Atari VCS (2020) Documentation
The Atari VCS (2020) documentation below is Atari's pair of upgrade guides for the Atari VCS console, published through its support site in 2024.
RAM Installation Manual
The RAM Installation Manual is a 10-page illustrated guide, © 2024 Atari Interactive, Inc., linked from Atari's support article "SSD & RAM Upgrade". It gives the memory compatibility (DDR4-2400 SODIMMs, fitted in pairs, up to 32 GB), the tools (a T10 Torx driver or hex key) and 20 steps for opening the console, lifting the main board, changing the two modules and putting everything back.[1]
Download: Atari VCS RAM Installation Manual (2024).pdf
M.2 SSD Drive Installation Manual
The M.2 SSD Drive Installation Manual is a 7-page illustrated guide from the same source. It explains the difference between SATA M.2 drives, which the VCS accepts, and NVMe drives, which it does not, and gives 13 steps for opening the console and fitting the drive.[1]
Download: Atari VCS M.2 SSD Drive Installation Manual (2024).pdf
What these guides do not contain
  • A schematic, parts list, power supply rating or any fault-finding procedure.
  • Anything on the built-in eMMC storage or the controllers.
Pages that cite these guides
  • Atari VCS (2020): memory and storage specifications, opening the case, fitting an SSD and changing the memory
  1. ↑ 1.0 1.1 Atari support, "SSD & RAM Upgrade" (article 17483665679003, support.atari.com), which links both guides on Google Drive.
