Macintosh Performa 5400CD
(Redirected from Performa 5430)
ReleasedApril 22, 1996
DiscontinuedFebruary 1, 1997
CPUPowerPC 603e @ 120 MHz
Memory16 MB RAM (expandable to 136 MB)
Storage1.6 GB IDE hard drive, 4X CD-ROM
Display15" shadow mask CRT (640ร—480 16-bit, 832ร—624 8-bit)
Sound16-bit stereo output and stereo input port; built-in mono microphone
Dimensions17.5" H ร— 16.0" W ร— 15.1" D (445 ร— 406 ร— 383 mm)
Weight17 lb without CD-ROM, 19 lb with CD-ROM (Apple)
OS / FirmwareSystem 7.5.3 โ€“ Mac OS 9.1
PredecessorPerforma 5300
SuccessorPerforma 5500
CodenameAlchemy, Excalibur
The Macintosh Performa 5400CD is an all-in-one personal computer released by Apple Computer on April 22, 1996.[1] Based on the Alchemy architecture, it was the consumer version of the Power Macintosh 5400 educational line. The Performa 5400 series was the last of Apple's 5xxx all-in-one Macintosh computers before the transition to the Performa 5500 series.
The 5400CD featured a 120 MHz PowerPC 603e processor in the same case design as the earlier Performa 5200, but with substantial internal improvements including the first use of 168-pin DIMM memory sockets and a PCI expansion slot in the LC line.[2]
Model Variants
The Performa 5400 series includes several regional and speed variants sharing the same Alchemy logic board:
Model CPU Speed CD-ROM RAM HDD Case Region
Performa 5400CD 120 MHz 4X 16 MB 1.6 GB Platinum Worldwide
Performa 5410CD 120 MHz 4X 16 MB 1.6 GB Platinum Europe
Performa 5420CD 120 MHz 4X 16 MB 1.6 GB Platinum Asia
Performa 5400/160 160 MHz 8X 16 MB 1.6 GB Platinum Europe/Asia
Performa 5430 160 MHz 8X 16 MB 1.6 GB Platinum Europe
Performa 5440 180 MHz 8X 16 MB 1.6 GB Black Europe/Asia
The educational versions were sold as the Power Macintosh 5400/120, 5400/160, and 5400/180 in North America.
Processor
The Performa 5400CD uses a PowerPC 603e processor running at 120 MHz on a 40 MHz system bus.[3] The 603e is a 32-bit processor with a 64-bit data path and integrated floating-point unit. Higher-speed variants used 160 MHz or 180 MHz versions of the same processor.
Cache
The processor includes 32 KB of L1 cache (16 KB instruction, 16 KB data). Level 2 cache is an optional 256K module on a 160-pin DIMM card; Apple gives 512K of Level 2 cache as standard only on the 5500/275.[4]
Memory and Storage
RAM Configuration
The Performa 5400 series uses 168-pin DIMM modules, the first use of this memory type in the LC line. Apple gives 8 MB of DRAM soldered on the board for the 5400/120, 8 or 16 MB for the 5400/180 and 16 MB for the 5400/160 and 5420/180, each expandable to 136 MB in two JEDEC-standard DIMM sockets. The DIMM specification is not the same across the range — see below.[4]
Video RAM
1 MB of system RAM is dedicated to video function. This VRAM allocation cannot be expanded.
Storage Systems
The base 5400CD includes a 1.6 GB IDE hard drive and 4X CD-ROM. Later models shipped with 8X CD-ROM drives. A 1.44 MB manual-eject floppy drive is standard. External SCSI devices are supported via the DB-25 SCSI port.
Display and Graphics
The built-in 15" shadow mask CRT supports:
  • 640ร—480 at 16-bit colour, 67 Hz or 60 Hz (VGA)
  • 800ร—600 at 16-bit colour, 60 Hz or 72 Hz
  • 832ร—624 at 8-bit colour at 75 Hz — this mode does not support video input
Apple lists no 1024ร—768 mode for the 5400 series; that mode belongs to the 6360 and the 6400. Mirroring to an external display needs the optional video connector kit for the DB-15 mirror-out port, and Apple notes the external display is presentation only — it cannot be driven by the mouse.[4]
Audio Capabilities
Apple's specification for the 5400 series gives:
  • Two stereophonic sound output ports, level nominally 0.5 V RMS into 39 ohms — one front
 headphone jack, one rear stereo mini phone jack
  • A stereo sound input port, which supports the Apple PlainTalk Microphone and a standard
 stereo miniplug-to-RCA adapter, and does not support the Apple Omni microphone or the
 attenuated RCA adapter shipped with some models
  • A built-in microphone, which is monophonic
  • Internal stereo speakers capable of 8-bit and 16-bit stereo sound
SRS surround-sound mode belongs to the 5500, not the 5400. Apple's Speaker entry splits the two explicitly, giving the 5500 "SRS surround-sound mode" and the 5400 series plain 8-bit and 16-bit stereo.[4]
Input/Output and Expansion
Port Configuration
  • 1ร— ADB port (keyboard and mouse)
  • 2ร— GeoPort serial ports (modem and printer, Mini DIN-8)
  • 1ร— DB-25 SCSI port (external devices)
  • Ethernet or a modem by way of the communications slot — Apple's specification gives one slot for an optional modem or Ethernet card, not built-in Ethernet
  • 3.5mm stereo audio output
  • 3.5mm mono audio input
Expansion Slots
The Alchemy logic board includes:
  • 1ร— PCI expansion slot, 32-bit PCI bus, for 7-inch cards; NuBus cards cannot be used in it
  • 1ร— communications slot for an optional modem or Ethernet card (PCI-bus configuration)
  • 1ร— 60-pin video-in slot (Digital Audio Video, DAV). Apple warns that the 5400's video input
 card is not compatible with the DAV slot in the Quadra 660AV/840AV or the Power Macintosh
 6100/7100/8100, and that an adapter cable is needed to use Power Macintosh 5200/6200 cards
  • 1ร— optional internal TV/FM tuner
For detailed maintenance practices including cleaning, PRAM battery management, connector corrosion prevention, and voltage adjustments, refer to the dedicated Macintosh Performa 5400 General Maintenance page.
