Atari 1020 Capacitor Replacement Guide
Atari 1020 with the top cover removed
The Atari 1020 Color Printer has five aluminium electrolytic capacitors on its board. The largest is the main filter after the bridge rectifier; two more sit on the outputs of the two 5 V regulators, and two on the reset pins of the microcontrollers.[1] All values and ratings below are from Atari's schematic in the field service manual.
Capacitor list
Atari 1020 electrolytic capacitors (FD100288 figure 2-2)
Ref Value Voltage Where it sits
C8 6,800 µF 25 V Main filter, after the bridge rectifier D1-D4 and before the regulators
C7 33 µF 16 V Output of A6 (HA17805P), the Vc +5 V rail for logic and motors
C6 10 µF 16 V Output of A5 (HA17805P), the Vp +5 V rail for the pen solenoid
C13 1 µF 35 V Reset pin of A2, the printer controller
C14 4.7 µF or 47 µF (the hosted scan is not clear) 35 V Reset pin of A1, the serial/parallel controller
The board also carries a 1 µF 100 V film capacitor (C15) across the AC input and 0.1 µF 50 V ceramic capacitors (C3, C4, C5) beside the regulators; these are not electrolytics.[1] Check the value printed on C14 itself before ordering.
Signs of failure
  • No power LED. Atari's flowchart checks for 8-13 V DC on pin 1 of A6 and, if it is present with no 5 V out, blames A6 or a shorted C3 or C7.[1]
  • Bulging, leakage or a vented top on C8, the largest capacitor; see Capacitor Failure Symptoms.
C13 and C14 hold the two microcontrollers in reset for a moment at switch-on.[1]
Procedure
  1. Unplug the adaptor; Atari warns against any disassembly with AC power connected.[1]
  2. Open the printer and lift out the printer module as described in the Atari 1020 Maintenance Guide.
  3. Remove the board's four screws and lift it out.[2]
  4. Replace the capacitors one at a time, observing polarity.
Checks after recapping
Voltages to check (FD100288)
Point Expected
Anode of D4 9 V AC from the adaptor
Pin 1 of A6 8-13 V DC
Pin 3 of A6 (Vc) +5 V DC ±5 %
Output of A5 (Vp) +5 V DC ±5 %
The figures are from the no power and pen-down flowcharts and the power supply description.[1] Then switch on and confirm the four-square test pattern; see the Atari 1020 Troubleshooting page.
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 Atari, Inc., 1020 Color Printer Field Service Manual, FD100288 Rev. 01, August 1983: power supply and noise limit capacitors (pp. 1-8 and 1-9); power-on reset (p. 1-12); no power flowchart (p. 4-4); schematic, figure 2-2 (p. 2-5). Hosted here as File:Atari 1020 Color Printer Field Service Manual FD100288 Rev 01.pdf.
  2. ↑ RetroNerd, "Atari 1020 Colour Printer Plotter Repair", 7 January 2024. retronerd.co.uk. Community repair write-up.
