Atari 1020 Troubleshooting
Fault-finding on the Atari 1020 Color Printer follows the power-up test, the test programs and the flowcharts in Atari's 1020 Color Printer Field Service Manual (FD100288 Rev. 01).[1] Pens, gears and adjustments are covered on the Atari 1020 Maintenance Guide.
Power-up test
[edit | edit source]Press POWER. The key should stay down and the LED light. The print head moves to the far left, waits two or three seconds, draws four coloured squares and stops near the left margin.[1] The squares also show the state of each pen: a faded square means a pen running dry.[2]
Atari's power-up flowchart branches from here:[1]
- Key does not stay down: replace the switch assembly.
- LED does not light: the no-power chart below.
- Pens write when they should not: the pen-up chart.
- Pens do not write at all: check the pens, then the pen-down chart.
- Paper does not move: the paper feed chart.
- Print head does not move: the print head chart.
- Wrong colours: the colour chart (p. 4-10).
Things that are not faults
[edit | edit source]- The PAPER, COLOR and PEN buttons do nothing until the data sent to the printer ends with a carriage return or line feed. If the printer stops in that state, sending a carriage return makes the buttons work again.[1]
- Pressing PAPER and COLOR together resets the printer to text mode and moves the carriage to the left end.[1]
- Holding PEN for more than three seconds sends the carriage home and prints the four-square test.[2]
- In the colour-change test with increments of 3, the holder turns three steps and then one more, back to home. Atari notes this is normal.[1]
Test programs
[edit | edit source]Atari's CPS diagnostic diskette runs T1020.BAS (FD100577), with an all-function test and loops for pen up and down, platen up and down, carriage right and left, and pen change. Without the diskette, the manual gives short BASIC programs:[1]
- Text test: the same character-loop program used for the other Atari printers, run with the codes for 20, 40 and 80 columns and the international character set. Print that is lighter on one side of the line means worn pens or a worn rotary pen holder.
- Carriage motor: in graphics mode (ESC ESC CTRL-G), loop
M480,0;0,0. - Paper feed motor: in graphics mode, loop
M0,999;0,-999. - Pen up and down: the text test in 80 columns with international characters gives rapid pen movement.
If a particular command fails, swap A1 and A2.[1]
Symptom checklist
[edit | edit source]| Symptom | Possible cause | Flowchart |
| LED, no power | D10, A6, D1-D4, J3 | C, p. 4-4 |
| No initialisation | A1, A2, A3, motors, pens | B, p. 4-3 |
| Pens do not write | Pens, J4, print mechanism, A1, A2, A3 | E, p. 4-7 |
| Pens always write | J4, print mechanism, A1, A2, A3 | D, p. 4-5 |
| No paper feed | Print mechanism, A1, A2, A3 | F, p. 4-8 |
| Print head does not move | Print mechanism, J4, A1, A2, A3 | G, p. 4-9 |
The checklist sends "pens do not write" to the pen-up chart (E) and "pens always write" to the pen-down chart (D). The power-up flowchart does the opposite, sending pens that write when they should not to E and pens that do not write to D, which matches the chart titles.[1]
No power
[edit | edit source]| Check | If yes | If no |
| Is the adaptor good? | Next check | Replace the adaptor |
| +5 V DC on pin 3 of A6? | LED faulty, or open from A6 pin 3 to D10 | Next check |
| 8-13 V DC on pin 1 of A6? | A6 faulty, or C3 or C7 shorted | Next check |
| 8-13 V DC on the cathode of D3? | Open from D3 cathode to A6 pin 1 | Next check |
| 9 V AC on the anode of D4? | One of D1-D4 faulty | J3 or C15 faulty, or open from J3 to D4 |
A5 and A6 are HA17805P regulators and D1-D4 the bridge rectifier.[1]
Pens
[edit | edit source]| Step | Check | Remedy |
| 1 | Does the pen mechanism move freely when the actuator is pulled off the permanent magnet by hand? | If not: adjust or replace the electromagnet; set the 0.1-0.2 mm actuator gap; check the ejection lever shaft and spring and any binding; the actuator spring must overcome the ejection lever spring |
| 2 | Is there a single 5.4 ms pulse at J4-P12 (pen down) or J4-P13 (pen up) while the test runs? | If yes: replace the electromagnet assembly |
| 3 | 5 V DC at the output of A5? | If not: replace A5 |
