Atari 800XE Capacitor Replacement Guide
Replacing the original electrolytic capacitors ("recapping") in your Atari 800XE is essential preventive maintenance for long-term reliability. The 800XE is electronically identical to the Atari 65XE and uses the same motherboard designs, so all capacitor references, locations, and values in this guide apply equally to both models.
Ageing electrolytic capacitors lose capacitance and develop high ESR (Equivalent Series Resistance) over time, leading to power instability, video artefacts, audio distortion, random crashes, or complete failure to boot. Proactively recapping the board protects the irreplaceable custom chipset (ANTIC, GTIA, POKEY, FREDDIE) from voltage ripple and instability.
editBefore starting, examine all electrolytic capacitors on the mainboard for:
- Bulging or domed tops — indicates internal gas pressure from electrolyte breakdown.
- Leaking electrolyte — brown, green, or white crust around the base or leads. Can corrode PCB traces.
- Discolouration of the PCB beneath or around a capacitor — a sign of past leakage.
- Random resets, video glitches, or audio hum — often the first symptoms of dried-out or high-ESR capacitors, even if they look visually fine.
If any capacitor shows visible signs of failure, it is strongly recommended to replace all electrolytic capacitors on the board as a preventive measure.
Identifying Your PCB Revision
editThe 800XE was manufactured on two different motherboard designs. Identify your board revision before ordering parts, as the capacitor count, values, and locations differ:
| Board Number | RAM Type | Electrolytic Cap Count | Notes |
| C070067 (Rev B/C) | 8 × 4164 DRAM | 11 electrolytic capacitors | Original XE board; through-hole construction |
| CA200519 | 2 × 41464 DRAM | Fewer electrolytics (simplified power path) | Cost-reduced board; some SMD components |
Capacitor List — C070067 Board
editThe C070067 is the original and most common XE motherboard. The following electrolytic capacitors are present:
| Ref. Designator | Capacitance | Voltage Rating | Type | Function / Location |
| C1 | 470 µF | 16 V | Radial | Main +5 V input filter — primary power smoothing |
| C2 | 22 µF | 16 V | Radial | Power decoupling — ANTIC/GTIA area |
| C3 | 22 µF | 16 V | Radial | Power decoupling — CPU/ROM area |
| C10 | 22 µF | 16 V | Radial | Power decoupling — RAM area |
| C19 | 4.7 µF | 35 V | Radial | Video output coupling — composite video path |
| C20 | 4.7 µF | 35 V | Radial | Video chroma coupling — monitor port |
| C22 | 4.7 µF | 35 V | Radial | Video luminance coupling — monitor port |
| C24 | 10 µF | 16 V | Radial | Audio output coupling — amplifier stage |
| C50 | 10 µF | 16 V | Radial | Reset circuit timing capacitor |
| C71 | 22 µF | 16 V | Radial | SIO / serial port decoupling |
| C98 | 10 µF | 16 V | Radial | Power decoupling — peripheral interface area |
Notes:
- All capacitors on the C070067 board are through-hole radial electrolytics.
- C1 (470 µF) is the largest and most critical — a failed C1 causes widespread power instability.
- C24 (10 µF audio coupling) is a common failure point, causing weak or distorted sound.
- C19, C20, and C22 (4.7 µF/35 V) affect video quality — failed caps cause washed-out colours or missing chroma/luma.
Capacitor List — CA200519 Board
editThe CA200519 is the cost-reduced board used in later production 800XE and 65XE units. It uses fewer discrete components and may include some SMD electrolytic capacitors.
| C1 | 470 µF | 16 V | Radial | Main +5 V input filter |
| C2 | 22 µF | 16 V | Radial | Power decoupling |
| C3 | 22 µF | 16 V | Radial | Power decoupling |
| C19 | 4.7 µF | 35 V | Radial | Video output coupling |
| C20 | 4.7 µF | 35 V | Radial | Video coupling |
| C22 | 4.7 µF | 35 V | Radial | Video coupling |
| C24 | 10 µF | 16 V | Radial or SMD | Audio output coupling |
Notes:
- The CA200519 board has fewer electrolytic capacitors due to the simplified power distribution.
- Some later CA200519 revisions may use SMD electrolytic capacitors in certain positions. Replace with equivalent SMD parts, or carefully adapt radial types if SMD replacements are unavailable.
- Always cross-check your specific board's silkscreen — minor layout differences exist between production runs.
