Macintosh Performa 630
Revision as of 18:45, 1 October 2026 by Josh (talk | contribs) (Remove Category:Macintosh Performa (created in error, to be deleted))
The Macintosh Performa 630 is the consumer version of the Macintosh LC 630 and Macintosh Quadra 630, a low-profile desktop Macintosh with a 33 MHz 68LC040 that Apple introduced in July 1994.[1] Apple's specification sheet dates it 1 July 1994; EveryMac and Wikipedia give 18 July 1994.[1][2][3] The base Performa 630 has no CD-ROM drive; the Performa 630CD adds one. EveryMac lists the 630 at US$1,500 (order number M3423LL/A).[2]
Macintosh Performa 630 (Hellis, Italian Wikipedia, CC BY-SA 3.0)
TypeDesktop personal computer
ReleasedJuly 1994
Intro priceUS$1,500
CPUMotorola 68LC040 at 33 MHz, no FPU
Memory4 MB on the logic board; one 72-pin SIMM socket (80 ns); 36 MB maximum
Storage250 MB internal IDE hard drive
Display—
Sound8-bit mono input; 8-bit stereo output (16-bit in CD mode)
Graphics1 MB DRAM frame buffer, not expandable; DB-15 port
ROM1 MB
Media1.4 MB Apple SuperDrive (manual insert); bay for an optional AppleCD 300i Plus
Ports / interfaceOne ADB, two RS-232/RS-422 serial (mini DIN-8), SCSI (DB-25), DB-15 video, sound in, sound out front and rear
Expansion114-pin LC processor-direct slot, 112-pin communications slot, 60-pin video-in slot, 10-pin TV tuner connector
Power100-240 V AC, 50-60 Hz, 45 W maximum
Dimensions4.3 × 16.5 × 12.6 in (10.95 × 41.95 × 32 cm)
Weight17 lb (7.7 kg) without CD-ROM drive
OS / FirmwareSystem 7.1.2P to Mac OS 8.1
CodenameCrusader
Model no.M3076 (Gestalt ID 98)
Apple's Macintosh Performa 630 Series Service Source covers the Performa 630, 630CD, 631CD, 635CD, 636, 637CD and 638CD.[4]
Performa 630 series configurations
Configurations in Apple's Service Source
Model RAM Hard drive CD-ROM drive Display Modem Other
Performa 630 4 MB 250 MB None 14-inch Performa Display Plus TelePort
630CD 8 MB 250 MB AppleCD 300i Plus 14-inch Performa Display Plus TelePort
635CD 5 MB 250 MB AppleCD 300i Plus 15-inch Performa Display TelePort
636 4 MB 250 MB None 14-inch Performa Display Plus None
637CD 8 MB 250 MB AppleCD 300i Plus 15-inch Performa Display TelePort TV tuner and video-in cards
638CD 8 MB 250 MB AppleCD 300i Plus 15-inch Performa Display TelePort TV tuner and video-in cards
The manual's title page also names the 631CD but gives no configuration for it.[4] The Performa 640CD DOS Compatible is covered by the LC 630/Quadra 630/Performa 640 Service Source.[5]
Performa 630 series specifications (Apple)
Item Specification
Processor Motorola 68LC040 at 33 MHz; 32-bit registers, address and data buses[4]
RAM 4 MB built in; 36 MB maximum on a logic board with one SIMM slot (part 661-0158), 52 MB on a board with two (661-1114: one ordinary slot and one single-sided slot)[4]
ROM 1 MB[4]
Video 1 MB DRAM frame buffer, not expandable; up to 16 bits per pixel on Apple 12- to 14-inch monitors, the 15-inch multiple-scan and VGA (640 × 480); up to 8 bits on the Apple 16-inch and SVGA (800 × 600)[4]
Drives 1.4 MB SuperDrive, manual insert; 250 MB IDE hard drive; optional AppleCD 300i Plus. Internal SCSI hard drives are not supported[4]
Ports Two RS-232/422 serial (mini DIN-8); one external SCSI (DB-25); one ADB (mini DIN-4); DB-15 monitor port on the video daughterboard[4]
Sound 8-bit mono input (microphone or line level, with bias current for an electret microphone); 8-bit stereo output, 16-bit in CD mode, 0.5 V RMS into 39 ohms, front and rear jacks[4]
Slots 114-pin LC processor-direct slot; 112-pin communications slot; 60-pin video-in slot; 10-pin TV tuner port[4]
Controls Soft power from the keyboard; front-panel volume buttons; optional infrared remote[4]
Electrical 100-240 V AC, 50-60 Hz; 45 W maximum, not including the monitor[1][5]
Size and weight 10.95 × 41.95 × 32 cm; 7.7 kg (17 lb) without CD-ROM drive, 8.6 kg (19 lb) with[4]
The Performa 630 Series volume prints the maximum power as "5 W, not including monitor"; Apple's specification sheet and the LC 630/Quadra 630/Performa 640 volume give 45 W.[4][1][5] The same volume says the external SCSI port takes up to six devices in its specifications and seven in its general information.[4]
Low End Mac describes the 630 family as the first desktop Macintoshes with an IDE hard drive; the CD-ROM drive, when fitted, is SCSI.[6] Apple says IDE drives must be replaced like for like, and that the IDE drive does not affect SCSI IDs or termination.[4] The logic board slides out of the back once the plastic I/O door is removed, and the drives come out from the front after the drive bezel.[4]
The 68LC040 has no FPU; Low End Mac notes that one can be added by fitting a full 68040 in its place.[6] Apple's upgrades were the Macintosh Processor Upgrade, a PowerPC 601 card with a 256K cache card that lets the machine switch between the 601 and its 68LC040, and the Power Macintosh 5300/6300 logic board upgrade with a 100 MHz 603e.[4]
Battery
Apple's specification sheet gives the battery as 4.5 V alkaline, and Low End Mac agrees.[1][6] The Service Source names no battery part and no test voltage. Its symptom charts tell the technician to "Unplug 5.4 battery, wait 20 seconds, plug in battery, and restart computer"; "5.4" is a misprint for 4.5, which the LC 630 volume prints for the same step.[4][5] Fitting the Processor Upgrade involves lifting the battery and turning it a quarter turn on the board.[4] Leakage from an alkaline pack is neutralised with a weak acid such as vinegar; see Battery Explosion, Capacitor or Corrosion Damage.
