Amstrad PCW 8256 Capacitor Replacement Guide
Revision as of 06:36, 2 October 2026 by Josh (talk | contribs) (New page: electrolytic list from the service manual parts list, procedure and supply settings)
PCW8256/8512 monitor board; the outlined area is at mains potential (service manual p. 21)
The Amstrad PCW 8256 keeps its power supply on the monitor board, so the electrolytic capacitors that matter most for the whole machine, printer included, are in the monitor unit. Amstrad's service manual lists every electrolytic with its value, voltage and part number. The list of parts that differ on the Amstrad PCW 8512 contains no electrolytic capacitors, so the same list covers both machines.[1]
Safety
Warning: the monitor unit runs from the mains and contains a CRT. The 100 µF 400 V reservoir C5005 holds a dangerous charge after the plug is pulled.
  • Unplug the machine, remove the back and discharge the tube; see CRT Discharge Procedure.
  • Measure across C5005 and discharge it through a suitable resistor before touching the board. Amstrad's board drawing outlines the mains area and marks it "danger mains voltage".[1]
  • After the work, run Amstrad's safety tests: a 4 kV flash test, and an insulation resistance of at least 4 MΩ, both between the joined mains live and neutral and all accessible metal on the outside.[1]
How the parts are numbered
Amstrad numbers parts in series by area. The 5000 series is the power supply (IC5001 STK7308, switching transformer T5001, mains fuse F5001); the 4000 series is the deflection circuit (IC4001 LA1385, IC4002 AN5753, horizontal drive transformer T4001); the 100 series is the CPU board (IC101–IC120); the 800 series is the keyboard (keyboard controller IC801); the 8000 series includes the CRT socket J8001; and the 2000 series includes the brightness control VR2001.[1] The printer's own board uses the 700 series and has its own parts list.[1]
Electrolytic capacitors
Electrolytic capacitors, monitor, CPU and keyboard (service manual p. 34)
Ref Value Voltage Amstrad part no.
C5028 0.33 µF 50 V 171086
C4001 0.47 µF 50 V 150909
C803 1 µF 50 V 20062
C4029 1 µF 160 V 1422151
C5006 1 µF 250 V 1400152
C4006, C4020 4.7 µF 50 V 1400240
C122, C4010, C4015 10 µF 16 V 20024
C4032 10 µF 25 V 20037
C2001, C5020–C5023 10 µF 50 V 1400242
C4030 10 µF 160 V 170608
C4008 22 µF 16 V 20025
C8001 22 µF 63 V 170609
C4012 33 µF 10 V 170610
C5024 33 µF 50 V 171087
C121, C124, C805 47 µF 10 V 1400244
C4031 47 µF 50 V 171088
C2002 100 µF 16 V 20028
C5012 100 µF 50 V 171089
C5005 100 µF 400 V 171090
C4011 220 µF 10 V 170611
C4021, C4025, C4026, C4033 220 µF 16 V 20029
C5007 220 µF 35 V 20055
C5025 470 µF 10 V 20031
C5017, C5027 470 µF 16 V 1400248
C5018, C5026 470 µF 35 V 171091
C5019 470 µF 50 V 171092
C4014 1000 µF 10 V 800372
The same list gives two tantalum capacitors, C4007 (1 µF 50 V, 171100) and C4009 (10 µF 16 V, 1422167), and a 0.1 µF 250 V "special type" at C5001 (171102).[1]
Electrolytic capacitors, printer board MS0030B (service manual p. 34)
C719 47 µF 10 V 20027
C720 1000 µF 35 V 171207
The manual's short Mk II parts list changes the mains filter coil (L500), the switching transformer (T5001, part 171227), the vertical hold control and two ceramic resonators, and lists no different capacitors.[1] Boards in the field may still differ from the drawings, so read the value and voltage printed on each part before removing it.
Where to start
The 5000-series electrolytics belong to the power supply, which feeds the whole machine including the printer. If the 12 V or 5 V output is low, noisy or will not adjust into tolerance, start with these. The 4000-series parts are in the deflection circuit. See Capacitor Failure Symptoms for what failed parts look like.[1]
Procedure
  1. Unplug the machine, remove the back of the monitor unit, and discharge the CRT and C5005.
  2. Photograph the board and note the value, voltage and polarity of each electrolytic before removing it.
  3. Remove each capacitor and clean the pads. Check under the larger supply capacitors for leaked electrolyte and corroded tracks.
  4. Fit new parts of the same capacitance and the same or a higher voltage rating, observing polarity. For C5005, use a 400 V part.
  5. Inspect and reflow any cracked joints on the switching transformer, the STK7308 and the other heavy parts.
  6. Reassemble, then check and set the supply outputs before refitting the back.
After the recap
Set the supply outputs as Amstrad's alignment chart specifies, with connector CD101 disconnected and the brightness control VR2001 at maximum:[1]
Supply settings (service manual p. 17)
Output Measure at Set with Tolerance
12 V Pin 2 of CD102 VR5002 ±2%
5 V Pin 3 of CD102 VR5001 ±2%
Then reconnect CD101, check the picture adjustments in the Amstrad PCW 8256 Maintenance Guide, and repeat Amstrad's safety tests.[1]
  1. ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 Amstrad, PCW 8256/8512 Personal Computer Word Processor Service Manual. Hosted as File:Amstrad PCW 8000 Series Service Manual.pdf, described at Amstrad PCW 8256 / PCW 8512 Service Manual. Safety tests p. 2; monitor alignment chart p. 17; monitor board layout p. 21 (PDF p. 22); monitor/keyboard and CPU electrical parts list p. 33 (PDF p. 34); electrical parts list, PCW8512 differences and printer electrical parts list p. 34 (PDF p. 35).
