Sega Dreamcast Maintenance Guide
Routine care for a Sega Dreamcast. The machine is now old enough that its supply, its optical drive and its connectors all need attention, and two of the three are straightforward work.
Sega Dreamcast
Sega's power supply schematic, 837-13570. CN3, bottom right, is the output header: 12 V, GND, GND, GND, 5 V, 3.3 V.
Every Dreamcast has an internal, mains-powered supply and a GD-ROM drive. There is no revision that takes an external power brick, and none that omits the optical drive. Sega's own block diagram shows the supply taking mains in and producing 3.3 V, 5 V and 12 V, with the GD-ROM fed from the 12 V and 5 V rails;[1] console5 lists internal supply boards for both 110 V and 220–240 V markets and for every logic-board revision.[2]
Before you open it
The supply board carries mains potential, and its bulk capacitor holds charge after the lead is pulled — 100 µF at 200 V on 110 V machines, 47 µF at 400 V on 220–240 V machines.[2] Unplug the console, measure across that capacitor, and discharge it through a resistor before touching the board. Mains tracks are what can kill you and stored charge is what can hurt you; with both dealt with, servicing the supply is ordinary work, and on a machine of this age it is usually the single most useful thing you can do.
Strip-down
  1. Unplug everything and remove the modem or broadband adapter from the rear bay.
  2. Remove the case screws from the underside and lift the top shell.
  3. The optical drive, the supply board and the controller interface board all unplug; note the orientation of each connector before you pull it.
  4. Shield plates sit over the logic board. Note which way round they go — they are part of how the machine produces a clean picture.
Sega's exploded view for the VA0 machine shows the assembly order and carries one servicing note that is easy to lose: Molycoat is applied to the angled surface of the boss on the underside of the Open button.[3] A lid that has become stiff usually wants grease there rather than force.
Cleaning
  • Case and vents. A damp microfibre cloth; a soft brush or dry air through the vent slots and the fan grille. Nothing abrasive.
  • Inside. Dry air and an anti-static brush over the logic board, the supply and around the drive.
  • Lens. A cotton swab barely damp with isopropyl alcohol, wiped gently outwards. Let it dry before the lid is closed.
  • Controller ports and the expansion bay. Isopropyl alcohol on a swab, dried fully before power is applied.
  • Sled rails. Remove old thickened grease before applying new; mixing the two makes the sled worse.
Rails to check
Sega's block diagram gives the supply outputs, and the power supply schematic gives the output connector's pin order.[1][4]
CN3, the supply output header
Pin Rail Feeds
1 +12 V GD-ROM drive
2, 3, 4 GND Reference
5 +5 V GD-ROM drive; the G1 bus is 5 V tolerant
6 +3.3 V The logic board, and the input to both core regulators
Two further rails are generated on the logic board and are not present at CN3: 2.0 V for the SH-4 core and 2.5 V for HOLLY, both derived from the 3.3 V rail.[1] If 3.3 V is missing or sagging, both cores lose their supply and the machine will not come out of reset — Sega's reset diagram makes that explicit, since SRST is released only after the supply has been stable for a minimum of 300 ms.[1]
This wiki has not found a published tolerance band for the Dreamcast's rails, so none is quoted here. Measure the three at CN3 against their nominal values, and treat a rail that is visibly low or noisy on a scope as the fault.
Capacitors
Four separate boards carry electrolytics — the logic board, the supply, the GD-ROM optical board and the small controller-interface board — and they do not share a designator series. On the logic board, electrolytics are CE parts and plain C numbers are ceramics or unfitted positions.[5]
Full lists by board and revision are on Sega Dreamcast Capacitor Replacement Guide; what each failure mode looks like is on Capacitor Failure Symptoms; cleaning up after a leak is on Battery Explosion, Capacitor or Corrosion Damage.
