Related changes
Enter a page name to see changes on pages linked to or from that page. (To see members of a category, enter Category:Name of category). Changes to pages on your Watchlist are in bold.
Recent changes optionsShow last 50 | 100 | 250 | 500 changes in last 1 | 3 | 7 | 14 | 30 days
Hide registered users | Hide anonymous users | Hide my edits | Show bots | Hide minor edits
Show new changes starting from 03:55, 24 September 2026
Page name:
List of abbreviations:
N
This edit created a new page (also see list of new pages)
m
This is a minor edit
b
This edit was performed by a bot
(±123)
The page size changed by this number of bytes
23 September 2026
     23:35  Apple Lisa 3 changes history +6,962 [Josh (3×)]
23:35 (cur | prev) +471 Josh talk contribs (Verification drive: the Lisa 2/10 has one 3.5-inch drive plus the internal Widget, not two floppy drives, and a plain Lisa 2 cannot take an internal drive because its I/O board and motherboard do not support one; MacWorks is loaded from diskette, not a ROM emulator)
23:32 (cur | prev) +54 Josh talk contribs (House style: rephrase the corrections as statements about the figures themselves rather than about this page's own history)
23:13 (cur | prev) +6,437 Josh talk contribs (Verification drive: screen refresh is Apple's 60 Hz not 67 Hz and the dot rate is 20 MHz not a '25 MHz crystal'; removed the fabricated memory map, 'Lisa PDS' pinout table, 'Lisa ASIC', light-pen interface, ProDOS-derived filesystem and LisaTerminal-as-3270/Telnet claims; the ProFile connects to the built-in PARALLEL port, not AppleBus; memory is two 512 KB boards, Apple max 1 MB (2 MB third-party), not '4x 256Kx1 SIMMs, 1.5 MB'; removed the duplicated lead paragraph; fixed cabinet dimensions...)
     23:32  Macintosh Floppy Drive Maintenance 2 changes history +3,344 [Josh (2×)]
23:32 (cur | prev) −15 Josh talk contribs (House style: rephrase the corrections as statements about the figures themselves rather than about this page's own history)
23:10 (cur | prev) +3,359 Josh talk contribs (Verification drive: the Apple SuperDrive and its 400K/800K predecessors are DIRECT DRIVE - no belt exists, and the 'check the drive belt' advice that propagated from here to several machine pages is removed; deleted the uncited head re-tensioning, track-zero sensor alignment and stepper head-alignment procedures (there is no felt pad in a double-sided 3.5in drive and Apple publishes no adjustment at all); removed HD SC Setup as a floppy tool; added Apple's 3.5 Drive performance and current-dr...)
     23:32  Macintosh HDD Maintenance 2 changes history +4,698 [Josh (2×)]
23:32 (cur | prev) +44 Josh talk contribs (House style: rephrase the corrections as statements about the figures themselves rather than about this page's own history)
23:11 (cur | prev) +4,654 Josh talk contribs (Verification drive: removed the +5/+12 V rail table and the 'adjust analog board trimmer R56' instruction - R56 is on the 128K/512K/Plus power-sweep board and regulates +12 V, so that advice pushed +12 V out of spec on the few machines that even have it; added Apple's Hard Drives Service Source procedures (run HD SC Setup first; remove terminator resistors or damage the logic board; torque carrier screws to 8.0 in-lb; 20SC Rev A/B like-for-like matching))
     23:07  Macintosh Performa 5420CD 2 changes history +2,606 [Josh (2×)]
23:07 (cur | prev) +38 Josh talk contribs (Remove red link to a Power Macintosh 5500 page that does not exist yet)
23:07 (cur | prev) +2,568 Josh talk contribs (Verification drive: Apple says the 5420 is a GRAPHITE-COLOURED Power Macintosh 5400/120 sold initially in Japan - the difference is the plastics, not a software bundle; 8 MB soldered not 16 MB standard; width/depth were swapped; sound input is stereo not mono; removed the unsourced 40 MHz bus figure; separated out the distinct Performa 5420/180 (603ev at 180 MHz, Japan and Australia); added CRT, video-mode, cache-DIMM and electrical specs; fixed red link to Power Macintosh 5500)