Replacement Capacitor Specifications
editWhen sourcing replacement capacitors:
| Parameter | Recommendation |
| Temperature rating | 105 °C (mandatory — do not use 85 °C rated parts) |
| ESR | Low-ESR types preferred (especially for C1 and power decoupling positions) |
| Voltage rating | Use equal or higher voltage rating than the original (never lower) |
| Capacitance | Match original value exactly |
| Brands | Nichicon, Panasonic, Rubycon, United Chemi-Con (avoid generic/unbranded) |
| Lead spacing | 5 mm for most 10–22 µF; 5–7.5 mm for 470 µF (check PCB pad spacing) |
| Maximum height | 18 mm or less — must clear the metal RF shield |
editTools Required
edit- Temperature-controlled soldering iron (15–40 W, fine chisel or conical tip)
- Desoldering pump (solder sucker) and/or desoldering braid (wick)
- Isopropyl alcohol (IPA, 99%) and a small brush or lint-free cloth
- Lead-free or leaded solder, 0.5–0.7 mm diameter
- ESR meter (optional but recommended for testing old capacitors before removal)
- Flush-cut side cutters for trimming leads
- Antistatic wrist strap
- Multimeter for post-recap voltage verification
Step-by-Step Procedure
edit- Disassemble the 800XE: Remove the five case screws from underneath. Gently lift the top case. Disconnect the keyboard membrane cable.
- Remove the mainboard: Unscrew the PCB mounting screws. Carefully lift out the board, noting the orientation of all connectors and any shielding.
- Remove the RF shield (if present) to access all capacitors.
- Document the board: Photograph the board before starting — note the orientation (polarity stripe) of each electrolytic capacitor.
- Desolder old capacitors: Heat each lead from the underside and use a desoldering pump or wick to remove solder. Gently pull the capacitor free once both leads are clear. Do not force — you risk lifting pads.
- Clean the pads: Remove old flux and any leaked electrolyte residue using IPA and a brush. Inspect pads and nearby traces for corrosion damage.
- Install new capacitors: Observe correct polarity — the longer lead is positive; the silkscreen typically marks the negative (–) pad with a stripe or filled half-circle. Insert the new capacitor, bend leads slightly to hold it in place, and solder from the underside.
- Trim leads: Cut flush with the solder joint using side cutters.
- Inspect all joints: Check for solder bridges, cold joints, or missed connections.
- Reassemble: Refit the RF shield, mainboard, keyboard cable, and case.
Post-Recap Verification
editAfter recapping, verify correct operation before reassembling the case:
Voltage and Ripple Checks
edit| Test Point | Nominal Value | Acceptable Range | Maximum Ripple (peak-to-peak) |
| +5 V at mainboard input (C1) | 5.00 V | 4.85–5.15 V | < 50 mV |
| +5 V at CPU pin 8 | 5.00 V | 4.85–5.15 V | < 50 mV |
| +5 V at ANTIC pin 40 | 5.00 V | 4.85–5.15 V | < 50 mV |
| +5 V at GTIA pin 24 | 5.00 V | 4.85–5.15 V | < 50 mV |
| +5 V at RAM Vcc | 5.00 V | 4.85–5.15 V | < 50 mV |
Functional Checks
edit- Boot test: Power on — the system should display the blue READY screen within 2–3 seconds.
- Audio test: Press keys to hear key-click sounds. Load a program with sound if possible.
- Video quality: Check for clean, stable video via composite output. No jitter, rolling, or colour bleed.
- Keyboard test: Verify all keys respond correctly.
- Peripheral test: Connect an SIO device (disk drive or SIO2SD) and verify communication.
Power Supply (External)
editThe 800XE uses an external +5 V DC power supply. If you observe unstable voltages or excessive ripple after recapping the mainboard, the PSU itself may need attention:
| Capacitance | Voltage | Notes |
| 2200 µF | 16 V or 25 V | Main filter capacitor inside PSU enclosure |
Warning: The external PSU contains mains-voltage components. Only open and service it if you are experienced with mains electrical safety. Discharge all capacitors before working inside.
Troubleshooting After Recapping
editIf the 800XE does not boot correctly after recapping:
- Check polarity of all new capacitors — a reversed electrolytic will fail quickly and may damage the board.
- Inspect for solder bridges between adjacent pads or traces.
- Verify no pads were lifted during desoldering — repair with thin wire jumpers if necessary.
- Re-check voltages at all IC Vcc pins to ensure power is reaching the entire board.
- Test with a current-limited power supply (if available) for the first power-on after recapping — this protects against short circuits.
For further diagnostic procedures, see the Atari 800XE Troubleshooting Guide.
Additional Tips
edit- Always check the PSU first — a failing external PSU can damage newly installed capacitors.
- Keep capacitor height under 18 mm to ensure the metal RF shield fits correctly.
- Double-check polarity before soldering — reversed electrolytics can burst or explode.
- Clean all leaked electrolyte thoroughly — it is corrosive and will continue to eat traces if left in place.
- Power up with a fuse or current-limited supply for the first test after recapping.
- Consider adding IC sockets while the board is open — this makes future chip testing and replacement much easier.
Related Pages
edit- Atari 800XE
- Atari 800XE General Maintenance
- Atari 800XE Troubleshooting Guide
- Atari 65XE Capacitor Replacement Guide