From Apple's symptom charts
Symptom Apple's cures, in order
Eight-tone error chord at start-up Reseat the SIMMs; replace the SIMMs; replace the logic board[4]
Four-tone error chord at start-up Disconnect the hard drive power cable and restart (if normal, test and replace the drive); disconnect the floppy cable and restart (if normal, replace the floppy drive); replace the logic board[4]
Screen completely dark, fan not running, LED off Check the power connections; the machine powers on only from the keyboard, so try a known-good keyboard; reseat the logic board; unplug the battery for 20 seconds; check the monitor has power; remove cards and peripherals; replace the power supply, then the logic board[4]
Menu bar flashes or the system keeps beeping Check the front-panel buttons are not jammed; reseat the drive bezel and front panel control board[4]
Crackling sound outside play-through mode Audio Volume Extension 1.1 or later; replace the logic board[4]
Rattling at start-up with the Apple External Video Connector Fold the external video cable away from the fan blades[4]
The start-up chords and Sad Mac codes are on Sad Mac Error Codes.
Maintenance and repair
The Performa 630 has the LC 630's logic board and case, and the LC 630 guides apply:
  1. ↑ 1.0 1.1 1.2 1.3 1.4 Macintosh Performa 630 and 630CD: Technical Specifications, Apple—link(accessed 2026-09-30) 68LC040 at 33 MHz, no FPU; slots LC, comm, TV, video in; one ADB; DB-15 video; 45 W maximum, 100-240 V; battery type 4.5 V alkaline; 4 MB on the logic board, one 72-pin SIMM slot, 4-36 MB, 80 ns; introduced 7/1/1994; Gestalt ID 98; System 7.1.2P with System Enabler 405; 250 MB IDE; 19 lb.
  2. ↑ 2.0 2.1 Apple Macintosh Performa 630 (CD) (PC) Specs, EveryMac—link(accessed 2026-09-30) Introduced 18 July 1994, discontinued 1 July 1995; 4 MB or 8 MB; 250 MB IDE; order numbers M3423LL/A (no CD-ROM) and M3424LL/A (630CD); US$1,500 and US$2,250; model M3076; Gestalt ID 98; supported system software 7.1.2P to 8.1.
  3. ↑ Macintosh Quadra 630, Wikipedia—link(accessed 2026-09-30) Quadra and Performa 630 introduced 18 July 1994; codename "Crusader" (citing Jim Heid, "Multimedia Mac", Macworld, September 1994, pp. 98-103).
  4. ↑ 4.00 4.01 4.02 4.03 4.04 4.05 4.06 4.07 4.08 4.09 4.10 4.11 4.12 4.13 4.14 4.15 4.16 4.17 4.18 4.19 4.20 4.21 4.22 4.23 4.24 4.25 Apple Computer, Macintosh Performa 630 Series Service Source (1995), File:Performa 630 series.pdf; see Macintosh Performa 630 Series Service Source. PDF page numbers: title p. 1; General Information pp. 3-6; Product Configuration pp. 7-12; Logic Board Diagram p. 15; Specifications pp. 18-28; Symptom Charts pp. 31-46; Processor Upgrade pp. 100-116; Power Macintosh 5300/6300 Logic Board Upgrade pp. 117-118.
  5. ↑ 5.0 5.1 5.2 5.3 5.4 Apple Computer, LC 630/Quadra 630/Performa 640 Service Source, File:Quadra.lc 630.performa 640.pdf; see LC 630/Quadra 630/ Performa 640 Service Source. Specifications chapter.
  6. ↑ 6.0 6.1 6.2 Performa 630 and LC 630, Low End Mac—link(accessed 2026-09-30) First desktop Mac with an IDE hard drive; CD-ROM is SCSI; LC and Performa 630 have no FPU, which can be added by replacing the 68LC040 with a 68040; one SIMM socket; PRAM battery 4.5 V alkaline; upgrade paths: PowerPC PDS card and 6300-series logic board.