     23:05  Macintosh Performa 6200 diffhist +3,165 Josh talk contribs (Verification drive: width and depth were swapped (Apple: 16.5 in wide, 12.6 in deep); the 1 MB frame buffer is dedicated DRAM on the logic board, not carved out of system RAM; added Apple's Repair Extension Program checks (U10 343S1191/343S1121, Cache/ROM DIMM 661-1278, U6/U27 version-B check, RGB cable) and the electrical spec; cited to the Performa 6200/6300 Service Source)
     23:04  Macintosh Performa 5200 2 changes history +4,748 [Josh (2×)]
23:04 (cur | prev) −562 Josh talk contribs (Collapse duplicate named-ref definitions to a single definition per ref)
23:04 (cur | prev) +5,310 Josh talk contribs (Verification drive: the 1 MB frame buffer is dedicated DRAM on the logic board, not shared system RAM; added Apple's Repair Extension Program checks (U10 343S1191/343S1121, Cache/ROM DIMM 661-1278, U6/U27 version-B check, RGB cable 922-2357) and Open Transport 1.1.1; added CRT, video-mode and electrical specs; explained Apple's self-contradictory published weight; cited to the 5200/5300 Service Source)
     21:13  Macintosh LC 630 2 changes history +4,356 [Josh (2×)]
21:13 (cur | prev) +1,459 Josh talk contribs (Battery section corrected: Apple's '4.5 battery' is a section cross-reference, not a voltage - the same manual prints '5.4 battery' for the same step and the Performa 630 manual prints '5.4' in the identical entry. Apple documents no battery part number, voltage or threshold for this machine, so none is asserted)
21:07 (cur | prev) +2,897 Josh talk contribs (Rewrite against Apple's LC 630/Quadra 630/Performa 640 Service Source and the newly hosted Developer Note: DELETED 'passive cooling leads to heat accumulation' - Apple documents a fan/video card bracket (922-1160), a 2-pin fan cable and four symptom-chart entries that branch on whether the fan is running; dimensions corrected from 3.4x12.3x15.8 in to Apple's 4.3x16.5x12.6 in and weight split 17 lb / 19 lb with CD-ROM; sound corrected from '16-bit 44.1 kHz' to Apple's 8-bit stereo, 16-bit in C...)
     21:08  Macintosh LC 550 2 changes history +8,532 [Josh (2×)]
21:08 (cur | prev) +183 Josh talk contribs (Define each named reference in full at its first use (was rendering a cite error))
21:05 (cur | prev) +8,349 Josh talk contribs (Rewrite against Apple's LC 520/550/575 Service Source plus the newly hosted LC 520 and LC 575 Developer Notes: maximum power corrected from '150W typical / 200W maximum' to Apple's 120 W; frequency to 47-63 Hz; the '24-bit address / 16 MB space' claim deleted as self-contradictory; VRAM ceiling no longer asserted - Apple's shared Service Source row conflates three machines, the LC 520 note gives 768 KB and the LC 575 note gives 1 MB from two matched sockets, and no LC 550 developer note exist...)
     21:08  Macintosh IIfx 2 changes history +10,095 [Josh (2×)]
21:08 (cur | prev) +359 Josh talk contribs (Define each named reference in full at its first use (was rendering a cite error))
21:02 (cur | prev) +9,736 Josh talk contribs (Rewrite against Apple's Macintosh II/IIx/IIfx Service Source and the newly hosted Apple Technical Note HW 9, plus Recap-a-Mac's board photograph, MacDat and Console5. Corrections: height 5.5 in not 5.8 in; model number M5525 not M5780 (M5780 is the IIci); price US$8,970-10,970 not $8,969-12,000. DELETED the unsourced capacitor list (10x47uF/4x10uF 25V/2x220uF/2x470uF 25V/1x1000uF) and replaced it with the real complement, 14x47uF 16V + 3x470uF + 1x220uF + 1x10uF + 1x1000uF 10V, corroborated t...)