Apple Service Manual
The Performa 5400 series shares service documentation with the Power Macintosh 5400 line.
Detailed capacitor replacement guidelines for the logic board can be found on the Macintosh Performa 5400 Capacitor Replacement Guide page.
Retrobrite
To address plastic yellowing (particularly on platinum models), detailed instructions can be found on the Retrobrite page.
A comprehensive troubleshooting guide addressing no power, video issues, intermittent operation, and common failure points is available on the Macintosh Performa 5400 Troubleshooting page.
System Architecture
Sub-system Specification
CPU PowerPC 603e @ 120/160/180 MHz
Bus Speed 40 MHz
Data Path 64-bit
ROM 4 MB
RAM 8โ€“16 MB on board + 2ร— 168-pin DIMM (max 136 MB)
Video 1 MB (from system RAM)
Storage IDE hard drive, ATAPI CD-ROM, 1.44 MB floppy
Expansion 1ร— PCI, Comm slot, Video I/O slot, TV slot
Processor Specifications
Component Specification
CPU PowerPC 603e
Clock Speed 120/160/180 MHz (by model)
L1 Cache 32 KB (16 KB I + 16 KB D)
L2 Cache 256K optional, on a 160-pin DIMM card
FPU Integrated
Data Bus 64-bit
Address Bus 32-bit
Apple service data
Figures in this section are Apple's own, from the Power Macintosh/Performa 5400 and 5500 Series Service Source volume hosted on this wiki.[4]
Item Apple's figure
Line voltage 100โ€“240 VAC, 47โ€“63 Hz
Power 125 W; current 2.5 A maximum for all line and load conditions; 220 W maximum for all line and load conditions
Surge voltage / inrush 300 V rms for 100 ms; peak inrush 40 A pk
Case Height 17.5 in. (445 mm), width 16 in. (406 mm), depth 15.1 in. (383 mm)
Weight Without CD-ROM 17 lb.; with CD-ROM 19 lb. Weight varies with options
Display 15-inch shadow mask, 12.8-inch viewable image; dot pitch 0.28 mm; vertical frequency 66.7 Hz; active raster 9.5 ร— 7.3 in. (240 ร— 185 mm); white point 9,300 K
Sound output Two stereophonic output ports, nominally 0.5 V RMS into 39 ohms; front headphone jack, rear stereo mini phone jack
PRAM battery Verify on the 10 V DC scale with the logic board out; replace below 3.0 V
Apple's weight figure is printed as "19 lb. (21.15 kg)" in three of these volumes. 19 lb is 8.6 kg; 21.15 kg is not a conversion of anything on the page, and 17/19 lb is also what Apple gives for the much smaller LC 630 chassis. The pounds figures are used here and the metric one is not.[4]
Adjustment controls
The 5400/5500 volume's Adjustments chapter is Light Meter Setup, Geometry, Video and Focus — there is no rail-voltage adjustment or tolerance table for this machine. The controls Apple names are VR701 (horizontal shift) with the three-position horizontal centring switch SW701, VR601, and on the CRT video board VR301, VR302 (red gain), VR303 (green gain), VR304 (red bias) and VR305 (green bias). Geometry work is done with the All-White Screen from the Display Service Utility in the Utilities folder of the MacTest Pro CD, using a plastic flat-blade or Phillips tool — Apple warns that metal alignment tools are a shock hazard.[4]
Memory: the DIMM specification changes inside the range
Apple's memory entries are not interchangeable even though the sockets look identical: the 5400/120, 5400/160 and 5400/180 take 168-pin, 70 ns or faster, 2K refresh DIMMs, while the 5400/200 and every 5500 take 168-pin, 60 ns or faster, 2K refresh, 5-volt buffered EDO DIMMs. The 5400 series carries 1 MB of DRAM on board for video support and a 4 MB ROM; Level 2 cache is an optional 256K module on a 160-pin DIMM card (512K on the 5500/275).[4]
  1. โ†‘ Macintosh Performa 5400CD Specs, EveryMac.comโ€”link(accessed 2026-02-10)
  2. โ†‘ Power Macintosh 5400 LC, Apple-History.comโ€”link(accessed 2026-02-10)
  3. โ†‘ Macintosh Performa 5400CD Specs, EveryMac.comโ€”link(accessed 2026-02-10)
  4. โ†‘ 4.0 4.1 4.2 4.3 4.4 4.5 4.6 4.7 Apple Computer, Power Macintosh/Performa 5400 and 5500 Series, Service Source. Hosted here as Power Macintosh/Performa 5400 and 5500 Series Service Source (File:Powermac.perf_5400.5500.pdf). Specifications, Adjustments and Additional Procedures — Battery Verification chapters.
