Macintosh Performa 405
Revision as of 11:57, 10 February 2026 by Josh (talk | contribs) (Specifications)
The Macintosh Performa 405 is a consumer-oriented personal computer introduced by Apple Computer on April 12, 1993.[1] It is a rebrand of the LC II and is identical to the Performa 400, but shipped with 256 KB of VRAM instead of 512 KB and included a 12" Apple color monitor.
TypePersonal Computer
ReleasedApril 12, 1993
DiscontinuedNovember 1, 1993
Intro priceUS$1,300
CPUMotorola 68030 @ 16 MHz
Memory4 MB RAM (expandable to 10 MB)
Storage80 MB SCSI hard drive, 1.44 MB floppy
Display512x384 (8-bit), 640x480 (4-bit)
Sound8-bit mono
Dimensions2.9" H x 12.2" W x 15.3" D
Weight8.8 lbs (4 kg)
OS / FirmwareSystem 7.0P - 7.6.1
PredecessorPerforma 400
SuccessorPerforma 450
Model no.M1700
The Performa 405 uses a Motorola 68030 processor running at 16 MHz with a 16-bit data path. It shipped with 4 MB of RAM (expandable to 10 MB using 30-pin SIMMs) and an 80 MB SCSI hard drive.
Component Specification
CPU Motorola 68030 @ 16 MHz (16-bit data path)
FPU None
System Bus 16 MHz
ROM 512 KB
RAM 4 MB onboard (expandable to 10 MB via 30-pin SIMMs)
VRAM 256 KB (upgradeable to 512 KB)
Storage 80 MB SCSI hard drive, 1.44 MB floppy
Expansion 1x LC PDS slot
Ports ADB, SCSI, 2x Serial (Modem/Printer), Audio out
Display 512x384 @ 8-bit, 640x480 @ 4-bit (256 KB VRAM)
Power 90V-240V AC, 50 W max
Relationship to LC II
The Performa 405 is identical to the LC II internally. The only difference from the Performa 400 is the reduced VRAM configuration (256 KB vs 512 KB).
For detailed maintenance procedures including cleaning, PRAM battery management, and connector maintenance, refer to the Macintosh LC II General Maintenance page.
A troubleshooting guide addressing common issues is available on the Macintosh LC II Troubleshooting page.
Capacitor replacement information for the logic board can be found on the Macintosh LC II Capacitor Replacement Guide page.
  1. Macintosh Performa 405 Specs, EveryMac.com—link(accessed 2026-02-10)
