Amstrad PC3386SX
Revision as of 05:37, 2 October 2026 by Josh (talk | contribs) (Link the PC2386 page)
Amstrad PC3386SX
PC3386SX with monitor and keyboard, from Amstrad's 1990 leaflet
ManufacturerAmstrad plc
TypeDesktop personal computer (IBM PC/AT compatible)
Released1990
Intro priceDM 4,699 with 14-inch VGA monitor (Germany, 1991)
CPUIntel 80386SX at 20 MHz on a plug-in processor board; 80387SX socket
Memory1 MB, expandable to 4 or 16 MB with four identical SIMMs; optional 64 KB cache
Storage3.5-inch 1.44 MB floppy drive; 40 MB AT-IDE hard disk, 100 MB optional
Display—
Sound—
GraphicsBuilt-in Paradise VGA with 256 KB, up to 800 × 600 on a multi-frequency monitor
Ports / interfaceParallel (25-way), RS232 serial (25-way), Amstrad mouse, VGA, monitor power outlet
ExpansionTwo full-length and one half-length 16-bit ISA slots, one full-length and one half-length 8-bit
Power145 W internal supply with 100–120 / 200–240 V selector
Dimensions425 × 135 × 390 mm (W × H × D)
OS / FirmwareMS-DOS 3.30A
The Amstrad PC3386SX is the top model of Amstrad's "Generation 3" desktop PCs of 1990, alongside the Amstrad PC3086 and Amstrad PC3286. It uses the PC3286's main board and case with a 20 MHz 80386SX on its own processor daughterboard, and was sold with a 40 MB hard disk as standard.[1][2][3] Amstrad PC International tested one with the optional 100 MB Conner drive in 1991 and called it the flagship of the range.[4]
PC3386SX (Amstrad leaflet and user manual)
Item Value
Processor 80386SX at 20 MHz, slowed to 10, 7, 5 or 4 MHz by software; 80387SX socket
Memory 1 MB parity-checked, 32 bits wide, expandable to 4 or 16 MB; built-in LIM expanded memory
Cache 64 KB of 35 ns cache RAM, optionally fitted
Floppy drive 3.5-inch 1.44 MB
Hard disk 40 MB IDE, 28 ms; 100 MB Conner as an option
Expansion Two full-length and one half-length 16-bit ISA slots, one full-length and one half-length 8-bit; expansion bus at 8 MHz
Video Paradise VGA with 256 KB on the main board; 640 × 480, or 800 × 600 with a multi-frequency monitor
Power supply 145 W
Size 425 × 135 × 390 mm; keyboard 475 × 35 × 200 mm
Software MS-DOS 3.30A
Sources: Amstrad's leaflet and manual, and Amstrad PC Internationals test.[1][5][3][4] The specification page of Amstrad's manual gives the processor as 16 MHz, but the leaflet, the magazine and the manual's own DEVICE example all give 20 MHz.[5][6]
The main board, links, SIMM sockets, cache, video and drive interfaces are those of the PC3286 and are described in the Amstrad PC3286 Maintenance Guide.[3] The differences are on and around the processor board:
  • The 80386SX and the 80387SX co-processor socket are on a daughterboard that plugs into the main board. Link LK720 on that board enables or disables pipelining.[2][3]
  • The 386SX reads memory 32 bits wide, so the four SIMM sockets must hold four identical modules, giving 1, 4 or 16 MB.[7]
  • Links LK500 and LK501, where present, sit on pins 1 and 2, not on pins 2 and 3 as on the PC3286.[3]
Amstrad PC International listed the standard drive as a 40 MB Miniscribe AT-bus disk with a 28 ms average access time and the power supply as 145 W, and noted the speaker volume control and the mixture of horizontal and vertical slots.[4] The clock data is kept in a CMOS RAM with a built-in lithium battery, which Amstrad's leaflet quotes for a 10-year life.[8][1]
Software and configuration
The PC3386SX shipped with MS-DOS 3.3 on two 5.25-inch disks and one 3.5-inch disk. Amstrad's automatic hard disk installation did not work on the magazine's machine with the optional 100 MB drive, because the routines were not written for a disk of that size, and the drive had to be prepared by hand.[4] SETUP, DEVICE and the memory managers are the same as on the PC3286; on the 386SX the manual also describes MEMM.SYS /E as a "LIMulator" that turns extended memory into LIM expanded memory, at some cost in speed, loaded after HIMEM.SYS.[9][6][10]
Known faults
Faults shared with the PC3286 board, and the 386SX specifics, are in the Amstrad PC3386SX Troubleshooting Guide; maintenance is in the Amstrad PC3386SX Maintenance Guide. No capacitor list has been published: Amstrad's service manual for the range (SM-PC3000) has not been scanned.[11][12]
  1. ↑ 1.0 1.1 1.2 Amstrad plc, PC3386SX leaflet, © August 1990, p. 2 (specification). Hosted as File:Amstrad PC3386SX leaflet (1990).pdf.
