Panasonic Q Troubleshooting Guide
Fault-finding on the Panasonic Q (SL-GC10) splits along the line between its two halves. Faults on the GameCube side (controller ports, memory cards, the GameCube board's own supply and chips) are covered by the Nintendo GameCube Troubleshooting Guide. Faults in the Q's own parts, its mains supply, DVD drive, display and case, are covered here, from Panasonic's operating instructions, RetroSix's bench notes and owners' repair reports.[1][2] Disassembly and the connector map are on the Panasonic Q General Maintenance page.
Before you start
[edit | edit source]- The Q is rated for AC 100 V only.[3] Find out what supply it has been run from before diagnosing anything else.
- Unplug it before opening the case. The AC power board is live whenever the plug is in.[2]
- The Q plays only GameCube discs marked for Japan.[1] A foreign disc that will not boot is not a fault. Some Qs carry region modifications from earlier owners; one photographed for Commons has a rear sticker reading "Modded, hold power to play american".[4]
Things that are not faults
[edit | edit source]- The GAME and DVD/CD buttons change mode only when the tray is empty.[5]
- A GameCube disc in DVD mode shows NO PLAY, and a DVD or CD in game mode shows NO DISC.[1][6]
- There is no picture in DVD mode until a DVD has loaded, and DIALOGUE ENHANCER does nothing until a DVD is playing.[6]
- The fan does not run in DVD mode.[5]
- DVD video never appears on the digital AV output, only on composite and S-Video. The TV aspect setting in the DVD menu does not change the game picture.[3][5]
- The case warms up in long use. Panasonic says this is normal.[1]
- Some picture break-up during fast forward and rewind is normal.[1]
Normal start-up
[edit | edit source]RetroSix's notes give the sequence on a working Q:[6][2]
- With mains connected, the red standby light on the front board comes on. RetroSix measured about 15 mA drawn on standby at 110 V.
- Press POWER. The relay on the AC board clicks once and the LCD shows HELLO, then the last mode used.
- In DVD/CD mode the LCD shows DVD/CD, then ---- READ, then a CD or DVD icon. With a disc it counts through 0---, 00-- and 000- as it reads, then plays. With no disc it shows NO DISC.
- In GameCube mode the LCD shows GAMECUBE and the GameCube boot screen appears on the television.
- OPEN/CLOSE shows OPEN or CLOSE while the tray moves.
Panasonic's own fault table
[edit | edit source]| Symptom | Panasonic's check or remedy |
| No power | Push the mains plug fully into the socket. If the case is hot, let it cool before switching on. |
| Buttons do nothing | Some discs block some operations. Lightning or static can upset the unit; switch it off and on again. |
| Remote control does nothing | Check the batteries and their polarity; aim at the receiver. |
| DVD or CD will not play, or stops at once | Condensation on the lens after moving from cold to warm: leave for one to two hours. Check the disc is a type the Q plays, clean it, and check the parental lock setting. |
| NO PLAY on the display | The disc cannot be played, or the parental lock blocks it. |
| NO DISC on the display | No disc, a disc not seated properly, or a DVD, CD or Video CD in the tray in game mode. |
| "Check the disc" on the television | Clean the disc. |
| H and two digits on the display | A fault has been detected. Switch off and on again. If the code stays, have the unit repaired and quote the code (for example H01). |
| No sound | Check the volume and input selection on the connected equipment, and the connections and settings. |
| Harsh noise from an amplifier | With a digital connection, set Dolby Digital and DTS output to match the amplifier. |
| Distorted sound | The surround setting can distort some sound; check it. |
| No picture, or wrong picture size | Check the connections, the TV's power and input selection, the TV aspect setting and the TV's own picture mode. |
| No game picture or main menu | Check the connections and TV input. Only Japanese GameCube discs play. Check the disc is seated. If the game was set to progressive output on a TV that cannot show it, press GAME RESET or switch off and on to restore the normal output. |
| Edges of the game picture cut off | Adjust the horizontal picture position in the GameCube settings. |
| Controller does nothing | Check it is in the port the game expects, and the controller position setting. |
| Forgotten parental lock code, or to restore factory settings | With playback stopped, hold the ■ (stop) button on the Q and the ≥10 button on the remote until ALL CLEAR disappears from the television. |
[1] The game side also shows its own error messages:[7]
- "An error has occurred. Press POWER to switch off and follow the instruction manual": Panasonic says the unit may be faulty. Switch off at once and unplug it.
