Atari SLM605
| Atari SLM605 | |
| An SLM605 with its paper tray (photograph: atari-computermuseum.de) | |
| Manufacturer | TEC for Atari Corp. according to atari-computermuseum.de; Epson according to the AEX site[1][2] |
| Type | 300 dpi laser page printer |
| Release date | Shown 24 August 1990 (Atari Messe, Düsseldorf); on sale 1990[1] |
| Discontinued | About 1993[1] |
| Price | DM 2,248 (1990); US$1,295.95 (November 1990)[1] |
| Interface | Atari DMA (ACSI) port, through the SLMC804 controller[1] |
| Compatible | Atari ST and TT computers with at least 2 MB of RAM[1] |
| Dimensions | 41 × 21 × 41.5 cm (W × H × D)[1] |
| Weight | 15.4 kg[1] |
| Predecessor | Atari SLM804 |
The Atari SLM605 is a 300 dpi laser printer that Atari Corp. sold for the Atari ST and TT from 1990, as the successor to the Atari SLM804. Like the SLM804 it holds only the print engine. The computer builds each page in its own memory and sends it through the same SLMC804 controller on the DMA port, so it needs at least 2 MB of RAM.[1] It is smaller and a little slower than the SLM804, at 6 pages a minute against 8, but its first page comes out sooner.[1][3]
History
[edit | edit source]atari-computermuseum.de records that the SLM605 was first shown at the Atari Messe in Düsseldorf on 24 August 1990 and went on sale that year at DM 2,248. In the United States it cost $1,295.95 in November 1990. Production ended in about 1993.[1]
START reported from the Fall COMDEX in Las Vegas in November 1990 that the new printer produced fast and flawless copies, printing six pages a minute at 300 × 300 dpi for under $1,300. The same report listed the hardware and software bundles Atari had approved for the fourth quarter of 1990. Two of them, at $2,099 each, were desktop publishing packs with a Mega 2, an Atari SM124 monitor, a Atari Megafile 30 hard disk and an SLM605, one with Calamus and one with Deskset II.[3]
Sources disagree about who built the printer. atari-computermuseum.de gives TEC as the manufacturer, as for the SLM804.[1] The AEX site (atari-explorer.ctrl-alt-rees.com) says the SLM605 was a lower-maintenance unit made for Atari by Epson.[2] No service document hosted here settles the question.
| Print method | Electrostatic photocopying with laser scanning; dry dual-component developer |
| Resolution | 300 dpi |
| Speed | About 20 seconds for the first page, then 6 pages per minute; warm-up about 60 seconds |
| Media | Standard copier paper, labels, envelopes, transparencies suitable for copiers |
| Paper feed | Cassette and manual feed |
| Connection | External SLMC804 DMA controller to the computer's ACSI port |
| Dimensions | 41 × 21 × 41.5 cm (W × H × D) |
| Weight | 15.4 kg |
The control panel in the museum's photograph has a paper-size slider marked Letter, Legal, A4 and B5, keys marked MANUAL, THICK PAPER and PRINT, and lamps that include POWER, READY, ERROR and CHANGE DRUM.[4] The top cover lifts to give access to the drum and toner area.[5]
Controller
[edit | edit source]The SLM605 uses the SLMC804 controller made for the SLM804.[1] The controller's command set and status codes are described in Atari's The Atari Page Printer Interface (April 1988); see Atari SLM804#The SLMC804 controller and Atari SLM804 Troubleshooting Guide#SLMC804 status codes.[6] Those codes come from the controller, so they are what an ST program reports with either printer. The SLM605 engine's own signals and lamps are not covered by any document hosted here.
Repair and documentation
[edit | edit source]The Atari Document Archive lists an Atari SLM605 owner's manual (C398791-001 Rev. A) with a French edition, and an SLM605 service manual (E0-30038A, May 1991). Neither is hosted here.[7] For the shared controller, see Atari SLM804 Troubleshooting Guide and Atari SLM804 Documentation.
Gallery
[edit | edit source]-
Control panel (atari-computermuseum.de)
Top cover raised (atari-computermuseum.de)
SLMC804 controller (atari-computermuseum.de)
Back of the SLMC804 (atari-computermuseum.de)
[edit | edit source]- Atari SLM804
- Atari SLM804 Troubleshooting Guide
- Atari SLM804 Documentation
- Atari Mega ST, Atari Mega STE, Atari TT030
[edit | edit source]- ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 1.12 1.13 atari-computermuseum.de, "Atari SLM605 Laser Printer", in "Atari ST-Peripheriegeräte". https://www.atari-computermuseum.de/st_peri.htm#slm605 (retrieved 2026-10-06).
- ↑ 2.0 2.1 AEX, "Personal Computers: ST Range: Peripherals". http://atari-explorer.ctrl-alt-rees.com/16bit/ST-peripherals.html (retrieved 2026-10-06).
- ↑ 3.0 3.1 John Nagy, "Z*Net Newswire: Atari at Comdex 1990", START vol. 5 no. 6, February/March 1991. https://www.atarimagazines.com/startv5n6/znet.php
- ↑ Photograph of the SLM605 control panel, atari-computermuseum.de. File:Atari SLM605 control panel (Atari Computermuseum).jpg.
- ↑ Photograph of an SLM605 with the top cover open, atari-computermuseum.de. File:Atari SLM605 with top cover open (Atari Computermuseum).jpg.
- ↑ Atari Corp., The Atari Page Printer Interface, 13 April 1988. File:The Atari Page Printer Interface (April 1988).pdf.
- ↑ Atari Document Archive, search results for "slm605" (catalogue listing). https://docs.dev-docs.org/htm/search.php?find=slm605 (retrieved 2026-10-06).
