Amstrad Mega PC Capacitor Replacement Guide
The Amstrad Mega PC has three sets of electrolytic capacitors: on the main board, which is the PC7386SX board; on the Mega Drive games card; and in the PC14DSM monitor sold with it. Amstrad's PC7386SX parts list does not list capacitors, so the main-board values below are read from the PC7386SX circuit diagrams. The monitor values are from the PC14DSM parts list in the Mega PC service manual.[1][2]
Safety
[edit | edit source]Warning: the power supply module and the monitor carry mains voltage, and the monitor's CRT and its 400 V reservoir capacitor hold a charge after switch-off. Unplug both and read CRT Discharge Procedure before working in the monitor. Amstrad's safety tests after any work are on the Amstrad Mega PC Maintenance Guide.[1]
Main board
[edit | edit source]The main board runs from +5 V, +12 V, −5 V and −12 V supplied by the power module.[1]
| Ref | Value as printed | Sheet | Position on the schematic |
| C1 | 33 µF 25 V | 1/13 | At the power header |
| C2 | 33 µF 15 V | 1/13 | +5 V at the power header |
| C119, C120, C121 | 10 µF 25 V | 1/13 | +5 V rail (drawn at the power header) |
| C4 | 10 µF 25 V | 1/13 | +12 V |
| C5 | 10 µF 25 V | 1/13 | −12 V (positive lead to ground) |
| C6 | 10 µF 25 V | 1/13 | −5 V (positive lead to ground) |
| C3 | 10 µF 16 V | 1/13 | Front panel reset line, with R5 (300 Ω) |
| C20, C21 | 10 µF 25 V | 2/13 | SIMM supply |
| C60 | 1 µF 16 V | 6/13 | WD76C20 battery supply (VBATT) |
| C131 | 10 µF 16 V | 12/13 | ICS1394 clock synthesiser supply |
| C132 | 10 µF 16 V | 12/13 | ICS1394 analogue supply, fed from +12 V through R51 and the 5.1 V zener D14; fitted with the ICS1394 only (the table on sheet 12/13 leaves it out, with R51, R52, R54, R55, D12 and C135, when an ICS1494 is used) |
| C141 | 1 µF 16 V | 12/13 | Beside R57 on the ICS1394 filter pins |
| C137 | 10 µF 25 V | 13/13 | RAMDAC analogue supply (VAA) |
| C110, C111 | 10 µF 25 V | 13/13 | Bulk capacitors on the video section's decoupling row (U51–U54, U56, U58) |
C2 is printed as 15 V on the schematic; fit a 16 V or higher part. C5 and C6 sit on the negative rails, so their positive leads go to ground; check the board marking before fitting.[1] The other capacitors on the sheets are ceramic decoupling parts with no polarity mark. Count the electrolytics on your own board against this list: the PC7386SX manual draws board VSC386SXD V.2.01, the marking on the Mega PC board photographed for Commons.[1][3]
The board has one more electrolytic that is not on the circuit diagrams: C140, beside R16 and R17 near the coprocessor socket U14. It is drawn on the PC7386SX top view and fitted on the photographed Mega PC board, but no value is published for it, so read the value and voltage printed on the part before removing it.[1][3] The three +5 V capacitors that sheet 1/13 draws at the power header are spread over the board: on the photographed board C120 is beside the 74LS245 at U44 by the ISA riser connector, C119 beside SIMM bank 0 and C121 beside U22.[3]
Games card
[edit | edit source]The games card's circuit diagrams and PCB views are in the Mega PC service manual, but the only available scan is about 90 dpi and the component values on the circuit diagrams cannot be read.[2] Record the value and voltage printed on each capacitor before removing it. A photograph of the fitted card shows a number of small radial electrolytics around the sound and video sections.[4]
Power supply module
[edit | edit source]Neither manual includes a circuit or parts list for the supply module (part 273888); Amstrad treated it as a replaceable unit.[2][1] Its capacitors must be read from the parts themselves. The primary side carries rectified mains.
