Macintosh Performa 430
(Redirected from Performa 430)
TypePersonal Computer
ReleasedOctober 18, 1993
DiscontinuedNovember 1, 1993
Intro priceUS$1,500
CPUMotorola 68030 @ 16 MHz
Memory4 MB RAM (expandable to 10 MB)
Storage120 MB SCSI hard drive, 1.44 MB floppy
Display512x384 (8-bit), 640x480 (4-bit)
Sound8-bit mono
Dimensions2.9" H x 12.2" W x 15.3" D
Weight8.8 lbs (4 kg)
OS / FirmwareSystem 7.0P - 7.6.1
PredecessorPerforma 405
SuccessorPerforma 450
Model no.M1700
The Macintosh Performa 430 is a consumer-oriented personal computer introduced by Apple Computer on October 18, 1993.[1] It is a rebrand of the LC II and is identical to the Performa 405, but shipped with a larger 120 MB hard drive.
The Performa 430 uses a Motorola 68030 processor running at 16 MHz with a 16-bit data path. It shipped with 4 MB of RAM (expandable to 10 MB using 30-pin SIMMs), 256 KB of VRAM (upgradeable to 512 KB), and a 120 MB SCSI hard drive.
Component Specification
CPU Motorola 68030 @ 16 MHz (16-bit data path)
FPU None
System Bus 16 MHz
ROM 512 KB
RAM 4 MB onboard (expandable to 10 MB via 30-pin SIMMs)
VRAM 256 KB (upgradeable to 512 KB)
Storage 120 MB SCSI hard drive, 1.44 MB floppy
Expansion 1x LC PDS slot
Ports ADB, SCSI, 2x Serial (Modem/Printer), Audio out
Display 512x384 @ 8-bit, 640x480 @ 4-bit (256 KB VRAM)
Power 90V-240V AC, 50 W max
Relationship to LC II
The Performa 430 is identical to the LC II internally. It differs from the Performa 405 only in having a 120 MB hard drive instead of 80 MB.
For detailed maintenance procedures including cleaning, PRAM battery management, and connector maintenance, refer to the Macintosh LC II General Maintenance page.
A troubleshooting guide addressing common issues is available on the Macintosh LC II Troubleshooting page.
Capacitor replacement information for the logic board can be found on the Macintosh LC II Capacitor Replacement Guide page.
Service Documentation
  1. Macintosh Performa 430 Specs, EveryMac.com—link(accessed 2026-02-10)
