Panasonic FZ-10 General Maintenance
Panasonic FZ-10
The Panasonic FZ-10 comes apart in a fixed order: top case, traverse unit, power board, then main board. The order, the service notes and the part numbers below are from Panasonic's U.K. service manual, IMD9504003C2.[1]
Safety
  • Warning: the power board runs from the mains, with its reservoir at about 130 V (120 V boards) or about 310 V (230–240 V boards). The power switch acts on the control side, so the primary is live whenever the lead is plugged in.[2][3] Unplug the console and let the board discharge.
  • Fit the power board cover while working on the main board, and keep clear of the metal parts of the power section.[1]
  • Replace the mains fuse only with the same type, 2 A, 250 V.[1]
Disassembly
Before starting, remove any disc, switch off, unplug the mains lead and remove any optional units. Panasonic warns against interchanging screws between parts of the console.[1]
Top case
  1. Turn the console upside down.
  2. Remove the seven screws A.
  3. Turn it back over and lift the top case off.
Traverse unit
  1. Push the two pins B out from underneath.
  2. Remove the traverse cover.
  3. Raise the traverse unit and unplug its five connectors, including CN760 and CN762, then lift it out.
Power board
  1. Remove the power board cover.
  2. Release the four hooks C and remove the AC inlet and the power switch.
  3. Remove the two screws D.
  4. Unplug CN101 and lift the power board out.
Main board
  1. With the top case and traverse unit off, remove the LED guide panel.
  2. Remove the five screws E and the upper shield plate.
  3. Remove the FMV cover on the right side.
  4. Remove the two screws F.
  5. Unplug CN420 and lift the main board out.
The CD panel comes off after releasing its two hooks G and removing the lid's hop-up spring and oil damper. The part Panasonic calls the DC latch comes off after releasing two hooks H.[1]
Reassemble in the reverse order.[1]
Service notes
  • To play a disc with the lid open, tape down the lid switch SW720.[1]
  • When measuring the waveforms Panasonic marks on its schematics, measure from the underside of the assembled unit.[1]
  • Panasonic's service tools for the FZ-10 were an extension flat cable for the power supply (DFWV95C0103), an FZ-10 checker with manual (DFWV95C0104) and its cable (DFWV95C0105), a traverse platform for working under the traverse (DFWV95C0106) and a set of extension cables (DFWV95C0107 to DFWV95C0111).[1]
Laser and drive
The laser diode is sensitive to static. Wear an anti-static wrist strap, work on a conductive sheet, keep clothing away from the pickup and leave its shorting point bridged while it is out. Do not touch the lens or turn the laser power preset.[1] The 3DO Development Repo notes that a dirty lens can be cleaned but a fogged or scratched one needs a new pickup, and that setting the laser current needs an oscilloscope.[4] The laser is the Sanyo SF-92.5 in its short-wire version.[5] A printed replacement for a CD-ROM pin of the FZ-10 is published on Thingiverse, and a printed AV expansion door is published on Printables.[6][7]
Back-up cell
Saved games are held in 32 KB of SRAM backed by a 3 V lithium cell, BT400, which the U.K. parts list gives as a CR2032.[1] Check it and the board around it for corrosion whenever the console is open; see Battery Explosion, Capacitor or Corrosion Damage.
Checks while the console is open
  • Look for leaking or bulging electrolytics on both boards. Values for each board are on the Panasonic FZ-10 Capacitor Replacement Guide.
  • Check the joints on the video and audio sockets; cracked joints give a picture on some outputs only.[4]
  • Clean the expansion port contacts; a dirty port causes failures with an XPort optical drive emulator.[4]
  • With the power board refitted and the main board unplugged, check +9 V on CN101 pins 1–3 and +5 V on pins 13–17.[2][3]
  1. ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 Matsushita Electric Industrial Co., Service Manual: 3DO Interactive Multiplayer FZ-10, order no. IMD9504003C2, area [E] (U.K.): handling precautions 2-1, disassembly 2-2, service notes 3-4, service tools 3-5, replacement parts list 3-7. Hosted here as File:Panasonic FZ-10 Service Manual IMD9504003C2.pdf; see Panasonic FZ-10 Documentation.
  2. ↑ 2.0 2.1 Panasonic 3DO FZ-10 POWER SUPPLY (120V, 30W) schematic diagram, ETXMM002A2B, NPX002A2-1B, one sheet. Community redrawing from the 3DO Development Repo; not a Panasonic document. Hosted here as File:Panasonic FZ-10 Power Supply ETXMM002A2B Schematic.pdf.
  3. ↑ 3.0 3.1 Panasonic 3DO FZ-10 POWER SUPPLY (230-240V, 30W) schematic diagram, ETXMM002E2B, NPX002E2-1A, one sheet. Community redrawing from the 3DO Development Repo; not a Panasonic document. Hosted here as File:Panasonic FZ-10 Power Supply ETXMM002E2B Schematic.pdf.
  4. ↑ 4.0 4.1 4.2 General Hardware Repair and Maintenance, 3DO Development Repo, 7 November 2022—link(accessed 2026-10-01) Community repair notes.
  5. ↑ Panasonic 3DO FZ-10, Console5 TechWiki—link(accessed 2026-10-01) Laser type, test points and capacitor lists. Secondary source.
  6. ↑ Internet Archive copy of Thingiverse thing 5323820, "Panasonic 3DO FZ-10 CD-ROM pin replacement". Searched 1 October 2026.
  7. ↑ 3DO Mods Wiki, ConsoleMods Wiki, 11 July 2026—link(accessed 2026-10-01) "3D Printables" list, including the FZ-10 AV expansion door.
