Macintosh Performa 5400
ReleasedApril 22, 1996
DiscontinuedFebruary 1, 1997
CPUPowerPC 603e @ 120 MHz
Memory16 MB RAM (expandable to 136 MB)
Storage1.6 GB IDE hard drive
Display15" shadow mask CRT (640ร—480 16-bit, 832ร—624 8-bit)
Sound16-bit stereo output, 16-bit mono input, SRS surround
Dimensions17.5" H ร— 15.1" W ร— 16.0" D (44.5 ร— 38.4 ร— 40.6 cm)
Weight47 lbs (21.3 kg)
OS / FirmwareSystem 7.5.3 โ€“ Mac OS 9.1
PredecessorPerforma 5300
SuccessorPerforma 5500
CodenameAlchemy
Model no.M3046
The Macintosh Performa 5400 is an all-in-one personal computer manufactured by Apple Computer, Inc. It is functionally identical to the Performa 5400CD, with the same 120 MHz PowerPC 603e processor and Alchemy logic board. Both model names refer to the same hardware configuration.
The Performa 5400 series was based on the Alchemy architecture and was the consumer version of the Power Macintosh 5400 educational line. It introduced 168-pin DIMM memory sockets and a PCI expansion slot to the LC line.[1]
The Performa 5400 uses a PowerPC 603e processor running at 120 MHz on a 40 MHz system bus. The 603e is a 32-bit processor with a 64-bit data path and integrated floating-point unit.
Cache Configuration
  • L1 Cache: 32 KB (16 KB instruction, 16 KB data)
  • L2 Cache: 256 KB (optional)
Memory and Storage
RAM Configuration
Specification Details
RAM Type 168-pin DIMM
Minimum Speed 70 ns
Motherboard RAM 8 MB soldered
Standard RAM 16 MB
Maximum RAM 136 MB
RAM Slots 2
Storage Systems
  • Hard Drive: 1.6 GB IDE internal drive
  • Floppy Drive: 1.44 MB 3.5" manual-eject
  • CD-ROM: 4X
Display and Graphics
The built-in 15" shadow mask CRT supports:
  • 640ร—480 at 16-bit color
  • 800ร—600 at 16-bit color
  • 832ร—624 at 8-bit color
Video memory consists of 1 MB dedicated from system RAM.
For detailed maintenance practices, refer to the dedicated Macintosh Performa 5400CD General Maintenance page.
Detailed capacitor replacement guidelines can be found on the Macintosh Performa 5400CD Capacitor Replacement Guide page.
A comprehensive troubleshooting guide is available on the Macintosh Performa 5400CD Troubleshooting page.
  1. โ†‘ Macintosh Performa 5400CD Specs, EveryMac.comโ€”link(accessed 2026-02-10)
