Macintosh Performa 6200CD
TypePersonal Computer
ReleasedJuly 11, 1995
DiscontinuedApril 1, 1996
Intro priceUS$2,300
CPUPowerPC 603 @ 75 MHz
Memory8 MB RAM (expandable to 64 MB)
Storage1.0 GB IDE hard drive, 4X CD-ROM, 1.44 MB floppy
Display640×480 @ 16-bit, 800×600 or 832×624 @ 8-bit
SoundStereo 16-bit, 22 kHz
Dimensions4.3" H × 12.6" W × 16.5" D (10.9 × 32 × 41.9 cm)
Weight19.0 lbs (8.6 kg)
OS / FirmwareSystem 7.5.1 – Mac OS 9.1
PredecessorQuadra 630
SuccessorPerforma 6360
CodenameCrusader
Model no.M3076
The Macintosh Performa 6200CD is a PowerPC-based desktop computer introduced by Apple Computer on July 11, 1995.[1] It was the consumer-oriented replacement for the Quadra 630, sharing the same desktop case design. The business version, sold only in Asia, was marketed as the Power Macintosh 6200/75.[2]
The 6200CD was sold with an Apple Multiple Scan 15" display and an external 14.4k Global Village modem. Several variants were released with different configurations, all sharing the same logic board.
Model Variants
The Performa 6200 series encompasses multiple configurations based on the same logic board:
Performa 6200 Series Variants
Model CPU RAM HDD Modem Monitor Notes
Performa 6200CD 603 @ 75 MHz 8 MB 1.0 GB 14.4k 15" Base model
Performa 6205CD 603 @ 75 MHz 8 MB 1.0 GB 28.8k 15" Upgraded modem
Performa 6210CD 603 @ 75 MHz 8 MB 1.0 GB 28.8k 15" Different software bundle
Performa 6214CD 603 @ 75 MHz 8 MB 1.0 GB 14.4k 15" Different software bundle
Performa 6216CD 603 @ 75 MHz 8 MB 1.0 GB 14.4k None No bundled monitor
Performa 6218CD 603 @ 75 MHz 16 MB 1.0 GB 14.4k 15" More RAM
Performa 6220CD 603 @ 75 MHz 16 MB 1.0 GB 14.4k None TV/video card included
Performa 6230CD 603 @ 75 MHz 16 MB 1.0 GB 14.4k 15" Hardware MPEG decoder
Performa 6260CD 603e @ 100 MHz 8 MB 800 MB None 14" Europe/Asia only
Performa 6290CD 603e @ 100 MHz 8 MB 1.2 GB None None North America only
The Performa 6200CD uses a PowerPC 603 processor running at 75 MHz with integrated FPU. The processor is a 32-bit design with a 64-bit data path.[3]
The internal bus architecture consists of three buses:
  • A 64-bit 75 MHz bus connecting the CPU, 256 KB L2 cache, and 4 MB ROM
  • A 32-bit 37.5 MHz bus connecting memory, video, and I/O controllers via the Capella bridge chip
  • A 32-bit 16 MHz I/O bus managed by the PrimeTime II controller
The 6260CD and 6290CD variants use a PowerPC 603e processor at 100 MHz, with the system bus speed increased to 40 MHz.
Memory and Storage
RAM Configuration
The 6200CD shipped with 8 MB of RAM in two 72-pin SIMM slots, expandable to 64 MB using 80ns or faster SIMMs. The system dedicates 1 MB of main RAM to video memory, leaving 7 MB available for applications in the base configuration.
Storage Systems
Standard storage includes a 1.0 GB IDE hard drive, a 4X CD-ROM drive, and a 1.44 MB 3.5" floppy drive with manual insert mechanism. The system does not support internal SCSI hard drives.
Display and Graphics
Video is handled by an integrated controller using 1 MB of system RAM as VRAM. Display resolutions supported:
  • 640×480 at 16-bit color
  • 800×600 at 8-bit color
  • 832×624 at 8-bit color
A second display can be added via an LC PDS video card.
Input/Output and Expansion
Port Configuration
  • 2× RS-232/422 serial ports (printer and modem)
  • 1× External SCSI port (DB-25)
  • 1× ADB port
  • 1× Monophonic sound input
  • 1× Stereo headphone output
  • 1× DB-15 video output
The modem port was originally covered by a plastic seal on units shipped with an internal modem. If the seal is removed and the internal modem extracted, the external port becomes usable.
Expansion Slots
  • 1× LC PDS slot
  • 1× Comm slot (112-pin, for internal modem)
  • 1× Video I/O slot
  • 1× TV tuner slot
For detailed maintenance practices including cleaning, PRAM battery management, connector corrosion prevention, and general upkeep, refer to the dedicated Macintosh Performa 6200CD General Maintenance page.
Detailed capacitor replacement guidelines for the logic board can be found on the Macintosh Performa 6200CD Capacitor Replacement Guide page.
A comprehensive troubleshooting guide addressing common issues is available on the Macintosh Performa 6200CD Troubleshooting page.
Sub-system Specification (Macintosh Performa 6200CD, 1995)
CPU PowerPC 603 @ 75 MHz (603e @ 100 MHz on 6260/6290)
Bus width 64-bit data • 32-bit address
System Bus 37.5 MHz (40 MHz on 6260/6290)
ROM 4 MB
L1 Cache 16 KB (32 KB on 603e models)
L2 Cache 256 KB
RAM 8 MB (expandable to 64 MB)
Video 640×480 @ 16-bit (1 MB VRAM from system RAM)
Sound 16-bit stereo output, mono input
Storage 1.0 GB IDE, 4X CD-ROM, 1.44 MB floppy
Expansion LC PDS, Comm, Video I/O, TV slots
Ports Serial ×2, SCSI, ADB, Audio I/O, Video out
Identification
Identifier Value
Apple Model Number M3076
Apple Order Number M4100LL/A
Gestalt ID 42
Codename Crusader
  1. Macintosh Performa 6200CD Specs, EveryMac.com—link(accessed 2026-02-10)
  2. Power Macintosh 6200/75: Technical Specifications, Apple—link(accessed 2026-02-10)
  3. Macintosh Performa 6200CD: Technical Specifications, Apple—link(accessed 2026-02-10)
