The Panasonic Q (SL-GC10) has 88 electrolytic capacitors on its own boards, the DVD, AV, LCD and power boards, besides those on the GameCube mainboard and GameCube power board inside it. The lists below are Console5's, read from production boards and listed by board number.[1] RetroSix publishes the same values grouped by size, with Console5 among its sources, and marks which boards are surface mount and which through hole.[2] Panasonic's operating instructions give no component data.[3] Check the markings on your own boards before ordering.
For the GameCube boards, use the Nintendo GameCube Capacitor Replacement Guide: its mainboard table has a column for the DOL-CPU-10 and DOL-CPU-11, the two mainboards GC-Forever records in the Q.[4] Console5's Q kit covers every board on its Q page, but leaves out the aluminium polymer capacitors on the GameCube DC-DC board, which Console5 says should not need replacing. Since March 2026 its kit supplies tantalum parts for the 10 µF positions on the GameCube boards.[5]
Unplug the Q. The AC power board is live whenever the plug is in.[6]
C903 on the main power supply board LSJB1090-4 is the primary reservoir, 150 µF 200 V. Measure across it before handling the board. 100 V mains rectifies to about 141 V DC; fit a replacement rated 200 V or more.[1]
Note every ribbon and harness before unplugging it. The connector map is on the maintenance guide. Leave connector Q, which holds the laser trim settings, with its board.[7]
Hitman's Museum recapped the GameCube board of its Q while the board was out for an optical drive emulator fitting, ahead of recapping the rest of the machine.[8]
Take out one board at a time, and photograph it before removing anything.
Replace each capacitor with the same capacitance and the same or a higher voltage rating, observing polarity. Check the height of tall parts against the case and the boards above them; Console5 changed the 330 µF surface-mount parts in its kit in 2025 to get the height right.[5]
On the surface-mount boards, remove the old parts without lifting pads, and clean off any electrolyte before fitting new ones. The method is set out in the GameCube guide.
Refit the boards and reconnect them in stages, powering up after each, as in the troubleshooting guide. If the relay drops out after a step, the board just connected has a fault.[6]
The standby light comes on with the mains connected, the relay clicks once at POWER, and the LCD shows HELLO.[10]
The DC power board's outputs on connector N are 12 V, −12 V, 5 V and 2.5 V, and connector M carries 12 V to the GameCube power board. RetroSix gives no tolerances.[6]
Play a DVD, an audio CD and a GameCube disc, and check the composite, S-Video and optical outputs.
↑ 1.001.011.021.031.041.051.061.071.081.09Panasonic Q, Console5 TechWiki, 7 March 2025—link(accessed 2026-10-01)
Capacitor lists by board number for the DVD, AV, LCD and power boards; the GameCube boards are referred to Console5's GameCube page. Secondary source, compiled from boards.
↑ 2.02.12.2Capacitors (Panasonic Q), RetroSix Wiki, 16 August 2026—link(accessed 2026-10-01)
Capacitor tables grouped by value; repeats Console5's values and names Console5 among its sources.
↑Matsushita Electric Industrial Co., Ltd., DVD/ゲームプレーヤー 取扱説明書 品番 SL-GC10 (operating instructions, RQT6164-S, October 2001), 60 pages, in Japanese. Specifications p. 50; Q&A p. 50; troubleshooting table pp. 51–53; names of parts pp. 54–57; care, warranty and parts retention p. 58; game error messages p. 34. Hosted here as File:Panasonic Q SL-GC10 Operating Instructions RQT6164.pdf (PDF page = printed page + 1); see Panasonic Q Documentation.
↑GC-Forever Wiki, "GameCube versions". Community source. Lists the SL-GC10 with mainboards DOL-CPU-10 and DOL-CPU-11, IPL NTSC revision 1.0 and drive identifier 0000 0000 20010831 61 4D.
↑ 5.05.1Panasonic Q Cap Kit - All Boards: GameCube, DVD Player Control, Power Supplies, Console5—link(accessed 2026-10-01)
Kit notes: covers every board on Console5's Panasonic Q wiki page; GameCube DC/DC board aluminium polymer capacitors are not included; since March 2026 the 10 µF parts for the DOL boards are tantalum. The same page lists a replacement tray belt for the Q.
↑ 6.06.16.2Systematic Bring Up (Panasonic Q), RetroSix Wiki—link(accessed 2026-10-01)
Community account of the power-up stages: standby supply, relay, DC power board rails and the over-current trip.
↑Ribbon Connections (Panasonic Q), RetroSix Wiki—link(accessed 2026-10-01)
Community labelling of the boards and their connectors A to V.
↑Panasonic Q (SL-GC10) GameCube: Drive Rails & FlippyDrive, Hitman's Museum, June 2022 – September 2025—link(accessed 2026-10-01)
Restoration log: shattered left drive rail and deformed belt, 3D-printed rails, FlippyDrive with the flex cable reversed, and a recap of the GameCube board.
↑Power Up Basics (Panasonic Q), RetroSix Wiki—link(accessed 2026-10-01)
Community notes on the standby light, the relay, the LCD start-up messages and the front-panel buttons in each mode.
