Related changes
Enter a page name to see changes on pages linked to or from that page. (To see members of a category, enter Category:Name of category). Changes to pages on your Watchlist are in bold.
List of abbreviations:
- N
- This edit created a new page (also see list of new pages)
- m
- This is a minor edit
- b
- This edit was performed by a bot
- (±123)
- The page size changed by this number of bytes
25 September 2026
08:54 | Recommended Tools 2 changes history +2,697 [Josh (2×)] | |||
08:54 (cur | prev) +1,439 Josh talk contribs (P4 verification: cite Apple's own equipment lists: the LaserWriter Technical Procedures bench requirements and the light meter specified for the all-in-one video adjustments) | ||||
07:58 (cur | prev) +1,258 Josh talk contribs (cite Apple TechStep, the Chilton repair guide and the OneScanner volume (P4 orphan fix)) | ||||
| 08:54 | Capacitor Failure Symptoms diffhist +1,692 Josh talk contribs (P4 verification: add worked examples of ESR-rise and RIFA failure from the two hosted Pina books, with the U.S./International designator warning) | ||||
| 08:50 | Macintosh SE diffhist +912 Josh talk contribs (P4 verification: cite Apple's own Service Source volume for this machine (hosted here) for the electrical specification and battery threshold, and link the documentation page) | ||||
08:48 | Macintosh SE Capacitor Replacement Guide 2 changes history +2,118 [Josh (2×)] | |||
08:48 (cur | prev) +3 Josh talk contribs (P4 verification: rename a duplicated ref name so the citation renders) | ||||
08:47 (cur | prev) +2,115 Josh talk contribs (P4 verification: add a component-level sources section: Apple's module-level manual and Pina's SE analogue-board and CRT-socket-board parts lists, both hosted here) | ||||
| 08:44 | File:The Dead Mac Scrolls 1992.pdf diffhist +1,098 Josh talk contribs (P4 verification: real summary, page count, file size, source note and honest licence block for a File: page that was empty or 'MsUpload') | ||||
| 08:01 | Macintosh Classic II diffhist +661 Josh talk contribs (cite the hosted Service Source volume and what it settles (P4 orphan fix)) | ||||
| 08:01 | Macintosh Classic diffhist +1,250 Josh talk contribs (cite the hosted Service Source volume and what it settles (P4 orphan fix)) | ||||
| 07:58 | Macintosh 128K diffhist +904 Josh talk contribs (cite the Chilton guide, the 1985 training handout and Apple's Service Guide Volume 1 (P4 orphan fix)) | ||||
| 02:31 | Sad Mac Error Codes diffhist +929 Josh talk contribs (Link Apple's OS 8.1 Emergency Handbook and the MacsBug guide from the Sad Mac page - both were reachable from no article) | ||||
23 September 2026
23:33 | Sad Mac Error Codes 3 changes history +569 [Josh (3×)] | |||
23:33 (cur | prev) +17 Josh talk contribs (House style: rephrase the corrections as statements about the facts rather than about this page's own history) | ||||
23:28 (cur | prev) 0 Josh talk contribs (Fix the remaining FFFFTTEE to FFFFEETT for consistency with the rest of the page) | ||||
23:27 (cur | prev) +552 Josh talk contribs (Verification drive: labelled as {{Original research}} per the wiki's own policy for native decoding work. Fixed internal inconsistencies: the expanded line-1 layout is FFFFEETT not FFFFTTEE (the page's own worked example, the extended exception list and the decoder gadget all put the exception in the upper byte of the lower word); the intro example called RAM Bank A test 03 when the page's own table makes it 04; the per-ROM checksum Test Manager command was given as test 04 (RAM Bank A) rathe...) | ||||
23:30 | Sad Mac Decoder 2 changes history +651 [Josh (2×)] | |||
23:30 (cur | prev) +164 Josh talk contribs (Add the Sad Mac illustration to the decoder page) | ||||
23:27 (cur | prev) +487 Josh talk contribs (Verification drive: labelled as {{Original research}}; spelled out the FFFFEETT layout so it matches the Sad Mac Error Codes page and the gadget's own parsing; added 512Ke to the short-format model list to match the gadget; noted that the chimes are synthesised rather than sampled) | ||||
| 18:18 | Macintosh Classic II diffhist −1,624 Josh talk contribs (Rebuilt against Apple Classic/Classic II/Performa 200 Service Source: DELETED fabricated memory map, V8 Lite/MEMCjr chipset claims, 53C96 and Egret attributions, ROM module table, MacBench comparison table, Paris codename/Eiffel silkscreen, JP3 debug jumper and the cold-start easter egg; SIMM speed 80ns -> 120ns or faster, single SIMM claim corrected to a pair, dimensions/weight/model number corrected; region-specific analogue board warning added; release_date parameter fixed; refs and reflist) | ||||
