Panasonic FZ-10 Capacitor Replacement Guide
Community drawing of the FZ-10 power board ETXMM002A2B (120 V)
The Panasonic FZ-10 has electrolytic capacitors on two boards: a switch-mode power board, which differs by region, and the main board, which also carries the CD-ROM drive circuit.[1] The values below come from Panasonic's U.K. parts list, from Console5's lists read off production boards, and from community drawings of the three power boards.[2] The 3DO Development Repo lists failed capacitors as a common fault on all 3DO models.[3]
Before you start
  • Warning: the power board works directly from the mains. Its primary reservoir charges to about 130 V on a 120 V board and about 310 V on a 230–240 V board, and the power switch does not disconnect the primary.[4][5] Unplug the console and let the reservoir discharge, then measure across it before touching the board.
  • Panasonic's service note is to fit the power board's cover over it while working on the main board.[1]
  • Read the power board number before ordering parts. The primary reservoir differs between regions and a 200 V part on a 230–240 V board will fail.
Power board
Power board electrolytics by region
Ref (120 V and Japan) Ref (230–240 V) Capacitance Voltage
C003 – 150 µF 200 V
– C007 47 µF 400 V
– C009 33 µF 35 V
C101 C101 560 µF 25 V
C102 C102 1000 µF 25 V
C103 C103 470 µF 25 V
The 120 V board ETXMM002A2B and the Japanese board ETXMM002J2B use a 150 µF, 200 V reservoir, C003, on the rectified mains (about 130 V).[4][6][2] The 230–240 V board ETXMM002E2B uses a 47 µF, 400 V reservoir, C007, at about 310 V, and a 33 µF, 35 V capacitor, C009, on the control side; Panasonic's U.K. parts list and the community drawing agree on both.[1][5] On all three boards C101 (560 µF) filters the +9 V output, and C102 (1000 µF) and C103 (470 µF) sit either side of the choke L102 on the +5 V output.[4][5]
Main board DFUP0714ZA (ANVIL)
Panasonic's U.K. parts list and Console5's list for board DFUP0714ZA M2 give the same 35 values.[1][2]
Main board electrolytics, DFUP0714ZA
Ref Capacitance Voltage
C104, C201, C203, C274, C304, C522, C732, C743, C760 100 µF 16 V
C128 220 µF 25 V
C142, C647, C703 100 µF 6.3 V
C161 330 µF 10 V
C181, C183 470 µF 6.3 V
C184 470 µF 4 V
C182, C720 22 µF 50 V
C202, C272 10 µF 50 V
C220, C223, C230, C233, C244, C401 47 µF 35 V
C273 470 µF 10 V
C280, C281 10 µF 25 V
C420, C521, C523 1000 µF 10 V
C721 2.2 µF 50 V
C726 1 µF 50 V
[1][2]
Main board DFUP0678ZA
No Panasonic parts list for this board is hosted here. Console5 gives these 32 values.[2]
Main board electrolytics, DFUP0678ZA M4 (Console5)
C104, C124, C164, C201, C203, C273, C274, C522, C732, C743, C760 100 µF 16 V
C144, C304, C647, C703 100 µF 6.3 V
C148, C223, C233, C244 47 µF 35 V
C181, C183, C521 470 µF 6.3 V
C184 470 µF 4 V
C272, C401 10 µF 50 V
C420 1000 µF 10 V
C721 2.2 µF 50 V
C726 1 µF 50 V
[2]
Low-profile parts
Console5 notes that Panasonic used a few low capacitors (under 9 mm tall) on the FZ-10 main boards. Standard heights fit in most positions; C703 is the one Console5 marks as needing a short part.[2]
Procedure
  1. Unplug the console, discharge and check the power board as above.
  2. Remove the top case, the traverse unit and the power board, then the main board, in the order on the Panasonic FZ-10 General Maintenance page.[1]
  3. Read the board numbers and choose the matching list.
  4. Note the polarity of each capacitor before removing it, and inspect the board under any that have leaked.
  5. Fit parts of the same capacitance, at least the same voltage rating, and no taller than the original where Console5 marks a short part.
  6. Refit the power board and check the outputs at CN101 before connecting the main board: +9 V on pins 1–3 and +5 V on pins 13–17, with ground on pins 4–12. The drawings give 9.1 V and 5.0 V measured on the 230–240 V board.[4][5]
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 Matsushita Electric Industrial Co., Service Manual: 3DO Interactive Multiplayer FZ-10, order no. IMD9504003C2, area [E] (U.K.): general description p. 1-1; replacement parts list, main logic PCB and power PCB, pp. 3-19 to 3-25. Hosted here as File:Panasonic FZ-10 Service Manual IMD9504003C2.pdf; see Panasonic FZ-10 Documentation.
  2. ↑ 2.0 2.1 2.2 2.3 2.4 2.5 2.6 Panasonic 3DO FZ-10, Console5 TechWiki—link(accessed 2026-10-01) Capacitor lists for power board ETXMM002A2B and main boards DFUP0678ZA M4 and DFUP0714ZA M2, with a note on low-profile parts. Secondary source.
  3. ↑ General Hardware Repair and Maintenance, 3DO Development Repo, 7 November 2022—link(accessed 2026-10-01) Section "Common Failures", all 3DO models.
  4. ↑ 4.0 4.1 4.2 4.3 Panasonic 3DO FZ-10 POWER SUPPLY (120V, 30W) schematic diagram, ETXMM002A2B, NPX002A2-1B, one sheet. Community redrawing (credited to "Tristrams" by Console5), from the 3DO Development Repo; not a Panasonic document. Hosted here as File:Panasonic FZ-10 Power Supply ETXMM002A2B Schematic.pdf.
  5. ↑ 5.0 5.1 5.2 5.3 Panasonic 3DO FZ-10 POWER SUPPLY (230-240V, 30W) schematic diagram, ETXMM002E2B, NPX002E2-1A, one sheet. Community redrawing from the 3DO Development Repo; not a Panasonic document. Hosted here as File:Panasonic FZ-10 Power Supply ETXMM002E2B Schematic.pdf.
  6. ↑ Panasonic 3DO FZ-10 power supply schematic diagram, ETXMM002J2B, NPX002J2-1B, one sheet. Community redrawing from the 3DO Development Repo. Hosted here as File:Panasonic FZ-10 Power Supply ETXMM002J2B Schematic.pdf.
