Amstrad PCW 9512 Troubleshooting Guide
PCW9512, keyboard and daisywheel printer
Amstrad's user manual for the Amstrad PCW 9512 has a troubleshooting annex arranged by the machine, the disc drive, starting up and the printer,[1] and community repair advice adds the drive belt. The Amstrad PCW 9512+ Troubleshooting Guide covers the electronics of the later 9512+ from Amstrad's service manual for that model, and the Amstrad PCW 8256 Troubleshooting Guide the 3-inch drive of the 8000 series. Procedures are in the Amstrad PCW 9512 Maintenance Guide.
Warning: the main unit contains the mains power supply and a CRT. Read CRT Discharge Procedure before opening it.
The machine
Machine symptoms (user manual, Annex II)
Symptom Probable cause Action
No bright screen at switch-on No mains, plug not fully in, or a blown fuse Check the socket with a lamp, push the plug fully home and check the fuses. Then look inside: the supply is in the main unit.[1]
Screen clears, or the machine stops responding Software crash Take the discs out of the drives and reset by holding Shift and Extra and pressing Exit. If that fails, switch off, wait a few seconds and switch on, then reload LocoScript 2 or CP/M.[1]
Blank screen with no disc in the drive Normal: the PCW has no ROM to show anything Insert a start-of-day disc.[2][3]
Starting up
If the PCW beeps or the screen flashes when it is started, the disc in drive A is not a PCW9512 start-of-day disc, is damaged, or is not suitable for the machine. Check the disc and reset; if it still beeps, try the original master disc.[1] Start-of-day discs made for the PCW 8256, PCW 8512 or CPC 6128 cannot be used on the 9512.[1] The two kinds of PCW use different boot programs, one for dot matrix machines and one for daisywheel machines.[2]
If the drive motor can be heard but the disc does not turn, and the screen stays blank with a system disc inserted, the drive belt has probably perished.[3] See drive belt.
Disc drive
Drive symptoms (user manual, Annex II)
A disc will not go in A disc already in the drive, the transit card still fitted, something else in the slot, or the disc the wrong way round Press eject. Check for the card fitted for transport and for other objects, and check the orientation. Never force a disc in.[1]
A disc will not come out Mechanical fault Do not push anything into the drive to free it; the manual sends the user to a dealer.[1]
"Disc not formatted" message Blank disc, a disc from another computer, a damaged disc, or side 2 uppermost instead of side 1 Check the disc and which side is up; format it if it really is blank. Copy what can be recovered from a damaged disc before reformatting it.[1]
"Disc read" error when opening a file Disc inserted the wrong side up Reinsert with side 1 uppermost.[1]
Elliott's notes record that the 9512's floppy controller is of the same type as the 8256's and 8512's.[2]
Printer
Printer symptoms (user manual, Annex II)
Printer does not start No paper, or the printer is waiting for paper Load a sheet and press Exit. Press PTR to show the printer status line and check whether it is waiting for paper.[1]
Printer runs but nothing appears No ribbon Fit a ribbon cassette.[1]
Unreadable characters Software not set up for the wheel, or the daisywheel badly seated Press PTR to stop the printer, check the status line, and reseat the wheel.[1]
Printer stops suddenly mid-document End of ribbon; the PCW waits so no text is lost Fit a new ribbon and press Exit; printing carries on.[1]
Paper creases or jams – Press PTR to stop the printer (it may take a while to stop if it has a lot of text queued) and reload with fresh paper.[1]
Paper does not load automatically Paper release lever pulled forward Push the paper release lever back.[1]
The printer has no supply or controller of its own: power comes from the main unit through the printer cable, and most of the control electronics are in the main unit.[4] With a completely dead printer, check the cable and the main unit as well as the printer itself. Under CP/M, the defaults that other printers hold on DIP switches, such as paper length, margins and the paper-out detector, are set with the DAISY and MATRIX utilities, so check those settings before suspecting the hardware.[4] The 9512 has its own printer controller, different from the dot matrix machines', which also runs the parallel port.[2]
  1. ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 1.12 1.13 1.14 Amstrad, PCW9512 Ordinateur Personnel Traitement de Texte – Manuel de l'utilisateur (1987, French). Hosted as File:Amstrad PCW9512 User Manual (1987, French).pdf, described at Amstrad PCW 9512 User Manual (French). Annex II, troubleshooting, pp. 37–41: the machine (p. 37), the disc drive (pp. 38–39), starting up (p. 39), the printer (pp. 40–41).
  2. ↑ 2.0 2.1 2.2 2.3 John Elliott, PCW Hardware. Hosted as File:PCW Hardware Reference (John Elliott).pdf, described at Amstrad PCW Hardware Reference (John Elliott). Section 2 (boot process; the daisywheel boot program), section 6.2 (the PCW9512 printer controller), section 8.2 (drive decoding on the 8256, 8512 and 9512).
  3. ↑ 3.0 3.1 Richard Lloyd, PCW article ("Fifty two years and counting"), Amstrad CPC User Club Magazine (ACUC) issue 1, June 2022. Scan at archive.org. Retrieved 2026-10-02. Boot behaviour with and without a disc; the perished drive belt as the most common PCW fault, its symptoms and cleaning the old rubber off the pulley.
  4. ↑ 4.0 4.1 John Donaldson, "Benchtest: Amstrad PCW9512", Personal Computer World, October 1987, pp. 98–102. Scan at archive.org. Retrieved 2026-10-02. The daisywheel printer powered and largely controlled from the main unit; the DAISY and MATRIX utilities that set the defaults other printers keep on DIP switches.