PC14DSM monitor
[edit | edit source]The monitor's parts list (Mega PC service manual, PDF p. 32) gives these electrolytics. The scan is low resolution: the values and voltages are clear, but a few reference numbers are hard to read, so check each against the board.[2]
| Value | References as printed |
| 150 µF 400 V | C010 |
| 100 µF 160 V | C032, C522 |
| 47 µF 200 V | C524 |
| 33 µF 160 V | C041 |
| 100 µF 100 V | C022, C062, C063 |
| 10 µF 100 V | C842, C850 |
| 4.7 µF 100 V | C804, C814, C824 |
| 2.2 µF 100 V | C009, C011 |
| 1000 µF 25 V | C071 |
| 470 µF 35 V | C052 |
| 220 µF 35 V | C053, C514 |
| 2200 µF 16 V | C409 (last digit unclear) |
| 220 µF 16 V | C843 |
| 100 µF 35 V | C408 or C409 (last digit unclear) |
| 100 µF 16 V | C106, C117 |
| 47 µF 50 V | C529 |
| 47 µF 35 V | C104, C212 |
| 47 µF 25 V | C413 |
| 47 µF 16 V | C101, C111, C201, C601, C602, C625, C627 |
| 33 µF 35 V | C513 |
| 22 µF 16 V | C515 |
| 10 µF 50 V | C103, C422, C530, C626 |
| 4.7 µF 50 V | C014 |
| 2.2 µF 50 V | C102, C202, C302, C415 |
| 1 µF 50 V | C503, C510 |
C010, 150 µF 400 V, is the only 400 V electrolytic in the list; replace it with a 400 V part. The list also gives a 0.47 µF 250 V AC capacitor across the line (C001) and 2200 pF 250 V AC capacitors C003 to C006, which are safety parts.[2] See Capacitor Failure Symptoms.
Replacement procedure
[edit | edit source]- Unplug the system unit and the monitor. Open the case as described in the Amstrad Mega PC Maintenance Guide, and discharge the monitor's CRT before working in it.
- Photograph each board and note the polarity of every electrolytic, including the reversed parts on the negative rails.
- Remove one capacitor at a time with a desoldering iron or braid, clean the pads and check them for corrosion.
- Fit parts of the same capacitance and the same or a higher voltage rating.
- After reassembly, measure the rails at the main board's power header and check the monitor in both PC and game modes.
[edit | edit source]- Amstrad Mega PC · Amstrad Mega PC Maintenance Guide · Amstrad Mega PC Troubleshooting Guide
- Capacitor Failure Symptoms · CRT Discharge Procedure · Recommended Tools
[edit | edit source]- ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 Amstrad plc, PC7386SX Personal Colour Computer Service Manual, first published October 1992. Hosted as File:Amstrad PC7386SX Service Manual.pdf, described at Amstrad PC7386SX Service Manual. Main PCB top view p. 3; schematic diagrams 1/13 (p. 5), 2/13 (p. 6), 6/13 (p. 10), 12/13 (p. 16) and 13/13 (p. 17); electrical parts list p. 19.
- ↑ 2.0 2.1 2.2 2.3 2.4 Amstrad plc, MEGAPC3H40 with Games Card / PC14DSM 14" Dual Synch Colour Monitor Service Manual. Hosted as File:Amstrad Mega PC Service Manual.pdf, described at Amstrad Mega PC Service Manual. Note to engineers (PDF p. 3); games card circuit diagrams (pp. 7–22); PC14DSM parts lists (pp. 31–32).
- ↑ 3.0 3.1 3.2 Mister rf, "Amstrad VSC386SXD V2.01.jpg", Wikimedia Commons, 2022 (CC BY-SA 4.0). Retrieved 2026-10-02. Mega PC main board marked VSC386SXD V2.01: the silkscreen C120 beside U44, C140 beside R16 and R17, SIMM sockets fitted to banks 0 and 1 only.
- ↑ Bungle, "MegaPC ISAcard.jpg", Wikimedia Commons, 2007 (CC BY-SA 3.0). Retrieved 2026-10-02. The Mega Drive games card fitted in a Mega PC.
