Apple Display Card 24AC
Apple Macintosh Display Card 24AC
The 24AC in Apple's 1994 module identification manual
Manufacturer Apple Computer
Type 24-bit accelerated NuBus display card
Interface NuBus (7-inch card), DB-15 video connector
Compatible Macintosh II family, Centris, Quadra and Power Macintosh computers with a NuBus slot; PowerBook Duo Dock
Dimensions 6.5 × 4 in
Power +5 V 1.8 A, −12 V 0.01 A (maximum)
Part number 661-0432 (service module)
The Apple Macintosh Display Card 24AC is a 7-inch NuBus display card with QuickDraw acceleration. It drives Apple's colour displays at 24 bits per pixel (16.7 million colours) and its grey-scale displays at 8 bits per pixel. It fits Macintosh II, Centris, Quadra and Power Macintosh computers with a NuBus slot.[1] Apple's service part for the card is module 661-0432.[2][3]
The 24AC is the same card, or very nearly the same, as Radius's PrecisionColor Pro 24AC.[4] Apple's own documents point the same way: the ROM label reads "Radius 24AC", and Apple directed owners of the Radius-sold version to Radius for support.[5]
Item Specification
Interface NuBus, 7-inch card
Video connector 15-pin D-style (RS-343A)
Maximum depth 24 bits per pixel (16.7 million colours) at every resolution
Size 6.5 × 4 in
NuBus power (maximum) +5 V 1.8 A; +12 V 0.0 A; −12 V 0.01 A
System software System 7.1 or later
Memory 2 MB of RAM or more (4 MB recommended)
Operating temperature 10 to 55 °C
Humidity 5 to 95 % non-condensing
Figures from Apple's technical specification sheet.[6] Apple notes that some Macintosh II family computers can take the card only with an additional NuBus adapter card.[6]
Display modes
The 24AC supports five standard Macintosh resolutions and three more for multiple scan and VGA-type displays, all at up to 24 bits per pixel.[6]
24AC display modes
Macintosh resolutions Additional resolutions
640 × 480 at 67 Hz 640 × 480 at 60 Hz
832 × 624 at 75 Hz 800 × 600 at 60 Hz
1024 × 768 at 75 Hz 1024 × 768 at 60 Hz
1152 × 870 at 75 Hz
640 × 870 at 75 Hz (Portrait Display)
The card reads the multiple scan sense codes and changes resolution without a restart, so a multiple scan display on a 24AC needs no sense adapter, even under older system software.[7] Apple qualified its AppleVision displays on the 24AC as well as on built-in video.[8]
Output by display
Apple's 1996 compatibility chart gives these maximum outputs for the 24AC.[2]
24AC output on Apple displays (1996 chart)
Display Output
Macintosh 12" Monochrome Display 256 greys
Macintosh 12" RGB Display 16.7 million colours
Apple Basic Color Monitor (14") Not supported
Apple Color Plus 14" Display, Apple Performa Display, Apple Performa Plus Display 16.7 million colours
AppleColor High-Resolution RGB, Macintosh Color Display, AudioVision 14, multiple scan and AppleVision displays at 640 × 480 16.7 million colours
Macintosh 16" Color Display and multiple scan displays at 832 × 624 16.7 million colours
Macintosh Portrait Display 256 greys
Apple Two-Page Monochrome Monitor 256 greys
Multiple Scan 17 and Multiple Scan 20 at 1024 × 768 16.7 million colours
Macintosh 21" Color Display and Multiple Scan 20 at 1152 × 870 16.7 million colours
AppleVision 1710 and 1710AV at 1280 × 1024 Not supported
Software and ROM versions
Acceleration needs the 24AC software installed. On a Power Macintosh, version 1.2 of the software or later is required; earlier versions run the card unaccelerated and report that the board cannot be used in accelerated mode.[9] The acceleration icons appear in the Options window of the Monitors control panel only when the "Apple Macintosh 24AC" file is in the Control Panels folder, a monitor is connected to the card, and that monitor is selected before Options is clicked; the window should be headed "Apple Macintosh 24AC".[10]
ROM version 1.0 does not work with System 7.5.3 or later: after an upgrade the screen becomes illegible when the resolution or colour depth is changed. Apple shipped its cards with ROM 1.1, which works with 7.5.3 and later. A ROM 1.0 card is either a DVT (developer) board or a card sold by Radius.[5] Low End Mac gives ROM 1.0 as working from System 7.1 to 7.5.2, and ROM 1.1 as working up to Mac OS 8.6.[4] To identify the version, read the label on the ROM, which names "Radius 24AC" with the version beneath. The solder side carries a bar code beginning "ACH".[5]
Compatibility notes
Video connector
The DB-15 pinout below is Apple's.[6]
24AC video connector
Pin Signal Pin Signal
1 Red return 9 Blue video
2 Red video 10 ID 3 (sense)
3 Composite sync 11 Composite and vertical sync return
4 ID 1 (sense) 12 Vertical sync
5 Green video 13 Blue return
6 Green return 14 Horizontal sync return
7 ID 2 (sense) 15 Horizontal sync
8 Reserved Shell Shell ground
Faults and servicing
Apple's service guides list the 24AC only as a whole exchange module, 661-0432.[2][3] Apple's general chart for video cards covers a dark screen, a bright screen with no picture and similar faults. Work through it in order, skipping the memory steps on a card without socketed RAM:[2]
