Video Board Parts Layout
Display PCB Assembly — Commodore Business Machines, Inc.'s component-placement drawing for the Commodore PET 2001 display assembly, scanned at 400 dpi. The board outline is shown with the copper pattern in grey and a reference designator and a value printed against every fitted position.
"Video board" is this wiki's word, not Commodore's. Commodore calls it the display assembly, and it is the machine's power supply as well as its monitor.
This is the most immediately useful of the PET display documents on this wiki, because it is the one that lets you identify a part without tracing the schematic: point at a can on the board, read the designator and the value off the drawing.
What the drawing settles
VR1 is a 7812. The position is marked "VR1 7812 UC" inside heatsink H1. Commodore's parts list says only "voltage regulator, part 901527-01" — this drawing is where the actual device type is recorded, and it confirms that the display assembly's regulated output is +12 V.
C22 and C27 are 3.3 µF, not 33 µF. Both positions are marked "3.3 µF 200 V OR 160 V". Commodore's parts list prints that line as "33 µF/200 V or 4.7 µF/250 V", and the display schematic marks them 3.3 µF. Two drawings against one parts-list line, and the listed 4.7 µF alternative only makes sense beside 3.3 µF. This drawing also adds the 160 V alternative rating, which the parts list does not give.
Q14 has a documented substitution. The main drawing marks Q14 as MJE-13006 in heatsink H2; an inset headed Detail of substitution TR. Q14 and heat sink H2 covers fitting a TIP-55A instead, and instructs that the collector lead is cut off and the screw head connected to the PCB pattern by solder — the TO-220 tab becomes the collector connection. Two #6-32 Phillips screws, two #6-32 hex nuts and two lock washers per device.
The jumper wires are marked. Several links on the board are flagged with a symbol and a legend reading "jumper wire". They are factory links, not repairs, and not missing components.
Values printed on the drawing
Position Value as printed
C1 4700 µF 25 V
C3 47 µF 16 V
C9 1 µF 25 V
C12, C13 47 µF 16 V
C14 0.15 µF
C15 470 µF 16 V
C16 0.1 µF
C19 0.01 µF
C20, C30 220 pF
C22, C27 3.3 µF 200 V or 160 V
C23 220 µF
C24 0.001 µF 200 V
C25 0.022 µF 200 V
C28 10 µF N.P.
C29 820 pF
CR7 33 V 1 W zener
CR16 1N4148
CR17, CR18 1N4935
CR19–CR22 4 × 1N5402 — the mains bridge
L1 Miller 5250
L2 Miller 4632
Q9 TIP29
Q10 TIP30
Q14 MJE-13006 (TIP-55A substitution documented)
R9 100 k
R20 1 M
SG1, SG3 spark gap, 0.01 µF 1.5 kV
SG4 spark gap, 0.75 pF
T1 Marvel M594 A1A
T2 GI 294-7746 flyback
VR1 7812 UC
The rails marked on the drawing are +12 V and −12 V.
What it does not contain
No circuit — this is placement only. No test points or waveforms; those are on Video Board Schematic. No Commodore part numbers; those are in Video Board Parts List (1 of 3). Nothing about the main logic board, which has no equivalent placement drawing on this wiki.
Commodore Display PCB Assembly — component placement for the PET 2001 display assembly, with a value against every fitted position.
Download: video-layout.gif
