Amstrad PC2086 Troubleshooting Guide
Amstrad PC2086 main PCB layout
PC2086 main board MC0065 (service manual p. 7)
Amstrad's service manual for the Amstrad PC2086 has no fault-finding charts. Its notes to engineers rule out component-level repair of the main CPU board, which was replaced once a fault was confirmed, and of the floppy and hard disc drives; the parts list and schematics are there for the supply and the monitors.[1] The faults below combine the manual with owners' reports. Procedures are in the Amstrad PC2086 Maintenance Guide.
Start-up
If the processor and display are working, "Please wait" appears at switch-on.[2] Fitting all three links LK1–LK3 makes the BIOS skip most of its self-test, for diagnosis; the PC2086 BIOS has no language selection on these links. LK4 on pins 1 and 2 reduces the memory to 512 KB, which isolates a fault in the top 128 KB.[3]
Measure the rails with the main board and drives connected; the supply's test points and adjustment are in the maintenance guide. Amstrad's targets are 5.15 V ±0.1 V, 12.15 V ±0.2 V, −5 V ±0.1 V and −12.00 V ±0.2 V.[1]
Supply faults reported by owners
Symptom What was found
Low +12 V and −5 V on an unloaded supply, machine working Normal: one owner read 5.17 V, 8.62 V and −3.36 V with no load on a machine that ran happily. Measure under load before condemning the supply[4]
No output after a full recap; +5 V rises to about 10 V then falls to zero, with a click a few seconds after switch-off; no +12, −12 or −5 V; R607 and R609 on the primary side getting hot Unresolved in the report. The owner had replaced the electrolytics, zener diodes, both comparators and other diodes, and saw no waveform at the protection adjustment step[4]
Random freezes, the supply fan sometimes running and sometimes not, pops from the speaker Reported with corrupted screen output and failure to boot; check the rails and the fan's supply before suspecting the main board[4]
The owner who redrew the supply schematic found the PC1640 monitor's supply circuit close enough to the PC2086's to use as a cleaner reference; the PC2086 supply uses an STK7356 hybrid regulator with BA6993, LA6324 and BA707 control ICs, parts also found in the PC1512 and PC1640 monitor supplies.[4][1] The optocouplers are TLP732s at Q604 and Q605.[1]
Display
  • No picture from the built-in VGA: check the DIP switches. SW4 on disables the built-in VGA. John Elliott suggests all switches off except SW6 as a safe setting.[5]
  • Windows 3.0 goes to a black screen and crashes when installed with the VGA driver: this is a limitation of the 8086, not a fault. Use the CGA driver, the 8086-compatible VGA driver written in 2013, or an NEC V30.[2]
  • With an MDA or Hercules card added for a second screen, SW6 must be off.[5]
The PC12 and PC14 monitors have their own sections in the service manual, with parts lists and schematics; Amstrad allowed component-level repair of them.[1] See CRT Discharge Procedure.
Keyboard and key lock
  • Key lock fault at start-up: the lock (SW102) is a switch on the case that does not lock the case itself. Owners disconnect it inside the case.[1][6]
  • The keyboard and mouse use Amstrad's own interfaces, so a failed keyboard cannot be replaced by a standard one; an unworking mouse can be replaced with a serial mouse on the serial port.[6]
Hard disc
The /30's original RLL controllers proved defective, and many machines had the drive disconnected and a hard card fitted instead.[7] A surviving original drive reporting "not ready" or bad sectors is best copied off and replaced with an XT-IDE CompactFlash card or a SCSI controller and disc.[4][8] If an XT-IDE card freezes the machine at start-up, check its ROM and I/O addresses for conflicts.[4] See Hard Drive Maintenance and Repair.
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 Amstrad plc, PC2086 S/D/30 Personal Computer / PC12 MD / PC12 HRCD / PC14 CD / PC14 HRCD Monitors Service Manual. Hosted as File:Amstrad PC 2086 Service Manual.pdf, described at Amstrad PC 2086 Service Manual. Alignment instructions and notes to engineers p. 3; electrical parts list p. 4; schematics pp. 10–18.
  2. ↑ 2.0 2.1 John Elliott, "Replacing the PC2086 processor", seasip.info, 23 February 2013. Retrieved 2026-10-02. The "Please Wait" message as a test of a newly fitted processor, the case and supply removal, Windows 3.0 in VGA mode crashing to a black screen on an 8086.
  3. ↑ John Elliott, "PC2086 option links", seasip.info, 14 May 2004. Retrieved 2026-10-02. LK1–LK3 diagnostic mode, LK4 memory size, LK5 ROM size, LK6 write precompensation.
  4. ↑ 4.0 4.1 4.2 4.3 4.4 4.5 dorje, Ghislain, misna and others, "Amstrad PC2086 PSU", Vintage Computer Federation Forums, June 2020 – November 2024. Retrieved 2026-10-02. Community reports: unloaded readings on a working supply; a supply that would not start after a full recap, with +5 V rising to 10 V and falling, R607 and R609 running hot and no waveform at the protection adjustment; random freezes with the fan sometimes stopped; the observation that the PC1640's supply schematic closely resembles the PC2086's.
  5. ↑ 5.0 5.1 John Elliott, "PC2086 DIP switches", seasip.info, 3 July 2004. Retrieved 2026-10-02. The eight switches of the Paradise VGA and the safe setting.
  6. ↑ 6.0 6.1 cwathen and kuro68k, "PC2086 advice", Vintage Computer Federation Forums, August 2019. Retrieved 2026-10-02. Community comments: the key lock fault and disconnecting the lock, the proprietary keyboard and mouse interfaces, a PC2086D with no hard disc.
  7. ↑ John Elliott, "Amstrad XTs: Models", seasip.info, 19 April 2013. Retrieved 2026-10-02. The defective RLL controllers of hard disc PC2086s and their replacement by hard cards.
  8. ↑ John Elliott, "Replacing the PC2086 hard drive", seasip.info, 15 June 2004. Retrieved 2026-10-02. Replacing the hard disc with a SCSI controller and drive.
