Macintosh Performa 588
Revision as of 13:42, 27 September 2026 by Josh (talk | contribs) (Apple Service Source: added Apple's figures - 4 MB on board to 52 MB in two 72-pin SIMM sockets, 1 MB non-expandable VRAM, 11.5-inch viewable image, 120 W / 2.0 A supply on a 90-264 V rms input, 9-pin mini-DIN modem port, 22-pin external video connector, and the 3.0 V lithium PRAM threshold (bicarbonate, not vinegar). Sound is mono in / 8-bit stereo out)
TypeAll-in-one personal computer
ReleasedApril 1, 1995
DiscontinuedMay 1, 1996
Intro pricen/a
CPUMotorola 68LC040 @ 33 MHz
Memory8 MB RAM (4 MB on-board) expandable to 52 MB
Storage500 MB IDE hard drive, 2X CD-ROM drive
DisplayBuilt-in 14" shadow mask CRT, 11.5" viewable (640ร—480, 1 MB VRAM, 16-bit)
SoundMono sound input, 8-bit stereo output; built-in microphone
Dimensions17.9" H ร— 13.5" W ร— 16.5" D (454 ร— 343 ร— 419 mm)
Weight40.5 lbs (18.4 kg)
OS / FirmwareSystem 7.5 โ€“ Mac OS 8.1
PredecessorPerforma 578
SuccessorPerforma 5200CD
Codenamen/a
Model no.M3872
The Macintosh Performa 588 is an alternate name for the Macintosh Performa 588CD, the consumer variant of the Macintosh LC 580 sold exclusively in Europe and Asia.[1] All Performa 588 units shipped with a 2X CD-ROM drive; the "CD" suffix was sometimes omitted in marketing materials.
In Japan, the 588 shipped with KanjiTalk 7.5 for Japanese language support. The model shares its hardware platform with the Macintosh Performa 580CD but was marketed in different regions.
Hardware Overview
The Performa 588 shares its logic board with the Macintosh LC 580 and uses the same LC 630-derived architecture:
  • Processor: Motorola 68LC040 at 33 MHz (no FPU)
  • RAM: 4 MB soldered on-board plus 4 MB SIMM (8 MB total), expandable to 52 MB
  • Storage: 500 MB IDE hard drive, 2X CD-ROM
  • Display: 14" shadow mask CRT (not Sony Trinitron) at 640ร—480
  • Expansion: LC PDS slot, communications slot, video I/O slot
Regional Variants
Region Order Number Notes
Japan M4059J/A KanjiTalk 7.5 pre-installed
Europe Varies Standard System 7.5
Asia Varies Standard System 7.5
For cleaning, PRAM battery care, and preventive maintenance, see Macintosh LC 580 General Maintenance.
The Performa 588 uses the same logic board as the LC 580. For capacitor specifications and replacement procedures, see Macintosh LC 580 Capacitor Replacement Guide.
For diagnostic procedures and common issues, see Macintosh LC 580 Troubleshooting.
Service Documentation
Apple service data
Apple's own figures, from the Macintosh LC 580/Performa 580CD Service Source volume hosted on this wiki.[2]
Item Apple's figure
Processor Motorola 68LC040, 33 MHz, built-in memory management unit
RAM 4 MB on board, expandable to 52 MB in two 72-pin SIMM connectors (fast-page mode, 80 ns)
ROM / PRAM 1 MB ROM; 256 bytes of parameter memory with a long-life lithium battery
VRAM 1 MB of DRAM soldered to the logic board, enough for thousands of colours (16-bit). Not expandable
Display 14-inch diagonal, 11.5-inch viewable image; 0.28 mm dot-pitch shadow mask; vertical frequency 66.7 Hz; active raster 9.5 ร— 7.3 in. (240 ร— 180 mm); white point 9,300 K; shipping brightness 30 ยฑ 5 foot lamberts
Sound Sound-input port for monaural input; sound-output port and headphone jack each capable of 8-bit stereo; integrated stereo speakers; records and plays back at 11 or 22 kHz
Audio amplifier Drives a 16-ohm speaker; audio input 0.707 V rms into 10 kilohms
Serial Two RS-232/RS-422 ports — the modem port is a 9-pin mini-DIN and the printer port an 8-pin mini-DIN
Slots 114-pin processor-direct slot; 112-pin communications slot for a fax modem or Ethernet card; 60-pin video-in slot; a 22-pin external video connector for a second monitor
Power supply 90โ€“264 V rms, 50โ€“60 Hz ยฑ3 Hz, automatically configured; surge 300 V rms for 100 ms; peak inrush 40 A; 2.0 A maximum and 120 W maximum for all line and load conditions
Case Height 17.9 in. (45.5 cm), width 13.5 in. (34.4 cm), depth 16.5 in. (42.0 cm); 40.5 lb. (18.4 kg)
PRAM battery Verify on the 10 V DC scale; replace below 3.0 V. It is a lithium cell, so neutralise any leakage with sodium bicarbonate, never vinegar
Internal video is 640ร—480 only. With the external video connector kit the machine will mirror to 640ร—480 on Apple's 12-inch, Color Plus 14-inch, Performa Plus and Multiple Scan 15/17/20 displays, and to 800ร—600 on the Multiple Scan 15/17/20 and SVGA monitors.[2]
  1. โ†‘ Apple Macintosh Performa 588CD Specs, EveryMac.comโ€”link(accessed 2026-02-10)
  2. โ†‘ 2.0 2.1 Apple Computer, Macintosh LC 580/Performa 580CD, Service Source. Hosted here as Macintosh LC 580/Performa 580CD Service Source (File:Lc_580.performa_580cd.pdf). Specifications and Additional Procedures — Battery Verification chapters.
