Power Macintosh 6300
Revision as of 14:13, 27 September 2026 by Josh (talk | contribs) (Red-link sweep: retarget delegation links to the pages that actually exist (LC 550/LC 580/Performa 6100 sub-pages do not, the Performa 550/580 and Power Macintosh 6100 ones do), fix the malformed 'Macintosh Power Macintosh 5400' title, and de-link targets with no page)
The Power Macintosh 6300 is a personal computer introduced by Apple Computer on June 27, 1996.[1] It uses the compact desktop case design of the Macintosh Quadra 630 and features a PowerPC 603e processor. The Power Macintosh 6300 was sold primarily in Asia, while the consumer version—the Performa 6320CD—was sold worldwide with an additional TV/video system.
TypePersonal Computer
ReleasedJune 27, 1996
DiscontinuedJuly 1, 1997
Intro priceAsia only
CPUPowerPC 603e @ 100–120 MHz
Memory16 MB RAM (expandable to 64 MB)
Storage1.2 GB IDE hard drive, 1.44 MB floppy, 4X CD-ROM
DisplayDB-15 video out: 640×480 16-bit, 800×600 8-bit, 832×624 8-bit
Sound16-bit mono input, 16-bit stereo output
Dimensions4.3" H × 16.5" W × 12.6" D (10.95 × 41.95 × 32 cm)
Weight19.0 lbs (8.6 kg)
OS / FirmwareMac OS 7.5.1 – 9.1
PredecessorPower Macintosh 6200
Model no.M3076
Model Variants
Model Processor Standard RAM Hard Drive CD-ROM
6300/100 100 MHz 16 MB 1.2 GB 4X
6300/120 120 MHz 16 MB 1.2 GB 4X
  • Processor: PowerPC 603e
  • Clock Speed: 100 MHz or 120 MHz
  • Architecture: 32-bit processor with 64-bit data path
  • FPU: Integrated
  • System Bus: 40 MHz
  • L1 Cache: 32 KB
  • L2 Cache: 256 KB
  • ROM: 4 MB
Memory and Storage
  • RAM Type: 72-pin SIMM (80 ns minimum)
  • RAM Slots: 2
  • Standard RAM: 16 MB
  • Maximum RAM: 64 MB
  • Hard Drive: 1.2 GB IDE
  • Floppy Drive: 1.44 MB 3.5"
  • CD-ROM: 4X
Display and Graphics
  • Resolution: 640×480 (16-bit), 800×600 and 832×624 (8-bit)
  • Video RAM: 1 MB (from system RAM)
Input/Output and Expansion
  • LC PDS Slot: 1
  • Comm Slot: 1
  • Video I/O Slots: Input and output
  • TV Tuner Slot: 1
  • Serial Ports: 2
  • Ethernet: 10Base-T (optional)
Power
  • Input: 100V–240V AC, 50–60 Hz
  • Maximum Power: 55 Watts
For detailed maintenance information, refer to the Macintosh Performa 6300CD General Maintenance page.
See the Macintosh Performa 6300CD Troubleshooting page.
See the Macintosh Performa 6300CD Capacitor Replacement Guide page.
Full technical specifications are available on the Power Macintosh 6300 Specifications page.
Apple service data
Apple's own figures for this family, from the Performa 6200/6300 Series Service Source volume hosted on this wiki.[2]
Item Apple's figure (6200/6300 series except 6360)
Case Height 4.3 in. (10.95 cm), width 16.5 in. (41.95 cm), depth 12.6 in. (32 cm)
Weight Without CD-ROM 17 lb. (7.7 kg); with CD-ROM 19 lb. (8.6 kg)
Line voltage 100–240 VAC, 47–63 Hz (Performa 6360: 90–270 VAC, 43–67 Hz)
Power 125 W; 2.5 A maximum and 220 W maximum for all line and load conditions (6360: 150 W)
Level 2 cache 256K, standard across the series
ROM / video 4 MB ROM; 1 MB of DRAM on board for video support
Sound 16-bit monophonic sound input — the port accepts a stereo signal but combines it to mono for play-through or recording — and 16-bit stereophonic output, nominally 0.5 V RMS into 39 ohms, on two ports (front headphone jack, rear stereo mini phone jack). The internal speaker is muted when a plug is inserted in an output jack
Slots Processor-direct slot 96/114-pin (not fitted on the 6360); communications slot 112-pin; video-in slot 60-pin; TV tuner port 10-pin
SCSI / ADB One external DB-25 SCSI port, up to seven devices; one ADB port, mini DIN-4
PRAM battery Apple's symptom chart calls it a 4.5 V battery; verify it on the 10 V DC scale with the logic board removed and replace below 3.0 V
The Performa 6360 is the exception on almost every line. Apple gives it 16-bit stereophonic input and output with SRS 3D Surround Sound, a sound-input connector at line level 2 Vpp maximum into 10 kilohms and an output at 2 Vpp maximum into 32 ohms, one built-in speaker rather than two, one 6.88-inch PCI slot in place of the processor-direct slot, GeoPort-compatible serial ports, and memory in two 168-pin, 70 ns DIMM sockets expandable to 136 MB where the rest of the family uses two 72-pin, 80 ns SIMM sockets to 64 MB.[2]
Two things in this volume are Apple's own errors and are not repeated here: a "Video Screen: 15-inch 0.28 mm dot-pitch CRT" entry, which belongs to the 5200-series all-in-one and not to a desktop machine, and the battery instruction printed as "Unplug 4.5 V battery" in this volume but as "Unplug 5.4 battery" in the 630-series volumes for the identical step.[2]
  1. ↑ Power Macintosh 6300/120 Specs, EveryMac.com—link(accessed 2026-02-10)
  2. ↑ 2.0 2.1 2.2 Apple Computer, Performa 6200/6300 Series, Service Source. Hosted here as Performa 6200/6300 Series Service Source (File:Performa_6200.6300.pdf). Specifications and Additional Procedures — Battery Verification chapters.
