Sinclair ZX80 Capacitor Replacement Guide
The Sinclair ZX80 has very few capacitors, and only two of them are electrolytic. It is therefore not a "recap on sight" machine in the way that a machine full of low-voltage electrolytics is. The two electrolytics are worth attention on a forty-five-year-old board, and the rest of the board is ceramic and does not normally need to be touched.
Visual inspection and failure signs
edit- Leaking or crusty electrolytics — brown, green or white residue at the base of C8 or C10.
- Bulging or split cans on either of those two parts.
- Machine dead with a cold regulator. If the 7805 (IC22) never warms up, check the supply and C8 before anything else: C8 is the only reservoir between the unregulated input and the regulator.[1]
- No cursor at switch-on, but the screen is otherwise live. The Z80's reset is held by R21 (220 k) charging C10 (1 µF). A failed C10 attacks this directly.[1]
- Horizontal black and white stripes drifting through the picture. Sinclair attributed this to the power supply — either insufficient smoothing or too low an output on load.[2]
Capacitors on the ZX80 board
editSinclair's circuit diagram is the source for the list below.[1] Grant Searle's 2009 vector redraw of the same diagram carries identical designators and values, which is a useful independent check.[3]
| Ref | Value | Type | Where it sits on the diagram |
| C1, C2, C4, C5, C6 | 47 nF | Ceramic | Five decouplers across the regulated +5 V rail at the output of IC22 |
| C8 | 22 µF, 16 V | Electrolytic | Across the unregulated DC input, ahead of the IC22 regulator. The board's only reservoir capacitor |
| C9 | 47 pF | Ceramic | With R2 (470 R) in the ∅2 clock path feeding IC16 |
| C10 | 1 µF | Electrolytic | With R21 (220 k) to +5 V on IC1 (Z80) pin 26, /RESET — the power-on reset network |
| C11 | 47 pF | Ceramic | With R25 (470 R) in the /MREQ timing network feeding IC11 |
| C12 | 47 nF | Ceramic | In series with R29 (180 R) at the EAR socket — the tape input path |
| C13 | 47 nF | Ceramic | In the MIC socket network with R34 (1 k), fed from SYNC |
| C14 | 47 pF | Ceramic | In the same MIC socket network, with R35 (1 M) |
| C15 | 0–330 pF trimmer | Trimmer | In the 6.5 MHz master oscillator round X1, with R27 (1 k) |
There is no C3 and no C7 on the ZX80 circuit diagram. Designators were not reused from a ZX81 or a Spectrum; if your board is silkscreened with a designator not in the list above, work from your own board and post the finding rather than assuming this table is incomplete.
Only C8 and C10 are electrolytic. If you are ordering parts, those are the two to order.
Choosing replacements
edit- C8 — 22 µF at 16 V or higher. The rail it sits on is the raw supply, nominally 9–11 V DC and rising to about 14 V open-circuit, so do not fit anything rated below 16 V.[1][4]
- C10 — 1 µF. It sits on the +5 V rail; 16 V or higher is ample.
- Use 105 °C aluminium electrolytics from a recognised manufacturer. Equal capacitance, equal or higher voltage.
- The ceramics are stable parts and are not a normal service item. Replace one only if it has been physically damaged.
Recapping procedure
edit- Unplug the supply and remove the case screws.
- Free the board. Disconnect the keyboard tails from their connectors. The tails are the most fragile thing in the machine — pull them straight out, never at an angle, and never fold them.[5]
- Note the polarity of C8 and C10 before removing anything. The circuit diagram marks the positive end of both.[1]
- Add fresh flux and solder to the old joints and let it mix before applying wick or a pump. The ZX80 board is single-sided and the pads lift if you work them hot and dry.
- Fit the replacements the right way round. The originals are axial; radial parts are acceptable if you form and sleeve the leads so nothing can short to an adjacent track.
- Clean the flux residue with isopropyl alcohol and a soft brush, then inspect under magnification for splashes and bridges — a hairline solder splash reads as a few ohms and produces very misleading symptoms.[5]
- Reassemble and test.