  2. ↑ 2.0 2.1 Amstrad plc, User Manual and MS-DOS Guide for the PC3086, PC3286 and PC3386SX, 2nd ed. (1990), pp. 7-1 to 7-7. Processor speeds, fitting an 8087, 80287 or 80387SX co-processor, and opening the system unit.
  3. ↑ 4.0 4.1 4.2 4.3 Thomas Kallay, "Big Brother: AMSTRADs Flaggschiff der Generation 3: der PC3386 SX", Amstrad PC International, February/March 1991, pp. 41–42. Internet Archive. Retrieved 2026-10-02. Specification table and test of a PC3386SX with a 100 MB Conner disk.
  4. ↑ 5.0 5.1 Amstrad plc, User Manual and MS-DOS Guide for the PC3086, PC3286 and PC3386SX, 2nd ed. (1990), pp. 1-2 to 1-4. Specifications of the three models and memory configuration.
  5. ↑ 6.0 6.1 Amstrad plc, User Manual and MS-DOS Guide for the PC3086, PC3286 and PC3386SX, 2nd ed. (1990), pp. 4-2 to 4-18. The DEVICE command: display, floppy drive, cache, memory map and processor speed settings.
  6. ↑ Amstrad plc, User Manual and MS-DOS Guide for the PC3086, PC3286 and PC3386SX, 2nd ed. (1990), pp. 8-6 to 8-10. Memory cache, SIMM upgrades, memory size and DRAM speed links, cache speed links.
  7. ↑ Amstrad plc, User Manual and MS-DOS Guide for the PC3086, PC3286 and PC3386SX, 2nd ed. (1990), pp. 13-2 to 13-4. Transporting a hard disk PC, PARK.COM, and replacing the CMOS RAM.
  8. ↑ Amstrad plc, User Manual and MS-DOS Guide for the PC3086, PC3286 and PC3386SX, 2nd ed. (1990), pp. 3-7 to 3-15. Voltage selector, power switch, the "Please wait." self-test dots, start-up messages and BIOS versions, and the SETUP program for the PC3286 and PC3386SX.
  9. ↑ Amstrad plc, User Manual and MS-DOS Guide for the PC3086, PC3286 and PC3386SX, 2nd ed. (1990), pp. 8-2 to 8-5. Base, expanded and extended memory, HIMEM, and LIMulators (MEMM.SYS /E) on the PC3386SX.
  10. ↑ Centre for Computing History, "Amstrad PC3086 PC3286 PC3386SX Colour Personal Computers Service Manual" (CH27476): 53-page service manual with schematics and wiring diagrams, reference SM-PC3000. Retrieved 2026-10-02.
  11. ↑ acpc.me (ACME) archive, Amstrad PC section, directory DOCUMENTS_TECHNIQUES/SERVICE_MANUALS. Retrieved 2026-10-02. The PC3086/PC3286/PC3386SX, PC4386SX and PC5086/PC5286 service manuals are listed with placeholder images only, marked missing.
