Related changes
Enter a page name to see changes on pages linked to or from that page. (To see members of a category, enter Category:Name of category). Changes to pages on your Watchlist are in bold.
List of abbreviations:
- N
- This edit created a new page (also see list of new pages)
- m
- This is a minor edit
- b
- This edit was performed by a bot
- (±123)
- The page size changed by this number of bytes
23 September 2026
02:25 | Recommended Tools 2 changes history +7,999 [Josh (2×)] | |||
02:25 (cur | prev) +183 Josh talk contribs (Add a topical image (page had none)) | ||||
02:11 (cur | prev) +7,816 Josh talk contribs (Rewrite and verify every named product: corrected Retro Chip Tester (standalone 8Bit-Museum instrument, not a TL866 add-on) with its real capabilities; corrected ESD mat/strap earthing to require a current-limiting resistor per ANSI/ESD S1.1 (a direct bond to mains earth is dangerous); removed insulated gloves as CRT protection in favour of goggles and the correct discharge tooling; replaced the unsourced 20-50 MHz scope rule with edge-speed reasoning; added sourced solder melting points (Kes...) | ||||
02:15 | Capacitor Failure Symptoms 2 changes history +12,684 [Josh (2×)] | |||
02:15 (cur | prev) −40 Josh talk contribs (Remove self-referential wording per house rule) | ||||
02:07 (cur | prev) +12,724 Josh talk contribs (Rewrite with full citations (Nichicon CAT.8101H hosted here, Vishay 40110, KEMET F3011): corrected 60 Hz hum to twice mains frequency, corrected bulging mechanism to Nichicon gas generation, added missing film/X2 suppression section, added tantalum derating 60-50 percent, added Class II ceramic DC-bias behaviour, replaced Japanese-brand rule with no-datasheet-no-purchase, replaced IPA-only cleanup with Nichicon soap-and-water plus never acidic/alkaline, replaced reforming folklore with Nichic...) | ||||
| 01:36 | Battery Explosion, Capacitor or Corrosion Damage diffhist +12,961 Josh talk contribs (Verification drive: corrected chemistry (Li-SOCl2 half-AA neutralised with bicarbonate not IPA/water; capacitor electrolyte washed not neutralised - no published pH); added cadmium hazard for NiCd; added damaged-cell handling section incl. accurate lithium fire guidance; fixed +5V range 4.75-5.25 V; corrected United Chemi-Con/Nippon Chemi-Con and OS-CON/Panasonic; removed arbitrary '100 ohm' rail threshold and Kapton '400C' claim; added IEC 60086-1 cell designations; all figures now <ref>-cit...) | ||||
22 September 2026
20:00 | Super Famicom Maintenance Guide 2 changes history +10,176 [Josh (2×)] | |||
20:00 (cur | prev) +4,494 Josh talk contribs (Re-cite against Nintendo's own service manual instead of a secondary transcription. TC1 alignment corrected: the manual is PAL-M and specifies 21.453666MHz, not the 21.47727/17.734475 figures a secondary source had substituted. Added Nintendo's colour-fault tree, the GPM board changes, the C67 discharge step and a self-inflicted-faults section) | ||||
19:50 (cur | prev) +5,682 Josh talk contribs (Rebuild: supply is 10V DC 850mA (HVC-002) not 9V, and the barrel polarity was stated backwards; no 3.3V or 12V rail exists (fullsnes); regulator is U12/U9 not IC601; cap table (C59-C60 220uF audio, C67 470uF, C72, C81) fabricated and contradicted the cap guide; controller port is a proprietary 7-pin not mini-DIN. Added Nintendo Control Deck diagnostic table and Multi Out pinout. F1 1.5A confirmed. Cited; Unverified data cleared) | ||||
| N 19:58 | Nintendo Super NES Technical Manual (Playtronic, Rev. 01-94) diffhist +1,941 Josh talk contribs (Documentation page for a hosted but previously orphaned Nintendo service manual - no page linked it and it was not categorised) | ||||
21 September 2026
| 21:53 | Super Famicom Maintenance Guide diffhist +20 Josh talk contribs (Verification drive: flag unverified component data pending check against a primary source) | ||||
| 21:50 | Battery Explosion, Capacitor or Corrosion Damage diffhist +20 Josh talk contribs (Verification drive: flag unverified component data pending check against a primary source) | ||||