| 4 | 5 V DC at J4-P7? | If not: open circuit between J4 pin 7 and A5 |
| 5 | Logic low pulse at A2 pin 10 (pen down) or pin 9 (pen up)? | If not: check the crystals, then replace A2, then A1 (pen down); swap A2 and A1 (pen up) |
| 6 | Transistors good against table 4-1? | If not: replace the transistor; if so, replace the board |
| Pen up (A2 pin 9) | Pen down (A2 pin 10) | Emitter | Base | Collector |
| Q2 | Q1 | Vc | 5 V to 4 V | 0 V to 5 V |
| Q3 | Q4 | Ground | 0 V to 1 V | 5 V to 0 V |
| Q6 | Q7 | Vp | 5 V to 4 V | 5 V to 0 V |
All the signals in table 4-1 are pulses of about 5 ms while the pen up-down test runs, and the mechanism need not be connected to see them.[1] The theory section of the same manual names Q5, not Q3, as the ground-side transistor in the pen-up path.[1]
The flowchart asks whether X1 and X2 run at 4.43 MHz, while the parts list and theory section give 4 MHz crystals.[1]
Dried-out pens make a 1020 that otherwise moves correctly draw faintly or not at all.[3][4] Replacement pens made from cut-down ballpoint refills drew nothing in one repair because the mechanism's pen pressure was too low for them; gel refills worked.[5]
Paper feed and print head movement
[edit | edit source]| Check | Paper feed | Print head |
| +5 V on pin 7 of J4? | If not: go to chart I (p. 4-11) | If not: go to chart I |
| Does the motor run on its own? | If so: mechanical fault around the paper feed motor, right of the print head | If so: mechanical fault around the print head motor, left of the print head |
| About 5 V p-p square wave on A3 during the test? | Pins 15-18, platen up/down test; if present, replace the motor | Pins 11-14, draw right/left test; if present, replace the motor |
| About 4 V p-p square wave on A2 during the test? | Pins 29-32; if absent, swap A2, A1 and A3 in turn | Pins 25-28; if absent, swap A2, A1 and A3 in turn |
| Both present? | A3 faulty or an open line: repair | A3 faulty or an open line: repair |
The draw right/left test moves the carriage without the pen down, so it draws no line; and the platen-up test pulls in any paper loaded, so run platen-down or remove the paper first.[1]
Split nylon pinion gears on the two motor shafts are a frequent mechanical cause: Moore writes that many 1020s fail this way, and the Tandy wiki says nearly all these gears have split or soon will. A split paper-feed gear stops accurate vertical movement; a split carriage gear stops the pen holder travelling properly. Both were cracked on a new-in-box 1020.[3][6] Replacement is on the Atari 1020 Maintenance Guide.
Dead but lit
[edit | edit source]One 1020 lit its LED but neither moved the head nor fed paper at switch-on. The supply rails and chip supplies read 5 V, the clock from X1 was present, but X2, which clocks the main controller, showed nothing on the oscilloscope. A new 4 MHz crystal at X2 fixed it.[4] Atari's pen-down chart also checks both crystals before condemning A2 or A1.[1]
[edit | edit source]- Atari 1020
- Atari 1020 Maintenance Guide
- Atari 1020 Capacitor Replacement Guide
- Atari 1020 Documentation
[edit | edit source]- ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 1.12 1.13 1.14 Atari, Inc., 1020 Color Printer Field Service Manual, FD100288 Rev. 01, August 1983. Theory of operation (pp. 1-8 to 1-12); testing (pp. 3-1 to 3-10); diagnostic flowcharts (pp. 4-1 to 4-10, table 4-1 on p. 4-6); symptom checklist (p. 5-1); adjustments (pp. 6-5 and 6-6); parts list (p. 7-1). Hosted here as File:Atari 1020 Color Printer Field Service Manual FD100288 Rev 01.pdf.
- ↑ 2.0 2.1 Atari, Inc., The Atari 1020 Color Printer Owner's Guide (1982), test pattern and pen pages. Hosted here as File:Atari 1020 Color Printer Owner's Guide.pdf.
- ↑ 3.0 3.1 Jason H. Moore, "Repair an Atari 1020 Printer (30-60 mins)", Atari Projects, 25 August 2018. atariprojects.org. Community repair write-up.
- ↑ 4.0 4.1 RetroNerd, "Atari 1020 Colour Printer Plotter Repair", 7 January 2024. retronerd.co.uk. Community repair write-up.
- ↑ drygol, "Atari 1020 Plotter – plotting pens replacement", retrohax.net, 2 February 2024. retrohax.net. Community repair write-up.
- ↑ Tandy Tech wiki, "CGP-115", gears section (last edited 1 August 2026). tandy.wiki. Community reference.