- "The disc could not be read": the disc may be scratched or dirty. Clean it and insert it again.
- "The console settings have been lost. The date and time have been reset": set the date and time again. If this appears at every power-on, the internal battery may be exhausted; see the maintenance guide.
Power faults
| No red standby light | No mains; fuse; AC power board; connectors P or S | Check the mains lead and fuse, then the AC board, then connector P (top lid to AC board) and S (top lid to front board) |
| Standby light on, but no relay click at POWER | Wiring on connectors P and S | Reseat and inspect P and S |
| Relay clicks on and straight off again | A short or overload on a rail tripping the over-current protection | Bring the system up in stages, below |
| Q starts, then shuts down with F76 | A shorted rail, a faulty power board, or (reported once) a three-wire replacement fan | Bring the system up in stages; refit a two-wire fan or tie the third wire to the supply wire |
Bringing the system up in stages
[edit | edit source]RetroSix's method finds which part trips the over-current protection by reconnecting the boards one at a time and pressing POWER after each step:[2]
- Connect only the AC power board, the top lid (connector P) and the front board (connector S). The standby light should come on.
- Connect the DC power board to the AC board: the thick two-wire red and black lead carries the switched mains, and a five-wire harness goes to the other side. Press POWER; the relay should stay in.
- Connect M from the DC power board to the GameCube power board, and L from there to the GameCube board. Test again.
- Connect J from the GameCube power board to the side board. Test again.
- Connect N from the DC power board to the side board. Test again.
- Reconnect the rest one part at a time.
The step at which the relay drops out again identifies the part with the short. Check it for shorted capacitors and damaged parts; the values are on the Panasonic Q Capacitor Replacement Guide.
Disc tray
[edit | edit source]- OPEN/CLOSE does not bring the tray out; pulled out by hand, it will not close. BEEP traced this to a perished tray belt on a Q it repaired. The belt cannot be changed until the gear above it is removed.[9]
- Something rattles when the Q is tilted. On the same Q, BEEP found pieces of the plastic that holds the drive in place, with cracks elsewhere, and repaired the mounts.[9]
- Broken tray rails: Hitman's Museum found the left rail of its Q shattered and the belt deformed, and a GC-Forever member found the rails broken after the Q had been posted. Both fitted 3D-printed rails.[10][11]
The tray's open and closed positions are sensed by switches S3 and S2, wired with the tray motor to CN504 on the indication and control board.[12] The repair procedures are on the maintenance guide.
Disc reading
[edit | edit source]- Grinding, discs taking minutes to load, then no spin at all: one owner's Q went this way over a year. A reply suggested the spindle hub slipping down the motor shaft and rubbing on the plate beneath, as on the GameCube and the Philips CD-i, but nobody confirmed it on the Q. Another member's Q, whose drive stopped opening and closing properly after a fall, was repaired by an engineer who found its drive parts to be standard Panasonic DVD drive parts.[13]
- Lens broken, or the pickup damaged beyond repair: one owner replaced the whole drive with the one from a Panasonic DVD-XV10, which GC-Forever reports is the same drive as in the DVD-XP30 and DVD-XP50. The donor's tray switch assembly had to be desoldered and swapped for the Q's, whose wires are longer, and the laser potentiometers set to match the original drive. It then played DVDs and GameCube discs.[11]
- The pickup is a RAF3011A. Its position switch S1, closed when the pickup is at the spindle end, is wired with the pickup motor to CN402 on board RJB2452AA.[12]
- Clean the lens before anything else; Panasonic's lens-cleaning disc for the Q is the RP-CL510.[3]
Optical drive emulators and modchips
[edit | edit source]Where the drive cannot be saved, an optical drive emulator replaces it. The FlippyDrive works in the Q, with its flex cable fitted the opposite way round from a GameCube, which lets the screw for the drive's connector board go back in. Its intended routing is under the shielding.[10] On GC-Forever, one owner reports that the Qoob Pro modchip works and XenoGC does not, and another that softmods and Swiss run on the Q.[14]
[edit | edit source]- Panasonic Q
- Panasonic Q General Maintenance
- Panasonic Q Capacitor Replacement Guide
- Panasonic Q Documentation
- Nintendo GameCube Troubleshooting Guide
- Capacitor Failure Symptoms
[edit | edit source]- ↑ 1.0 1.1 1.2 1.3 1.4 1.5 Matsushita, SL-GC10 operating instructions (RQT6164), "故障かな!?と思ったら" (troubleshooting), pp. 51–53 (PDF pages 52–54), File:Panasonic Q SL-GC10 Operating Instructions RQT6164.pdf.
