Atari 800XE
Revision as of 16:19, 29 March 2026 by Josh (talk | contribs) (Creating Atari 800XE article)
The Atari 800XE is an 8-bit home computer produced by Atari Corporation as part of the XE ("XL Enhanced") series. It is functionally identical to the Atari 65XE but was marketed under the "800" designation in certain European countries — most notably Germany, some Eastern European markets, and other territories where the "800" brand carried stronger recognition from the original Atari 800.
Atari 800XE
Atari 800XE Home Computer
ManufacturerAtari Corporation
TypeHome Computer
Released1985
Discontinued1992
Intro priceVaried by market (European distribution)
CPUMOS Technology 6502C @ 1.77 MHz (PAL)
Memory64 KB RAM, 24 KB ROM (OS + BASIC)
StorageExternal cassette tape (410/1010), optional 5.25" floppy disk drive (1050/XF551)
Display320×192 pixels, 40×24 text, 16 colours (256 hue/luminance combinations via ANTIC/GTIA)
SoundPOKEY: 4 voices, 8-bit, noise, envelope, keyboard scan
Dimensions34 cm × 24 cm × 5 cm
Weight1.2 kg
OS / FirmwareAtari OS (in ROM), Atari BASIC Rev. C
PredecessorAtari 800XL
SuccessorAtari XE Game System
Codename
Model no.800XE
The 800XE features 64 KB of RAM, the standard Atari 8-bit custom chipset (ANTIC, GTIA, POKEY, PIA, FREDDIE), and full backward compatibility with the Atari 400/800/XL software library. It shares the same light-grey wedge case design as the 65XE and Atari 130XE.
The 800XE uses the MOS Technology 6502C (Sally) microprocessor running at 1.77 MHz (PAL systems). NTSC versions of the 800XE are extremely rare; the machine was primarily a PAL-market product.
The system architecture is identical to the 65XE:
  • ANTIC (CO21698) — Display list processor for video DMA
  • GTIA (CO14889) — Graphics Television Interface Adaptor for colour video output
  • POKEY (CO12294 / CO12294B) — Sound, keyboard, serial I/O, paddle input
  • PIA (CO14795 / 6520) — Peripheral Interface Adaptor for joystick ports
  • FREDDIE (CO61991 or CO61922) — Memory controller for DRAM timing and bus arbitration
  • MMU (CO61618) — Memory Management Unit (PAL-based address decoder)
Unlike the Atari 130XE, the 800XE does not include an EMMU chip, as it has only 64 KB of RAM with no bank-switching capability.
Memory and Storage
The 800XE is equipped with:
  • 64 KB RAM — typically 8 × 4164 (64K×1) DRAM chips on the earlier CO70067 board, or 2 × 41464 (64K×4) on the later cost-reduced CA200519 board
  • 24 KB ROM, comprising:
    • 16 KB for the operating system (Atari OS)
    • 8 KB for Atari BASIC (Revision C)
Storage options are identical to other XE-series machines:
  • Cassette tape drive (Atari 410/1010)
  • 5.25" floppy disk drive (Atari 1050, XF551)
  • Cartridge slot for instant program loading
Display and Graphics
Video output is managed by the ANTIC and GTIA chips:
  • Resolution up to 320×192 pixels (Graphics mode 8)
  • Text display: 40 columns × 24 rows
  • 16 colours simultaneously from 256 possible hue/luminance combinations
  • Multiple graphics modes with hardware scrolling
  • Player/Missile Graphics (sprites): 4 players and 4 missiles with collision detection
Output options:
  • Composite video via 5-pin DIN monitor port
  • RF modulated output for TV connection (PAL channel selection)
Sound Capabilities
Audio is generated by the POKEY chip:
  • 4 independent audio channels with 8-bit frequency control
  • Selectable clock bases for different frequency ranges
  • Programmable noise generation
  • Volume-only mode for digital audio playback
Input/Output and Expansion
The 800XE provides:
  • Cartridge slot — standard Atari 8-bit cartridge interface
  • SIO port — Serial Input/Output for peripherals
  • Two joystick ports — DE-9 connectors
  • ECI (Enhanced Cartridge Interface) — edge connector for system bus expansion
  • Monitor port — 5-pin DIN (composite video, luma, chroma, audio)
  • RF output — built-in PAL modulator
Differences from the 65XE
The 800XE and 65XE are electronically identical. The differences are purely commercial:
Feature 65XE 800XE
Model number badge "65XE" "800XE"
Target market Worldwide Select European markets
RAM 64 KB 64 KB
Motherboard CO70067 or CA200519 CO70067 or CA200519
Chipset Identical Identical
Case design Identical Identical
Software compatibility Identical Identical
The "800" designation was used because the Atari 800 name had stronger brand recognition in European markets. Some retailers and consumers were confused by the "65" designation, interpreting it as indicating a lower-specification machine.
PCB Variants
The 800XE was produced on the same motherboards as the 65XE:
Board Number RAM Configuration Notes
CO70067 Rev B/C 8 × 4164 (64K×1) Standard XE board with 8 RAM positions populated (of 16 available)
CA200519 2 × 41464 (64K×4) Cost-reduced board, fewer components