| 18:18 | Macintosh Classic diffhist −586 Josh talk contribs (Rebuilt against Apple Classic/Classic II/Performa 200 Service Source: DELETED fabricated memory map, ROM SIMM module table, SWIM-II/53C80 detail, MacBench benchmark table, Seattle/LittleFish codenames and MacsBug easter egg, and the 512KB 32-bit-clean/HFS+ ROM claim; CPU 8MHz -> 7.8336MHz, ONE ADB port (not two), Apple dimensions and 100W; predecessor SE/30 -> SE; added the real Command-Option-X-O ROM disk; fixed red link to a nonexistent Troubleshooting page; release_date parameter fixed; re...) | ||||
| 18:17 | Macintosh SE diffhist −4,570 Josh talk contribs (Rebuilt against Apple Macintosh SE Service Source: DELETED fabricated memory map, ROM v5.3-v5.6 table, PDS card list, RC filter values, environmental table, 150W max power, 1.5 million units and the ROM easter-egg address; Apple specs added (100W max, 90-140/170-270VAC, 17-21lb, four-voice sound); three-assembly construction (analogue board + separate PSU + video board) documented; FRU/board numbers; release_date parameter fixed; refs and reflist) | ||||
| 18:14 | Macintosh SE Memory Upgrade Guide diffhist +1,172 Josh talk contribs (Sourced to Apple Macintosh SE Service Source + Guide to the Macintosh Family Hardware: split resistor-board (R35/R36) and jumper-board procedures properly, added Apple note to disregard the 2/4M silkscreen, added eight-chip/complete-row/row-order rules, removed emoji headings, refs and reflist) | ||||
02:25 | Recommended Tools 2 changes history +7,999 [Josh (2×)] | |||
02:25 (cur | prev) +183 Josh talk contribs (Add a topical image (page had none)) | ||||
02:11 (cur | prev) +7,816 Josh talk contribs (Rewrite and verify every named product: corrected Retro Chip Tester (standalone 8Bit-Museum instrument, not a TL866 add-on) with its real capabilities; corrected ESD mat/strap earthing to require a current-limiting resistor per ANSI/ESD S1.1 (a direct bond to mains earth is dangerous); removed insulated gloves as CRT protection in favour of goggles and the correct discharge tooling; replaced the unsourced 20-50 MHz scope rule with edge-speed reasoning; added sourced solder melting points (Kes...) | ||||
02:15 | Capacitor Failure Symptoms 2 changes history +12,684 [Josh (2×)] | |||
02:15 (cur | prev) −40 Josh talk contribs (Remove self-referential wording per house rule) | ||||
02:07 (cur | prev) +12,724 Josh talk contribs (Rewrite with full citations (Nichicon CAT.8101H hosted here, Vishay 40110, KEMET F3011): corrected 60 Hz hum to twice mains frequency, corrected bulging mechanism to Nichicon gas generation, added missing film/X2 suppression section, added tantalum derating 60-50 percent, added Class II ceramic DC-bias behaviour, replaced Japanese-brand rule with no-datasheet-no-purchase, replaced IPA-only cleanup with Nichicon soap-and-water plus never acidic/alkaline, replaced reforming folklore with Nichic...) | ||||
02:15 | CRT Discharge Procedure 2 changes history +11,081 [Josh (2×)] | |||
02:15 (cur | prev) −45 Josh talk contribs (Remove self-referential wording per house rule) | ||||
02:05 (cur | prev) +11,126 Josh talk contribs (Rewrite against Apple Service Guide 1990 and Goldwasser CRT notes: corrected earth-return point (ground lug, never logic board), added never-wear-a-wrist-strap rule and implosion/goggles hazard, replaced unsourced 25 kV blanket with sourced per-class figures, replaced dead-short tool with resistive tooling, removed invented 30-min wait / 10-s hold / 10-15-min re-discharge interval, added ongoing shorting lead and aquadag mechanism; full ref citations) | ||||
| 01:36 | Battery Explosion, Capacitor or Corrosion Damage diffhist +12,961 Josh talk contribs (Verification drive: corrected chemistry (Li-SOCl2 half-AA neutralised with bicarbonate not IPA/water; capacitor electrolyte washed not neutralised - no published pH); added cadmium hazard for NiCd; added damaged-cell handling section incl. accurate lithium fire guidance; fixed +5V range 4.75-5.25 V; corrected United Chemi-Con/Nippon Chemi-Con and OS-CON/Panasonic; removed arbitrary '100 ohm' rail threshold and Kapton '400C' claim; added IEC 60086-1 cell designations; all figures now <ref>-cit...) | ||||
| 00:13 | Macintosh SE Capacitor Replacement Guide diffhist +10,759 Josh talk contribs (Verification drive: the 24-row analogue-board table was the Macintosh Plus power/sweep board list and does not apply to the SE at all - the SE uses analogue board 630-0147 plus a SEPARATE power supply module (three variants). Logic board caps were given as 33uF 10V; they are 16V, and the designators were wrong. Removed R56 - the SE has no voltage adjustment. Added Apple FRU numbers, electrical specs, the 2.8V battery threshold, and Pina component-level analogue-board faults from the hosted De...) | ||||
21 September 2026
| 21:52 | Macintosh SE Capacitor Replacement Guide diffhist +20 Josh talk contribs (Verification drive: flag unverified component data pending check against a primary source) | ||||
| 21:50 | Battery Explosion, Capacitor or Corrosion Damage diffhist +20 Josh talk contribs (Verification drive: flag unverified component data pending check against a primary source) | ||||
