Color StyleWriter Pro Service Source
The Color StyleWriter Pro volume of Apple's Service Source is Apple's 152-page field-service manual for the Color StyleWriter Pro, "a desktop color bubble-jet printer for personal use" with a 64-nozzle four-colour print head and a separate ink cartridge for each colour.[1]
Contents
Page numbers are PDF pages.[1]
  • Basics (pp. 3–9): overview; service mode (p. 5); service test page (p. 7).
  • Specifications (pp. 11–18): characteristics, graphics, paper handling, ink cartridges, environmental, electrical, physical.
  • Troubleshooting (pp. 20–34): the six controller board LEDs and their indications (pp. 21–24); symptom charts for operation, paper, print quality and error LEDs.
  • Take Apart (pp. 36–114): covers, print head unit, controller board (p. 48), cut sheet feeder, power supply (p. 56), sensor board, carriage unit and board, carriage motor, printer frame, ink absorber elements and plates, paper feed motor, paper guide, platen and roller, photo interrupter, purge unit.
  • Additional Procedures (pp. 116–133): printer cleaning, ink cartridge replacement, nozzle check, print head cleaning, print head purging, fuse replacement (p. 131).
  • Adjustments (pp. 135–150): the Color SW Pro Utility, service mode, EEPROM download mode, using the utility, alignment (p. 145).
  • Exploded view with Apple part numbers (p. 152).
Color StyleWriter Pro specifications as printed[1]
Item Value
Print method Serial bubble jet, ink on demand
Throughput 170 cps standard and 240 cps high speed (text, 10 cpi)
Print head 1 × 64 nozzles for each colour; life "thousands of pages"
Resolution 360 dpi best; 180 dpi draft
Input buffer 60 KB
Ink cartridges Black, cyan, magenta and yellow, about 8 g each; about 315 pages of text at 5 % coverage per colour
Electrical 120 V, 60 Hz, 1 A; 220–240 V, 50 Hz, 0.5 A; 28 W maximum
Size and weight 184 mm high × 418 mm wide × 256 mm deep; about 5 kg
Notes from the manual
  • Service mode uses the buttons and LEDs on the controller board, which are reached by removing the top cover and the inner cover. Hold the power and select buttons while plugging in the power cord; a four-tone beep confirms service mode. For the service test page, which shows whether the print heads need aligning, press select until the black, magenta and yellow LEDs (5, 3 and 2) light, then press power.[1]
  • The Color SW Pro Utility must be run after replacing the controller board, the power supply, the carriage board or the ink absorber plates. It downloads new parameters to the EEPROM on the controller board, with the printer in EEPROM download mode (cyan, magenta and yellow LEDs lit).[1]
  • The power supply connects to the controller board at JPOW1 and is held by two screws. The fuse is behind its own cover; the exploded view gives fuse part numbers 922-0180 (125 V) and 922-0181 (250 V) without a current rating.[1]
  • The troubleshooting LED tables cover 17 error indications, from paper empty or jammed through ink absorber full, EEPROM error and print head error.[1]
Selected parts in the exploded view (p. 152)[1]
Part Apple part number
Controller board 661-0876
Power supply 661-0877 (110 V); 661-0878 (220 V)
Fuse 922-0180 (125 V); 922-0181 (250 V)
Print head 922-0662
Carriage assembly kit 076-0463
Sensor board 922-0663
Purge unit 922-0665
Ink absorber plate kit 076-0149
Carriage motor; paper feed motor 922-0667; 922-0668
Encoder; carriage belt; photo interrupter 922-0669; 922-0689; 922-0670
Cut sheet feeder 922-0819
Top cover; inner cover 922-0890; 922-0889
It is written at module level: there is no schematic, no component values, no capacitor list and no voltage figures for the internal supply, only the mains rating.[1]
Download: color_stylewriter_pro.pdf
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 Apple Computer, Color StyleWriter Pro (Service Source), 152 pp. Hosted as File:Color stylewriter pro.pdf. Page numbers below are PDF pages.
