Apple Macintosh Color Display
Macintosh Color Display (M1212)
Manufacturer Apple Computer
Type 14-inch Trinitron colour monitor
Interface Analogue RGB, separate sync
Model M1212
Power Universal 90-270 V AC, 47-63 Hz; 37 W normal, 55 W maximum
The Macintosh Color Display (M1212) is a 14-inch colour monitor with a Sony Trinitron tube that Apple introduced in 1992 as the smallest of its Macintosh Color Display range.[1][2] It runs at a fixed 640 × 480.[3]
The display contains a CRT. Read CRT Discharge Procedure before opening it; Apple warns not to wear a grounding wrist strap until the CRT has been discharged.[4]
Macintosh Color Display specifications[3]
Item Value
Picture tube 14 in diagonal, 11.5 in viewable; Trinitron, 0.26 mm aperture-grille pitch
Resolution 640 × 480, 70 dpi; active area 235 × 176 mm
Scan rates 35.0 kHz horizontal, 66.7 Hz vertical
Input Analogue RGB; separate sync, negative-going TTL
Mains Universal, 90-270 V AC, 47-63 Hz
Power 37 W normal, 55 W maximum
Fuse Internal, on the main board; service part 922-0004
Size 330 mm high, 344 mm wide, 394 mm deep
Weight 11.3 kg (24 lb 14 oz) with cables
Warm-up 20 minutes to meet all specifications
Apple's exploded view lists the main deflection board in three versions: 661-0102 (with Energy Star), 661-1650 (without Energy Star) and 661-0169 (Rev. B). The CRT assembly is 661-1666, and the convergence controls are on the CRT video board. The take-apart chapter also covers the on/off switch assembly, the contrast, brightness and LED assembly, the base, the bezel, the power cable (590-0370) and the video cable (922-0035).[5] All adjustments use a short hex-head plastic tool; Apple warns against metal tools.[6]
A thin horizontal line about a third of the way up the picture is the support wire of the Trinitron aperture grille. Apple says it is common to all Trinitron displays smaller than 15 inches and cannot be adjusted out or removed by replacing modules.[7]
Known faults
Apple's symptom charts start with the surroundings and the computer: move the monitor away from other monitors, fluorescent lights and electrical equipment, check the computer's video with a known-good monitor, and adjust before replacing anything. Most remaining faults end at the main board, with the CRT for focus that stays bad in one area, a colour tint that cannot be removed, burnt phosphor and a black raster with a single line.[8] See Apple Macintosh Color Display Troubleshooting Guide.
  1. ↑ Apple Macintosh Color Display (M1212), CRT Database—link(accessed 2026-09-30)
  2. ↑ Apple displays, Wikipedia—link(accessed 2026-10-02) Used for the 1992 range of 14-, 16- and 20-inch Macintosh Color Displays.
  3. ↑ 3.0 3.1 Apple Computer, Macintosh Color Display (Service Source), 96 pp., Specifications, pp. 1-6 (PDF pp. 3-8). Hosted here: File:Macintosh color display.pdf (see Macintosh Color Display Service Source).
  4. ↑ Macintosh Color Display Service Source, Take Apart, Fuse, pp. 30-31 (PDF pp. 51-52).
  5. ↑ Macintosh Color Display Service Source, Take Apart contents and Exploded View, pp. 1-31 and p. 96 (PDF pp. 22-52, 96).
  6. ↑ Macintosh Color Display Service Source, Adjustments, Geometry, p. 2 (PDF p. 55).
  7. ↑ Macintosh Color Display Service Source, Troubleshooting, Symptom Charts/Miscellaneous, pp. 10-11 (PDF pp. 19-20).
  8. ↑ Macintosh Color Display Service Source, Troubleshooting, Symptom Charts, pp. 2-11 (PDF pp. 11-20).