Checks after the work
editThe ZX80 has a single internal rail. There is no −5 V and no +12 V on this machine — those belong to the ZX Spectrum, whose 4116 RAM needs them.
| Point | Expect | Source |
| Power jack, 3.5 mm, centre pin positive | Nominal 9 V DC unregulated, about 14 V open-circuit; the circuit diagram marks the input "9 V – 11 V" | [1][4] |
| IC22 (7805) output | +5 V | [1] |
| IC1 (Z80) pin 11 Vcc, pin 29 ground | +5 V | [1] |
| IC2 (8332 ROM) pin 24 Vcc, pin 12 ground | +5 V | [1] |
| IC3, IC4 (2114 RAM) pin 18 Vcc, pin 9 ground | +5 V | [1] |
| IC1 (Z80) pin 6 | 3·2 MHz, as Sinclair's diagram labels it — the 6.5 MHz oscillator X1 divided by two, i.e. 3.25 MHz | [1] |
Sinclair did not publish a ripple figure for the ZX80, and none is given here. What the manual for the closely related Sinclair ZX81 does say is that the regulator will not work correctly below about 7 V on load, and that drifting horizontal stripes point at the supply rather than the board.[2]
Tools and materials
editSee Recommended Tools for the general list. For this job specifically:
- Temperature-controlled iron with a fine tip
- Desoldering braid and/or a pump
- 63/37 leaded solder and fresh no-clean or rosin flux
- Two 105 °C electrolytics: 22 µF 16 V (or higher) and 1 µF 16 V (or higher)
- Isopropyl alcohol and a soft antistatic brush
- Heatshrink or sleeving if you are fitting radial parts in axial positions
Notes
edit- Check the power supply before you blame the board. A supply that has been re-terminated with the polarity reversed is a known way to destroy the regulator. On this family the regulator usually takes the hit and protects the rest of the board, but do not rely on that.[5]
- The ZX80 has no ULA. All of its logic is standard 74LS parts; the ULA arrived with the ZX81, which combined them into one chip. Advice written for a ZX81 or a Spectrum does not transfer.[6]
- Clean the edge connector while the board is out. Contact trouble there is a common cause of unreliable behaviour with a RAM pack fitted.
- See Capacitor Failure Symptoms for what failing electrolytics look like in general, and Battery Explosion, Capacitor or Corrosion Damage if there is existing corrosion to deal with.
editReferences
edit- ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 Sinclair Research Ltd, ZX80 Circuit Diagram. Hosted on this wiki as File:Sinclair ZX80 circuit diagram.png. Source for every ZX80 capacitor designator, value, IC type and pin number on this page.
- ↑ 2.0 2.1 Sinclair Research Ltd, ZX81 Service and Assembly Manual, section 6 (fault finding) and section 9 (power supply). Hosted on this wiki as File:Sinclair ZX81 Service and Assembly Manual.pdf. Cited here because Sinclair published no equivalent document for the ZX80 and the two machines share the same external supply arrangement.
- ↑ Grant Searle, ZX80 hardware page, http://searle.x10host.com/zx80/zx80.html — accurately redrawn ZX80 schematic, January 2009. Used here only as independent confirmation of the designators and values on Sinclair's own diagram.
- ↑ 4.0 4.1 Sinclair ZX80 Connectors, The Sinclair ZX Computers Archive, k1.spdns.de. Secondary source: connector types, supply polarity and open-circuit voltage.
- ↑ 5.0 5.1 5.2 "Servicing Sinclair Computers, Part 2", Television magazine, 1986. Trade servicing article covering the ZX80/ZX81 family; mirrored in the Sinclair ZX Computers Archive at k1.spdns.de. Secondary source, used here for handling practice, keyboard tails and solder-splash faults.
- ↑ Differences between ZX80, ZX81 and Timex 1000, The Sinclair ZX Computers Archive, k1.spdns.de. Secondary source: the ZX80's standard TTL logic was combined into a single ULA for the ZX81.