Two things worth knowing before you order parts:
  • CE303 and CE304 on the logic board are bipolar. They must be replaced with bipolar parts, not with ordinary polarised electrolytics fitted "the right way round".[2]
  • The supply is where most of the capacitance is, and Sega's own schematic gives its values: C3, C10, C13, C16, C17, C20, C21 and C22.[4]
The GD-ROM drive
Before suspecting the laser at all:
  • Clean the lens, gently.
  • Check the sled moves freely along its rails, by hand, with the power off.
  • Check the spur gears. console5 records the plastic gears in the optical drive stripping, which stops the sled moving and produces a drive that spins a disc but never reads it; replacement gears exist.[2] That fault looks exactly like a dead laser and is not one.
  • Check the ribbon between the drive and the logic board.
The drive is a CAV mechanism running between 4× and 12×, with its own 33.8688 MHz clock, and it takes both 12 V and 5 V.[1] A drive that does nothing at all is worth checking for a missing 12 V rail before anything else.
There is no published Sega procedure here for adjusting the Dreamcast's laser, and no figure for how far a trimmer may be moved, so none is given. Turning the pot on a worn pickup shortens what life it has left; fit a known-good drive, or an optical drive emulator, instead.
The real-time clock cell
Sega's block diagram shows a 3 V lithium cell holding up the real-time clock, which lives inside the AICA; the schematic shows the AICA's VCC (RTC) pin fed from a separate net labelled B.VCC.[1][5] A Dreamcast that asks for the date and time at every boot has a flat cell, not a board fault.
The cell is soldered in place on the controller-interface board. This wiki has not found a manufacturer source naming the exact part or stating whether the position is charged in service, so no part number is given here. Before fitting a replacement, establish which it is on your own machine: a non-rechargeable cell soldered into a charging position is a genuine hazard, and the two cell types look identical. Fitting a holder at the same time makes the next replacement a two-minute job.
Connectors
Poor contact accounts for a large share of intermittent Dreamcast faults. Worth inspecting, cleaning and reseating:
  • the supply-to-logic-board connector — the usual culprit for resets and no-boot;
  • the controller ports, on the small interface board that also carries the clock cell and one 47 µF 16 V capacitor at CE1;[2]
  • the AV connector, CN602 (Sega part 212-5710), which is held only by its own solder joints;[5]
  • the GD-ROM ribbon;
  • the fan and speaker leads;
  • the expansion bay for the modem or broadband adapter.
Clean with isopropyl alcohol and reseat. If a connector's joints are cracked, reflow them rather than adding more contact cleaner.
Cooling
The Dreamcast relies on one small fan and a passive heatsink. Keep the vents and the grille clear, and do not box the console in.
If the fan is noisy or has stopped, measure the voltage at its own connector before buying a replacement — the machine has 12 V, 5 V and 3.3 V available and this wiki has not established which the fan runs from, so the figure on the box you order should come from your meter, not from a guess.
Preventive schedule
  1. Check the three rails at CN3 after any long period in storage.
  2. Clean the vents, the grille and the heatsink every six to twelve months.
  3. Clean the controller ports and the expansion bay contacts annually.
  4. Inspect the supply board's capacitors, and replace them if they show any sign of age.
  5. Clean the lens and check the sled and its gears when read errors appear — before assuming the pickup is dead.
  6. Replace the clock cell when the machine starts forgetting the time, after establishing whether the position is charged.
  7. Reseat the supply-to-logic-board connector whenever the case is open.
  1. 1.0 1.1 1.2 1.3 1.4 1.5 Dreamcast Block Diagram (sheet 7-1), Dreamcast Clock Diagram (sheet 7-2) and Dreamcast Reset Diagram (sheet 7-3), Sega Enterprises, Ltd. Hosted on this wiki — see Sega Dreamcast VA0 Schematics. Source for the power supply input of 100–125 VAC at 50/60 Hz and its 3.3 V, 5 V and 12 V outputs; for the two on-board regulator blocks, "1.8/3.3" fed from 3.3 V producing 2.0 V for the SH4 and "2.5/3.3" fed from 3.3 V producing 2.5 V for HOLLY; for the 13.5 MHz PLL reference giving 33.33 MHz to the SH4 and the 54 MHz pixel clock to HOLLY; for the CAV 4× to 12× GD-ROM drive fed with 12 V and 5 V and clocked internally at 33.8688 MHz; for the 32.768 kHz real-time clock and its 3 V lithium cell; and for the reset sequence — "SRST becomes active after power has stabilized for a minimum of 300mS", after which HOLLY releases the SH4 and issues GRESETN to the AICA, the GD-ROM decoder and the expansion connector.
