Psion Revo Plus
| Psion product photograph of a German-market Revo Plus; the "16MB" marking is below the screen | |
| Developer | Psion |
| Manufacturer | Psion |
| Type | Clamshell palmtop / PDA |
| Released | September 2000 (Europe) |
| Discontinued | 2003 |
| CPU | ARM710T @ 36 MHz |
| Memory | 16 MB RAM; 8 MB ROM |
| Storage | Internal RAM disk only; no memory card slot |
| Display | 480 × 160 greyscale LCD (16 grey levels), touch-sensitive; no backlight |
| Sound | Loudspeaker |
| Power | 2 × internal AAA NiMH rechargeable cells (700 mAh) |
| Dimensions | 157 mm × 78 mm × 18 mm |
| Weight | 200 g |
| OS / Firmware | EPOC Release 5 (Symbian) |
| Predecessor | Psion Revo |
| Model no. | Rebadged for the United States and Canada as the Diamond Mako |
The Psion Revo Plus is the 16 MB version of the Psion Revo, first released in Europe in September 2000. It has twice the Revo's RAM, a redesigned main board to take the new memory chip, a larger battery, and the Opera web browser and a WAP browser in its software.[1][2] The processor, screen, keyboard and case size are the same as the Revo's.[3][2]
History
Psion released the Revo Plus in Europe in September 2000, about ten months after the Revo.[1][2] SONICblue sold it in the United States and Canada as the Diamond Mako.[2] The Revo line ended in 2003, and its planned successor, codenamed Conan, was never released.[2]
| Item | Specification |
| Processor | ARM710T, 36 MHz |
| ROM | 8 MB |
| RAM | 16 MB |
| Display | 480 × 160, 16 grey levels, touch-sensitive; no backlight |
| Keyboard | 53-key QWERTY |
| Interfaces | Infrared (IrDA); RS-232 serial through the docking station |
| Batteries | Two internal AAA NiMH rechargeable cells, 700 mAh; average run time 14 hours (netogram) |
| Mains adaptor input | 100–240 V AC ±10 %, 50/60 Hz |
| Size and weight | 15.7 × 7.8 × 1.8 cm, 200 g |
| Operating system | EPOC Release 5 |
Differences from the Revo
| Revo | Revo Plus | |
| RAM | 8 MB[4] | 16 MB[3] |
| Cells | 2 × 650 mAh AAA NiMH[4] | 2 × 700 mAh AAA NiMH[1][5] |
| Main board | Original | Redesigned for the new memory chip[1] |
| Software | EPOC Release 5 suite | Adds the Opera web browser and a WAP browser[1] |
| Nameplate | "revo" | "revo PLUS"[1] |
The Revo Plus holds twice the RAM in standby, so it uses more charge while switched off. Kevin Millican estimates about 6 % a day for a Revo Plus or Mako, against 3 % for a Revo.[6]
Battery and charging
The Revo Plus has the same arrangement as the Revo: two AAA NiMH cells soldered to a connector and sealed under the lid nameplate. R3UK's replacement guide was written on a Revo Plus and covers the Revo, Revo Plus and Diamond Mako.[5]
- Use NiMH cells only.[2]
- Avoid starting a charge above about 80 %. The charge controller calibrates from a thermal change at about 84 % of indicated capacity, and a charge started above that point may not switch to trickle charge.[6]
- After a battery replacement or hard reset, charge without interruption from empty to full so that the gauge recalibrates.[2][6]
- The loose-cell fault that affected a small number of early Revos was confined to 8 MB machines.[6]
The procedure is on Psion Revo Battery Replacement.
Psion's Psion Revo Handbook (PDF) covers the Revo's operation, charging, care, troubleshooting and resets, which are the same on the Revo Plus. Its specification appendix gives the 8 MB Revo's figures.[4]
General maintenance
See the Psion Revo Plus General Maintenance guide.
See the Psion Revo Plus Troubleshooting Guide.
Battery replacement
The Revo battery replacement procedure applies to the Revo Plus.[5]
- Psion Revo Plus General Maintenance
- Psion Revo Plus Troubleshooting Guide
- Psion Revo Battery Replacement
- Psion Revo
- Psion Series 5mx
- Battery Refurbishment
- ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 "Psion Revo Plus", Centre for Computing History.
- ↑ 2.0 2.1 2.2 2.3 2.4 2.5 2.6 "Psion Revo", Wikipedia.
- ↑ 3.0 3.1 3.2 "Psion 3mx, Psion 5, Psion 5mx, Psion Revo and Psion Revo Plus specifications", netogram.com, section "Psion Revo Plus".
- ↑ 4.0 4.1 4.2 Psion Computers PLC, Psion Revo Handbook, version 1.1, February 2000, "Specification" (p. 206). Hosted on this wiki as File:Psion Revo Handbook (February 2000).pdf.
- ↑ 5.0 5.1 5.2 David Savery, "Psion Revo/Diamond Mako Disassembly & Battery Replacement", R3UK, 9 August 2004.
- ↑ 6.0 6.1 6.2 6.3 Kevin Millican, "Revo Battery Information", 25 May 2003.