  1. Reseat the card.
  2. Reseat any RAM or VRAM SIMMs on the card.
  3. Check the cable connections.
  4. Run the video diagnostic tests.
  5. Replace socketed VRAM or DRAM.
  6. Replace the card.
If the picture breaks up only after a system software upgrade to 7.5.3 or later, check the ROM version before suspecting the hardware.[5] If acceleration is missing on a Power Macintosh, check the software version and the control panel conditions above.[9][10]
  1. ↑ 1.0 1.1 Apple Computer, "Display Card 24AC: Description (6/95)", Tech Info Library article 13987, created 16 November 1993, revised 28 June 1995. In the archive.org collection Apple's Technical Information Library Articles, file TIL09433_to_TIL17062.pdf. Source for: 24-bit colour on Apple colour displays and 8-bit grey scale on grey-scale monitors; QuickDraw acceleration; compatibility with Quadra, Centris and Macintosh II family computers, Power Macintosh computers with a NuBus slot and the Duo Dock; 7-inch NuBus card; support for multiple scan displays, possibly through a third-party adapter.
  2. ↑ 2.0 2.1 2.2 2.3 Apple Computer, Macintosh Displays and Video Cards service guide, September 1996, hosted as File:Apple Macintosh Displays and Video Cards Service Guide (September 1996).pdf (described at Apple Macintosh Displays and Video Cards Service Guide (1996)). Video card parts list p. 325; troubleshooting chart p. 327; Table 16, "Video Cards–Card Compatibility and Video Output Chart", pp. 342-343.
  3. ↑ 3.0 3.1 Apple Computer, Module Identification, Apple Service part number 072-8124, June 1994, hosted as File:Apple Service Module Identification Manual (June 1994).pdf, p. 4.5.2 (PDF page 264), "Apple Macintosh Display Card 24AC 24-Bit NuBus Card", Apple P/N 661-0432, page dated January 1994.
  4. ↑ 4.0 4.1 Low End Mac, "Macintosh Display Card 24AC", https://lowendmac.com/1994/macintosh-display-card-24ac/ (retrieved 2026-10-04). Source for: the card being the same or nearly the same as the Radius PrecisionColor Pro 24AC; Mac OS support by ROM version.
  5. ↑ 5.0 5.1 5.2 5.3 Apple Computer, "Mac Display Card 24AC: ROM V1.0 Isn't Compat w/7.5.3 (10/96)", Tech Info Library article 20599 (TA36169), file TIL17065_to_TIL60496.pdf in the APPLE_TIL_ARTICLES collection. Source for: ROM 1.0 not compatible with System 7.5.3 or later; Apple shipped the card with ROM 1.1, which is; ROM 1.0 found only on DVT (developer) cards and cards bought from Radius; the ROM label reading "Radius 24AC" with the version below it; a bar code beginning "ACH" on the solder side.
  6. ↑ 6.0 6.1 6.2 6.3 Apple Computer, "Macintosh Display Card 24AC: Technical Specifications (12/94)", Tech Info Library article 14837, created 9 March 1994, revised 21 December 1994, file TIL09433_to_TIL17062.pdf in the APPLE_TIL_ARTICLES collection. Source for: system requirements (Macintosh II family with NuBus slot, Centris, Quadra or Power Macintosh; some Macintosh II family computers need an additional NuBus adapter card; 2 MB RAM, 4 MB recommended; System 7.1 or later); operating environment; 6.5 × 4 in; NuBus interface; RS-343A 15-pin connector; display modes; 24-bit maximum depth; NuBus power allowances; video port pinout.
  7. ↑ Apple Computer, "Macintosh Displays: Overview of Sense Codes and Adapters", Tech Info Library article 14890 (TA21607), file TA20315-TA29994.pdf in the APPLE_TIL_ARTICLES collection. Source for: sense code adapters for older cards; the 24AC as a programmable card that recognises multiple scan sense codes and changes resolution without restarting.
  8. ↑ Apple Computer, "AppleVision 1710AV: Frequently Asked Questions", Tech Info Library article 19108 (TA21682), file TA20315-TA29994.pdf in the APPLE_TIL_ARTICLES collection, question 7. Source for: AppleVision monitors qualified on built-in ports of 68040 and PowerPC Macs, the 24AC NuBus card and the ATI PCI card.
  9. ↑ 9.0 9.1 Apple Computer, "Macintosh Display Card 24AC: Compatibility With Power Macintosh", Tech Info Library article 15049 (TA31470), last changed 27 July 1994, file TIL09433_to_TIL17062.pdf in the APPLE_TIL_ARTICLES collection. Source for: full Power Macintosh compatibility from revision 1.2 of the 24AC software; earlier versions did not support accelerated operation on Power Macintosh.
  10. ↑ 10.0 10.1 10.2 Apple Computer, "Display Card 24AC: Power Macintosh Can Use Acceleration (2/95)", Tech Info Library article 17245 (TA33342), file TIL17065_to_TIL60496.pdf in the APPLE_TIL_ARTICLES collection. Source for: no problems using the card in any Power Macintosh with a free NuBus slot; the three conditions for the acceleration icons to appear.
  11. ↑ Apple Computer, "AV Series: Apple NuBus Video Card Compatibility", Tech Info Library article 14695 (TA31196), file TA30000-TA39999.pdf in the APPLE_TIL_ARTICLES collection. Source for: the 24AC is a 7-inch NuBus card and so fits the Centris 660AV, Quadra 660AV and Quadra 840AV; significant performance (speed) problems in accelerated mode.
