Acorn System 1 Troubleshooting Guide
This guide gives component-level diagnosis for the Acorn System 1 (Acorn Microcomputer). The System 1 has no video and no POST: faults are diagnosed by the monitor program's behaviour on the 8-digit LED display, by probing the 6502 bus against the circuit diagram, and by substituting socketed parts. The IC references below are from the Acorn System 1 Technical Manual and the Acorn System 1 Circuit Diagrams.[1]
Acorn System 1 circuit diagram, sheet 1 of 3 (Technical Manual). All three sheets are on the wiki at Acorn System 1 Circuit Diagrams. (Source: The Centre for Computing History.)
Power-up behaviour
On power-up the monitor program in the 74S571 ROMs (IC5/IC6) drives the 8-digit LED display through the 7445 (IC8) and the 8154 (IC2) on the keyboard card, and waits for hex-keypad input. A healthy machine shows a prompt/address on the display and responds to the keypad. A dark or frozen display points to a supply, clock, CPU, ROM or RAM fault.
Dead machine
  1. Supply: verify +5 V at the LM340-T5 (IC13) output on the CPU card and at the IC VCC pins. Out of range → regulator or supply.
  2. Clock: scope the 1 MHz crystal and the 6502 (IC1) clock input. No clock → the master oscillator is dead and nothing runs.
  3. Reset: check the 6502 reset line releases after power-on.
  4. Address activity: with the clock present, the 6502 address lines should toggle. If static, reseat or substitute IC1 (6502).
  5. ROM fetch: the monitor lives in IC5/IC6 (74S571). The address decoder IC8 (74LS139 on the CPU card) and the glue (IC9 74LS20, IC11 74LS04, IC12 74LS00) select the ROM; check for activity on the ROM pins. A blank display with clocks present is often a ROM-select or ROM fault — reseat IC5/IC6.
Display and keypad
Symptom Probable cause Action
Whole display dark, machine seems alive 7445 decoder (IC8) or 8154 (IC2) on the keyboard card Reseat IC8 / the 8154; check the display drive lines
One digit or segment dead LED display or its drive Check the segment/digit lines from IC8
Keypad dead or wrong keys 8154 (IC2) keypad port, or keypad contacts Clean the keypad; reseat the 8154; check the ribbon to the CPU card
Garbled values / crashes 2114 RAM (IC3/IC4) Reseat; substitute a known-good 2114
RAM and ROM
  • RAM: the 1 KB of RAM is two 2114 devices (IC3/IC4). A failed 2114 corrupts the monitor's scratch/zero-page area and crashes it. Reseat, then substitute.
  • ROM: the 512-byte monitor is in two 74S571 bipolar ROMs (IC5 "Blue", IC6 "Yellow"). These are robust; a blank or wrong display with good clocks and RAM points to a ROM seating or select fault. Reseat IC5/IC6 and verify the decode (the Technical Manual notes the CS lines on address lines A7/A8 at IC8).[1]
Cassette interface
The CUTS 300-baud cassette circuit is built around the LM358 (IC7) on the keyboard card. When reading a known-good tape, the signal at IC7 pin 7 should exceed about 2 V; a low or absent level there points to the read amplifier or the input level.[1] If save/load fails with a known-good recorder, probe IC7 and check the DIN wiring before suspecting the 8154.
EuroConnector / expansion
The CPU card's second 8154 (IC8) and the EuroConnector let the card run in a System 2/3/4 frame. A System 1 that misbehaves only when fitted to a backplane usually has a dirty or bridged edge connector — clean the fingers.
Common fault catalogue
  • Dead, +5 V present — 1 MHz clock/crystal or the 6502 (IC1); reseat IC1.
  • Blank display, clocks present — ROM (IC5/IC6) seating/select, or the 7445 (IC8) display decoder.
  • Garbled values / crashes — a 2114 (IC3/IC4); substitute.
  • Keypad dead — 8154 (IC2) or keypad contacts.
  • Won't load tapes — recorder/tape first, then the LM358 (IC7); confirm IC7 pin 7 read level.
  • Intermittent when racked — dirty EuroConnector; clean.
  1. 1.0 1.1 1.2 Acorn System 1 Technical Manual (Acorn Microcomputer), Acorn Computers — hosted on this wiki. Source for the IC complement (IC1 R6502, IC2/IC8 8154 RAM/IO, IC3/IC4 2114 RAM, IC5/IC6 74S571 ROM, IC9 74LS20, IC10 74LS139, IC11 74LS04, IC12 74LS00, IC13 LM340-T5; keyboard card IC7 LM358, IC8 7445), the address decoding (IC8 chip selects on A7/A8), the cassette read level (IC7 pin 7), and the +5 V regulation.
