Color StyleWriter 4100 and 4500 Service Source
The Color StyleWriter 4100 and 4500 volume of Apple's Service Source is Apple's 165-page field-service manual for the Color StyleWriter 4100 and Color StyleWriter 4500, which Apple calls the Color StyleWriter 4000 Series, "desktop color bubble-jet printers for personal use". The title page reads Color StyleWriter 4100 and 4500; the file is stored as color_stylewriter_4500.4100.pdf.[1]
Contents
[edit | edit source]Page numbers are PDF pages.[1]
- Basics (pp. 3–20): overview, 4500 and 4100 differences (p. 4), ink cartridge configurations, troubleshooting LEDs, ink-jet and photo printing technology, ink cartridge identification, recommended paper, printing a photograph and a banner, Special Servicing Considerations (pp. 19–20).
- Specifications (pp. 22–34): characteristics, interfaces, graphics, print media, printable area, ink cartridges, environmental, electrical, physical.
- Take Apart (pp. 36–94): output tray, access door, banner lever, length adjuster, input tray, I/O cover, top cover, pressure plate, base, logic board (p. 55), ground bracket, sensor board, flex support, capping assembly, purge unit, carriage motor, idler hub, tension bracket, paper motor, rear rail, front cover actuator, encoder strip, shaft clip, carriage rod, carriage belt, mechanical assembly, paper out actuator.
- Troubleshooting (pp. 96–121): error messages and LEDs; diagnostic tests and sample pages (p. 99); symptom charts for operation, paper, print quality and LEDs.
- Additional Procedures (pp. 123–163): printer tests (self test, continuous print self test, diagnostic test, print skew test, extended diagnostic test), print head cleaning, fibre track cleaning, replacing and aligning ink cartridges, banner calibration (p. 156), clearing paper jams, fixing carriage stalls.
- Exploded view with Apple part numbers (p. 165).
| Print method | Serial bubble jet, ink on demand |
| Throughput (4500) | Best up to 1 ppm black, 0.3 ppm colour; Normal up to 3 ppm, 0.8 ppm; Draft up to 5 ppm, 1.7 ppm |
| Throughput (4100) | Up to 4 ppm black, up to 1.4 ppm colour |
| Interfaces | High-speed RS-422 serial; can be connected to LocalTalk, but not as a shared printer |
| Environment | Operating 5–40 °C; storage −40 to 60 °C; 10–80 % humidity, non-condensing; 48–52 dB |
| Electrical | External AC adapter: 102–132 V AC 60 Hz ±3 % (US and Japan), 204–264 V AC 50 Hz (UK and Australia), 196–253 V AC 50 Hz (Europe). 2 W off but plugged in; 4.5 W on, not printing; 12 W printing. |
| Size and weight | 199 mm high × 436 mm wide × 405 mm deep; 5.3 kg |
Notes from the manual
[edit | edit source]- Apple lists three differences between the models: the 4500 can produce photo-quality prints, can print on banner (z-fold) paper, and prints slightly faster than the 4100 (p. 4).[1]
- If a printer comes in for service and the customer has had it for a while, Apple says to replace the capping unit. Special Servicing Considerations gives the capping assembly as 922-3010 (4100) and 922-2855 (4500) (p. 19), but the exploded view lists the capping assembly as 922-3009 (4100) and 922-2854 (4500), and 922-2855 as the purge unit (p. 165). Check the number against current parts information before ordering.[1]
- After replacing the logic board or the ink cartridges on a 4500, recalibrate banner printing with the Color StyleWriter 4500 Banner Calibration utility from the Diagnostic folder of the Service Source Companion CD.[1]
- Do not touch or remove any mechanical assembly screw that the Take Apart chapter does not call out: Apple says doing so puts the printer out of alignment and requires a new mechanical assembly (p. 20).[1]
| Printout | Resume presses |
| Sample page | Once |
| Diagnostic self test | 5 |
| Clean print heads | 7 |
| Continuous sample page | 10 |
| Extended diagnostic test | 12 |
| Part | 4100 | 4500 |
| Logic board | 661-1354 | 661-1431 |
| Mechanical assembly | 661-1355 | 661-1430 |
| Capping assembly | 922-3009 | 922-2854 |
| Purge unit | 922-2855 | |
| Carriage motor; paper feed motor | 922-2846; 922-2852 | |
| Carriage belt; sensor board | 922-2851; 922-2834 | |
| AC power adapter | 922-2859 | |
[edit | edit source]It is written at module level: there is no schematic, no component values, no capacitor list and no voltage figures for the adapter's output.[1]
Related documents
[edit | edit source]- Color StyleWriter 6500 Service Source, Color StyleWriter 2200 Service Source, Color StyleWriter 2400 Service Source, Color StyleWriter 2500 Service Source and Color StyleWriter Pro Service Source
- Apple Color Printer Service Source, for Apple's earlier bubble-jet Apple Color Printer
- StyleWriter Service Source
Download: color_stylewriter_4500.4100.pdf