- ↑ 2.0 2.1 2.2 2.3 2.4 Systematic Bring Up (Panasonic Q), RetroSix Wiki—link(accessed 2026-10-01) Community account of the power-up stages: standby supply, relay, DC power board rails and the over-current trip.
- ↑ 3.0 3.1 3.2 Matsushita Electric Industrial Co., Ltd., DVD/ゲームプレーヤー 取扱説明書 品番 SL-GC10 (operating instructions, RQT6164-S, October 2001), 60 pages, in Japanese. Specifications p. 50; Q&A p. 50; troubleshooting table pp. 51–53; names of parts pp. 54–57; care, warranty and parts retention p. 58; game error messages p. 34. Hosted here as File:Panasonic Q SL-GC10 Operating Instructions RQT6164.pdf (PDF page = printed page + 1); see Panasonic Q Documentation.
- ↑ Rating plate on the rear panel, photographed by Evan-Amos: File:Panasonic Q SL-GC10 rear.jpg.
- ↑ 5.0 5.1 5.2 DVDプレーヤーとゲームキューブが合体 ゲームもできるDVDプレーヤー「Q」ファーストインプレッション, Impress, 30 November 2001—link(accessed 2026-10-01) Hands-on with a demonstration unit: tray recesses, front and rear panels, the fan, mode switching, LCD and game timer.
- ↑ 6.0 6.1 6.2 6.3 Power Up Basics (Panasonic Q), RetroSix Wiki—link(accessed 2026-10-01) Community notes on the standby light, the relay, the LCD start-up messages and the front-panel buttons in each mode.
- ↑ Matsushita, SL-GC10 operating instructions (RQT6164), "ゲームのエラーメッセージ" (game error messages), p. 34 (PDF page 35), File:Panasonic Q SL-GC10 Operating Instructions RQT6164.pdf.
- ↑ F76 Error (Panasonic Q), RetroSix Wiki—link(accessed 2026-10-01) Community notes on causes of the F76 shutdown.
- ↑ 9.0 9.1 【修理依頼】パナソニックDVD/ゲームプレーヤーQのディスク開閉不良を修理しました, BEEP, 7 February 2020—link(accessed 2026-10-01) Shop repair report: tray fault from a perished belt, gears removed to fit the new belt, old grease cleaned off, broken drive mounting plastic repaired.
- ↑ 10.0 10.1 Panasonic Q (SL-GC10) GameCube: Drive Rails & FlippyDrive, Hitman's Museum, June 2022 – September 2025—link(accessed 2026-10-01) Restoration log: shattered left drive rail and deformed belt, 3D-printed rails, FlippyDrive with the flex cable reversed, and a recap of the GameCube board.
- ↑ 11.0 11.1 Panasonic Q Complete DVD Drive SWAP (and hopefully modding?), GC-Forever forums, 26 May – 31 August 2020—link(accessed 2026-10-01) First post (Gaijinsan, 26 May 2020): drive shared with the Panasonic DVD-XV10, DVD-XP30 and DVD-XP50; printed rails needing filing; tray switch assembly moved across; laser pots adjusted. Replies on modchips and softmods.
- ↑ 12.0 12.1 Panasonic SL-GC10 (Panasonic Q) CD/DVD Mechanism Schematic Diagram RAJ4601-M (K), one sheet, 2010. A community drawing, not a Panasonic document. Hosted here as File:Panasonic Q SL-GC10 CD-DVD Mechanism Schematic RAJ4601.pdf.
- ↑ Panasonic Q with a dead optical drive, need replacement, GBAtemp, January–April 2010—link(accessed 2026-10-01) Owner's report of a grinding drive that stopped spinning discs, with replies.
- ↑ GC-Forever forums, "Panasonic Q Complete DVD Drive SWAP", replies of 28 July 2020 by EthernumRasa (modchips: Qoob Pro works, XenoGC does not; WASP/WiiKey Fusion possible but poorly documented) and emu_kidid (softmods and Swiss work on the Q). Community experience.
