Psion Series 3a Service Manual
Revision as of 12:54, 30 September 2026 by Josh (talk | contribs) (New documentation page for the hosted Series 3a Service Manual (June 1996, 6103-0114-01): contents with printed and PDF pages, what it settles, gaps, citing pages)
General assembly exploded view with Psion part numbers (PDF p. 11, printed p. 5).
The Psion Series 3a Service Manual is Psion PLC's service manual for the Psion Series 3a: version 1.0, June 1996, Psion part no. 6103-0114-01, in English. The PDF has 34 pages; the manual's own page numbers start at 1 on the Introduction (PDF p. 7), so printed page numbers are six lower than PDF page numbers. The contents page lists some later sections one or two pages earlier than they appear.[1] Its introduction says it is written for service technicians at third-party or registered Psion service centres.[1]
Contents
Sections of the manual[1]
Section Printed pages PDF pages What it covers
Front matter unnumbered 1-5 Covers, copyright, ESD precautions, FCC and CE information
Introduction 1 7 Purpose of the manual
Circuit description 2-3 8-9 Block diagram; single main PCB with 256K or 512K SRAM, or 1 or 2 MB pseudo-static RAM, and 1 or 2 MB ROM; 7.68 MHz and 32.768 kHz crystals; the ASIC9 (176-pin QFP with V30HL core) and its functions; power supply functions; the daughter PCB
Troubleshooting guide 4 10 Fault, cause and cure table (dead unit, keys, sound, LCD lines, SSD and expansion port faults, constant resets)
Exploded views 5-6 11-12 General assembly and TAB LCD module with Psion part numbers; EMC compliance modifications of November 1995
Spares kits 7-8 13-14 Individual assemblies; language-specific kits; PCB kits by memory size and language, including Acorn Pocket Book II boards
Disassembly 9-13 15-19 Tools, battery and backup cell removal, step-by-step disassembly, keyboard and keymats
Reassembly 13-17 19-23 Hinge pins and springs, battery wire assembly and routing, labels
Final test procedure (version 1.6) 17-23 23-29 Test equipment, explanation of tests, standby and on-and-idle current limits for the Series 3 and 3a, LED summary, test sequence, soak test, software upgrade
Final test unit 24-26 30-32 Test unit hardware and modification history
Warranty 27 33 Manufacturer's warranty
What it settles
  • The current limits used on the wiki's Series 3 and 3a troubleshooting pages: the table on printed p. 19 gives maximum (and typical) standby and on-and-idle currents for the Series 3 and for 256K/512K, 1 MB and 2 MB Series 3a machines.[2]
  • Two LCD versions were fitted, Seiko with positive polarity and Hitachi with negative polarity, and few non-English machines have the Seiko module.[3]
  • Psion recommends replacing the battery wires whenever a machine is taken apart, because they flex every time the case is opened and closed, and gives the routing of the wire through the battery moulding.[4]
  • TAB LCD hinge springs are coloured blue and non-TAB springs black.[5]
What it does not contain
  • No circuit schematic; the circuit description stops at a block diagram
  • No component values, component placement drawing or capacitor list
  • No coverage of the Psion Series 3c or Psion Series 3mx, which followed it; the wiki's 3c and 3mx pages use it only for the shared mechanical procedures
Pages that cite this document
Document
Download: Psion Series 3a Service Manual (June 1996).pdf
See also Psion Series 3a User Guide.
  1. ↑ 1.0 1.1 1.2 Psion PLC, Series 3a Service Manual, version 1.0, June 1996, part no. 6103-0114-01. Hosted on this wiki: File:Psion Series 3a Service Manual (June 1996).pdf. Copyright notice and part number on PDF p. 4; contents on PDF p. 6.
  2. ↑ Series 3a Service Manual, p. 19 (PDF p. 25), "Series 3/3a Current Levels".
  3. ↑ Series 3a Service Manual, p. 6 (PDF p. 12).
  4. ↑ Series 3a Service Manual, p. 16 (PDF p. 22), "Battery Wire Assembly".
  5. ↑ Series 3a Service Manual, p. 15 (PDF p. 21).