  2. 2.0 2.1 2.2 2.3 2.4 console5 TechWiki, Dreamcast, https://wiki.console5.com/wiki/Dreamcast . Secondary source — capacitor lists read off real boards for the VA0, VA1 and VA2.1 logic boards, the GD-ROM optical boards, the controller interface board and the power supply units, together with the IC map for the VA1 171-7965C board. Source for the supply board numbers 171-7874A, -7874A-X1, -7874B and -7874B-X2, 171-7962A and -7962A-X1 and 171-7970A and -7970A-X2 for 110 V markets and 171-7960A, PWR UNIT PANA EU V01 and ETXSE239E2C for 220–240 V markets; for the bulk capacitor being 100 µF 200 V on 110 V units and 47 µF 400 V on 220–240 V units; for the FA5317 switching controller; for the stripped optical-drive spur gears and the availability of replacements; and for the single 47 µF 16 V capacitor at CE1 on the controller interface board.
  3. Exploded View & Parts Lists VA0, sheet 12-1, Sega Enterprises, Ltd. — hosted on this wiki as File:Sega Dreamcast Exploded View.pdf (see Sega Dreamcast VA0 Schematics). A mechanical assembly drawing of a VA0 console with item numbers for the case, lid, GD-ROM drive, logic board, supply board, fan, shields and modem bay, carrying Sega's note that Molycoat (item 1-101) is applied to the angled surface of the boss on the under side of the Open button. The numbered parts list the sheet refers to is not part of the hosted scan.
  4. 4.0 4.1 Dreamcast power supply schematic, marked "COD. SEGA 837-13570", Sega Enterprises, Ltd. — hosted on this wiki as File:Sega Dreamcast Power Supply Schematic.pdf. A complete component-level sheet: mains inlet CN1, fuse F1 1.6 A, X-capacitor C1 68 nF 275 VAC with bleeder R2 270 kΩ, common-mode chokes L1 and L3, power switch CN2, bridge rectifier RC1 (S1NB60), bulk capacitor C3 68 µF 400 V, controller M1 (FA5317), switching MOSFET Q1 (P5NA80) with sense resistor R3 0.2 Ω, transformer T1 (28-8258), optocoupler PI1 (P521) and reference M4 (C1944T); on the secondary, the 12 V rail through RC2, C13 1000 µF 25 V, series pass Q2 (2SD1856) with zener D4 15 V, to C16 220 µF 25 V; the 5 V rail through RC3, C17 2200 µF 10 V, series pass Q4 (2SC4596) regulated by M3 (C1093T) with divider R22/R21, to C20 1500 µF 6.3 V; and the 3.3 V rail through RC4, C21 2200 µF 10 V, choke L2 6.8 µH, to C22 470 µF 10 V. The output connector CN3 is a six-way header in the order 12 V, GND, GND, GND, 5 V, 3.3 V.
  5. 5.0 5.1 5.2 Sega Dreamcast VA0 logic-board schematic sheets, Sega Enterprises, Ltd., hosted on this wiki — see Sega Dreamcast VA0 Schematics. Source for the designator convention on the logic board, where electrolytics carry CE numbers (CE307 drawn as 22 µF 10 V, CE402 as 47 µF 16 V) and plain C numbers are ceramics or positions marked "(NU)"; and for the device identifications IC301 = 315-6119 (AICA), IC303 = PCM1725, IC305 = BU2179F clock generator with X302 at 13.5 MHz, IC401 = BU1426KS video encoder and X301 = 32.768 kHz.
