Amstrad PCW 8256 / PCW 8512 User Guide
The PCW8256 and PCW8512 User Guide and Guide to Locomotive Software's LocoScript is the user manual AMSOFT, a division of Amstrad Consumer Electronics plc, supplied with the Amstrad PCW 8256 and Amstrad PCW 8512 in 1985. The cover calls it the User Guide – CP/M Logo & Word Processor Manual. The hosted scan has 395 PDF pages, image only, with no text layer.
Contents
The manual is in three sections, each numbered from page 1.
User guide and Guide to LocoScript:
  • Chapter 1, Setting up, p. 1 (mains plug, keyboard and printer connections, switching on, brightness, cleaning)
  • Chapter 2, Your first twenty minutes, p. 11
  • Chapter 3, Keeping your work on disc, p. 27 (disc handling, copying, Start of Day and data discs)
  • A Guide to LocoScript, p. 51, in ten stages (pp. 55–125), and LocoScript summarised, p. 129
  • Appendix I, Troubleshooting, p. 141
  • Appendix II, The printer: loading and maintenance, p. 145 (paper, autoloading, changing the ribbon p. 147, adjusting the print head p. 147, general hints p. 148)
  • Appendix III, Using LocoScript files in other programs, p. 149
CP/M Plus and Logo:
  • Part I, the CP/M operating system: introduction, commands, commercial software, graphics, the built-in commands and utilities; appendices on the character sets, advanced use of the printer, terminal characteristics and error messages (p. 143)
  • Part II, the Dr. Logo language, with its error messages
Part III, Two-Drive Operation, for the PCW8512 or a PCW8256 with a second FD-2 drive: discs and drives, formatting discs for drive B, using drive B with CP/M and LocoScript, and DISCKIT copying and verifying.
What it settles
  • The UK model runs from 220–240 V 50 Hz mains and needs a 5 A fuse in a 13 A plug (p. 1).
  • The keyboard plugs into a 4-pin DIN socket on the right of the monitor unit; the printer uses a 34-way ribbon cable and a separate lead to the Power Out socket (p. 2).
  • Clean the screen and case with an anti-static foam cleaner, never a spirit-based one (p. 8).
  • The printer ribbon is Amstrad Printer Ribbon PR-1. The print head lever has five positions, and position 2 suits one sheet of ordinary paper. The head can be very hot after printing; paper dust is cleared with a blower or a vacuum cleaner (pp. 147–148).
  • Drive B writes double-density CF-2DD discs using both sides at once, with side 1 nearest the screen. A disc formatted in drive B cannot be used in drive A, and drive B only reads, never writes, a CF-2 disc made in drive A (Part III, pp. 2–3).
There is no service information: no circuit diagrams, adjustments or parts lists. For those see Amstrad PCW 8256 / PCW 8512 Service Manual.
Pages that cite this document
Download: Amstrad PCW8256 PCW8512 User Guide (1985).pdf
