door. Apple warns that doing this with the power on may damage the drive. If the next caddy then will not load, shut down, wait about fifteen seconds and start up again. A caddy that comes part way out and is pulled back in, over and over, has the disc edge resting on the hinge of the caddy door: catch the caddy with a straightened paper clip as it comes out, pull it free and reseat the disc flat.
  • 300i Plus tray will not open: press the Open/Close button; if that fails, switch the computer off and push a large straightened paper clip into the small pinhole to the lower right of the tray opening, push gently until the tray is released and pull it out carefully. Forcing it can break the front of the tray.
  • Disc ejected without an error message, or icon not appearing: make sure the disc lies flat with the label up and the tray is fully closed, and that the CD-ROM software is installed; restart.
  • Jerky video or poorly synchronised sound on a 300i: set the AppleCD 300 Speed Switch control panel to Standard Speed.
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 Apple Computer, AppleCD 300i User's Guide (1992), hosted as File:AppleCD 300i User's Guide (1992).pdf. Chapter 1, pp. 1-3 (PDF pp. 7-9): internal drive, formats, care and handling; Chapter 3, p. 11 (PDF p. 17): motor stops when idle; Chapter 6, Troubleshooting, pp. 31-35 (PDF pp. 37-41); Appendix, Specifications, pp. 37-38 (PDF pp. 43-44).
  2. ↑ 2.0 2.1 Apple Computer, AppleCD 300e Plus and AppleCD 300i Plus data sheet, L00318C, March 1994, hosted as File:AppleCD 300e Plus and 300i Plus Data Sheet (1994).pdf. AppleCD 300i Plus order number M3152LL/A; half-height 5.25-inch removable-drive bay, adapter kit, installation by an authorised Apple service provider; internal power, environment, size and weight.
  3. ↑ 3.0 3.1 3.2 Apple Computer, Macintosh LC 520/550/575 Service Source, hosted as File:Lc 520.550.575.pdf (see Macintosh LC 520/550/575 Service Source). Basics, Product Information p. 2 (PDF p. 4); Specifications (PDF p. 10); Take Apart, Chassis Harness Assembly p. 37 (PDF p. 74).
  4. ↑ 4.0 4.1 Apple Computer, Performa 500 Series Service Source, hosted as File:Performa 500 series.pdf (see Performa 500 Series Service Source). Basics, Identifying Features (PDF p. 4); Specifications (PDF p. 9).
  5. ↑ Apple Computer, Macintosh TV Service Source, hosted as File:Macintosh tv.pdf (see Macintosh TV Service Source), Specifications (PDF p. 7).
  6. ↑ Apple Computer, Macintosh IIvx/IIvi/Performa 600 Service Source, hosted as File:Macintosh iivx.vi.perf 600.pdf (see Macintosh IIvx/IIvi/Performa 600 Service Source), Exploded View (PDF p. 76): CD-ROM drive 661-1646 (AppleCD 300i), 661-0913 (600i), 661-0023 (300).
  7. ↑ 7.0 7.1 7.2 Apple Computer, AppleCD 300i Plus User's Guide (1994), hosted as File:AppleCD 300i Plus User's Guide (1994).pdf. Care and handling p. 7 (PDF p. 16); Chapter 5, Troubleshooting, pp. 53-60 (PDF pp. 63-69); Appendix, Specifications, pp. 61-64 (PDF pp. 70-73).
  8. ↑ Apple Computer, Power Macintosh 6100/WS 6150 Service Source, hosted as File:Powermac 6100 series.pdf (see Power Macintosh 6100/ WS 6150 Service Source), Specifications, Disk Storage p. 5 (PDF p. 27).
