Amstrad ALT-286 / ALT-386SX Service Manual
Revision as of 00:32, 2 October 2026 by Josh (talk | contribs) (New page from Amstrad's ALT286/ALT386SX service manual and owners' restoration reports)
The ALT286 / ALT386SX Laptop Computer V.FTZ Service Manual is Amstrad plc's service manual for its two laptops, the Amstrad ALT-286 and Amstrad ALT-386SX. The hosted scan has 38 pages and no text layer; the printed pages run to 26, and the large schematics are split across several scan pages. No part number, price or issue date is printed.
Contents
Amstrad's contents list, with printed page numbers:
Section Page
Technical specifications; safety tests 2
ALT286/386SX LCD inverter PCB 3
ALT286/386SX keyboard PCB 4
ALT286/386SX expansion slot PCB 5
ALT286 co-processor PCB, top and bottom views 6–7
ALT286/386SX VGA PCB, top and bottom views 8–9
ALT286/386SX electrical parts list 10–11
Cabinet parts list 12
Cabinet exploded view 13
ALT286 main PCB, top and bottom views 14–15
ALT386SX main PCB, top and bottom views 16–17
ALT286 main PCB schematic diagrams (1) and (2) 19–20
ALT286 co-processor/memory schematic diagram 21
ALT286/386SX VGA schematic diagram 22
ALT286/386SX peripheral schematic diagram 23
ALT386SX main PCB schematic diagrams (1) and (2) 24–25
ALT386SX co-processor/memory schematic diagram 26
What it covers
The specification on page 2 compares the two models side by side: an 80286 or 80386SX at 16 MHz switchable to 8 MHz; 1 wait state on the ALT286 and 0.6 on the ALT386SX, or none with 60 ns DRAM; 1 MB of RAM with 2 MB and 4 MB upgrades; one half-length 16-bit slot; a 20 MB (28 ms) or 40 MB (25 ms) voice-coil hard disk; a 1.44 MB 3.5-inch floppy drive; VGA, EGA, CGA, MDA and Hercules graphics on a backlit 640 × 480 LCD of 223 × 169 mm with 32 grey scales; an internal 110/220/240 V self-switching power supply; a removable NiCd battery pack giving two hours, with a two-hour quick charge; 318 × 380 × 95 mm; and 7.00 kg with the battery, 6.00 kg without. The same page gives the safety tests: a 1.5 kV RMS flash test for 3 seconds, an insulation test at the same voltage requiring more than 4 MΩ, and a mains-lead earth resistance of no more than 0.5 Ω.
The electrical parts list on page 10 gives the PCBs, ICs (including the VLSI VL82C-series chip set, the Cirrus Logic CL-GD610 and CL-GD620 VGA controllers, the MC146818AF real-time clock and the BIOS EPROMs), switches, diodes, transistors, coils, crystals and miscellaneous parts; page 11 lists the parts that differ on the ALT386SX. The cabinet parts list on page 12 gives the mechanical parts and the replaceable units: the NiCd battery pack, keyboard unit, LCD unit, hard disk, floppy disk unit, power supply unit and fan motor.
  • No capacitor or resistor values in the parts lists. They appear only on the schematics.
  • No schematic or parts list for the power supply, which Amstrad lists only as a complete unit (UN-1, part 270492).
  • No fault-finding charts, test points, adjustment procedures or disassembly instructions beyond the exploded view.
  • No text layer.
Pages that cite this document
Download: Amstrad ALT286 ALT386SX Service Manual.pdf
