Atari SLM804 Documentation
Documentation for the Atari SLM804 laser printer and its SLMC804 controller: a scanned compilation of TEC and Atari service material, and Atari's programming document for the controller.
SLM804 service manual and SLMC804 schematics
[edit | edit source]A 31-page scan catalogued on the Internet Archive as the "Atari SLM804 Service Manual [Sep 1987]".[1] It is a compilation. The TEC service manual whose cover it carries (Service Manual Model SLM-804, document E0-16172A, original June 1987, revised September 1987, Tokyo Electric Co., Ltd.) is represented only by its first chapter, the specification.[1] The rest is schematics and drawings.
Contents
[edit | edit source]| PDF page | Contents |
| 1 | Page 2 of Atari's The Atari Page Printer Interface (13 April 1988), the introduction with the controller block diagram |
| 2 and 3 | TEC "Laser Printer Power Supply 200V", drawing SLE52-00301, for board SLE61-0081, April 1987. Designators only, no values |
| 4 to 7 | TEC "MCON-T CCT", the engine controller, drawing JRE52-05101, January 1987, revised April 1987. The article name "LB-1301" is crossed out and "SLM-804" written in |
| 8 | Atari (Japan) Corporation "Schematic Diagram SLMC 804", drawing C026455 Rev. 2, sheet 1 of 3: 6801 microcontroller, 4.0 MHz crystal, DMA bus side. Drawn 28 July 1987 |
| 9 | An SLMC804 interface page without a title block, marked with an arrow labelled "Canno" (cut off by the scan edge): buffers, 75113 line drivers and a 29.821 MHz oscillator |
| 10 | SLMC804 schematic sheet 2 of 3, marked "TEC": 74LS14 and 7408 buffers to the TEC engine signals |
| 11 and 12 | SLMC804 schematic sheet 3 of 3: pull-ups and filter capacitors on the engine lines and the 37-way connector J3, which takes +5 V from the printer on pins 16, 17, 35 and 36 |
| 13 and 14 | SLMC804 printed circuit board drawing C100519 Rev. 2: silk screen and layout |
| 15 and 16 | SLMC804 assembly drawing CA200168 Rev. 3, with an exploded view of the case |
| 17 to 29 | TEC Service Manual Model SLM-804 pages 1 to 13: summary, outside dimensions and floor space, basic specification, operation panel, variohms, video interface pin assignment and signals, interface block diagram, timing charts (power on, single print, line scan, continuous print, errors) |
| 30 | A single page numbered 4-23, "Flowchart of printing sequence" (Fig. 4-20), in a different typeface from pages 1 to 13. Its JAM1 to JAM3 errors match the jam numbering in the SLM-804 timing charts |
| 31 | Cover of TEC's Service Manual Model SLM-804 |
Printed page n of the TEC specification chapter is PDF page n + 16.
What this scan does not contain
[edit | edit source]- The rest of TEC's service manual, apart from the single page 4-23: theory, disassembly, adjustments beyond the two variohms, and troubleshooting.
- A parts list or any component values for the engine boards.
- The power supply for the 100 to 120 V version.
- Any part of Atari's owner's manual.
Pages that cite this document
[edit | edit source]- Atari SLM804: specifications, the SLMC804 controller, the engine boards
- Atari SLM804 General Maintenance: placement, mains, paper, toner and drum, adjustments
- Atari SLM804 Troubleshooting Guide: panel lamps, engine signals, controller and supply checks
Download: Atari SLM804 Service Manual and SLMC804 Schematics (1987).pdf
Atari page printer interface document
[edit | edit source]Atari Corp., The Atari Page Printer Interface, Sunnyvale, California, dated 13 April 1988, RCS revision 1.1.[2] It describes the host side of the SLMC804: how a program on the ST talks to the controller over the DMA bus. It states that it does not cover the interface between the controller and the printer engine.[2] Printed page n is PDF page n + 2.
| Printed page | Contents |
| 2 | Introduction: the controller as translator between the DMA bus and the engine's video interface; command, data out and status phases |
| 3 to 12 | Command definitions: Request Sense (0x03), Print (0x0a), Inquiry (0x12), Mode Select (0x15), Mode Sense (0x1a) and its parameter list, Stop Print (0x1b) |
| 13 to 16 | Status definitions: the status byte and the table of error codes |
| 17 and 18 | Extended command phase and extended status phase |
| 19 to 21 | Appendix: a 68000 assembly driver that prints a Letter page through the DMA port |
[edit | edit source]- Atari SLM804: the controller's command set, identification string and example driver
- Atari SLM804 General Maintenance: page size and toner and drum reporting
- Atari SLM804 Troubleshooting Guide: the status code table and controller behaviour
Download: The Atari Page Printer Interface (April 1988).pdf
Other documents
[edit | edit source]The Atari Document Archive lists these SLM804 documents, which are not hosted here:[3]
- Atari SLM804 Laser Printer Owner's Manual, C033517-001 Rev. A, 1987, and a French edition, C033517-0A4.
- Atari SLM804 Parts List and Recommended Spare Parts List, E5-16168, May 1987.
- SLM804 Printer Emulator (emulation of the Diablo 630), 1987, and a French edition, C300123-003 Rev. A.
- Atari SLM804 driver disks.
- A Dutch "HD Technical Info" document covering the SH204, SH205, Megafile 20/30/60, SLM804 and SLMC804.
An Italian Atari brochure, "Atari 1040 STf – Atari Mega ST – Stampante laser SLM 804", is on the Internet Archive.[4]
[edit | edit source]- ↑ 1.0 1.1 Internet Archive item Atari_SLM804_Service_Manual_Sep_1987. https://archive.org/details/Atari_SLM804_Service_Manual_Sep_1987 (retrieved 2026-10-06). Hosted as File:Atari SLM804 Service Manual and SLMC804 Schematics (1987).pdf.
- ↑ 2.0 2.1 Atari Corp., The Atari Page Printer Interface, 13 April 1988, title page and p. 2 (PDF pp. 1-4). Internet Archive item The_Atari_Page_Printer_Interface_Apr_12_1988. https://archive.org/details/The_Atari_Page_Printer_Interface_Apr_12_1988 (retrieved 2026-10-06). Hosted as File:The Atari Page Printer Interface (April 1988).pdf.
- ↑ Atari Document Archive, search results for "slm804". https://docs.dev-docs.org/htm/search.php?find=slm804 (retrieved 2026-10-06).
- ↑ Atari Italia, "Atari 1040 STf – Atari Mega ST – Stampante laser SLM 804", undated brochure. Internet Archive item atari1040stfmegastslm804. https://archive.org/details/atari1040stfmegastslm804 (retrieved 2026-10-06).