     21:08  Macintosh IIci 2 changes history +7,629 [Josh (2×)]
21:00 (cur | prev) +7,270 Josh talk contribs (Rewrite against Apple's IIcx/IIci/Quadra 700 Service Source and the newly hosted Macintosh IIci Developer Note, Recap-a-Mac board photograph and MacDat: battery threshold 2.8 V from this machine's own manual; bicarbonate not vinegar for a lithium cell; real 820-0242-A capacitor complement added with the axials at 25 V (not the IIcx's 16 V) and a statement that Console5 carries no IIci list so this rests on two sources; Apple PSU part numbers and rated rail currents added; no rail-tolerance ta...)
     21:08  Macintosh IIcx 2 changes history +6,155 [Josh (2×)]
20:59 (cur | prev) +5,796 Josh talk contribs (Rewrite against Apple's IIcx/IIci/Quadra 700 Service Source plus the newly hosted Recap-a-Mac board photograph, MacDat and Console5: clock given as Apple's 15.6672 MHz with the 31.3344 MHz crystal as the check (the II/IIx manual's 15.6772 MHz is a misprint); battery threshold 2.8 V from this machine's own manual, with a warning that it is the most-transplanted figure of the three; bicarbonate not vinegar; real 820-0230-B capacitor complement corroborated three ways, with MacDat's 25 V axial c...)
     21:08  Macintosh IIx 2 changes history +8,314 [Josh (2×)]
20:58 (cur | prev) +7,955 Josh talk contribs (Rewrite against Apple's Macintosh II/IIx/IIfx Service Source plus newly hosted Recap-a-Mac board photograph and MacDat/Console5: maximum power corrected from 230 W (the IIfx figure) to Apple's 220 W; mains input corrected from 'switch selectable' to Apple's auto-configuring 100-240 VAC 48-62 Hz; width corrected from 18.5 in to Apple's 18.7 in; model number corrected from M5810/M5820 to M5840; DELETED the unsourced rail-current table, BTU figure, NuBus per-slot power table, the invented UB1/UB...)
     21:06  Macintosh LC 580 diffhist +6,055 Josh talk contribs (Rewrite against Apple's LC 580/Performa 580CD Service Source plus a newly hosted Recap-a-Mac board photograph and MacDat: sound corrected from '16-bit 44.1 kHz' to Apple's 8-bit at 11/22 kHz; ADB corrected from two ports to one; the two serial ports distinguished as Apple gives them (9-pin mini-DIN modem, 8-pin mini-DIN printer); the unsourced per-socket SIMM capacity list replaced with what Apple actually documents (one single-bank socket); the unsourced resistor-removal overclock instructio...)
     21:04  Macintosh LC 520 diffhist +8,670 Josh talk contribs (Rewrite against Apple's LC 520/550/575 Service Source and the newly hosted Macintosh LC 520 Developer Note: maximum power corrected from '150W typical / 200W maximum' to Apple's 120 W; mains frequency corrected to 47-63 Hz; the '24-bit address / 16 MB space' claim deleted as self-contradictory; VRAM ceiling settled at 768 KB (512 KB soldered + one 256 KB SIMM) from Apple's machine-specific developer note - 1 MB belongs to the LC 575; the 10 MB / 16 MHz figures identified as the Color Classic'...)
N    20:43  Macintosh LC III Developer Note diffhist +1,040 Josh talk contribs (Documentation page for newly hosted Apple developer documentation)
     20:42 Upload log Josh talk contribs uploaded File:Macintosh LC III Developer Note.pdf (Apple developer documentation for the RTC verification drive)
     18:20  Macintosh Color Classic II diffhist +1,250 Josh talk contribs (Rebuilt: DELETED invented Known Revisions and Errata (marginal 5V regulation/improved 7805, swapped C6/C7 footprints), the US MSRP (never sold in the US), stereo line-out and 2.5x performance claims, and successor = LC 520/Performa 275 (Performa 275 is the same machine); memory now states both published answers - Apples own Service Source repeats the Color Classics 10MB/two 30-pin J10 page verbatim while independent sources and the LC 520/550/575 manual give 36MB via one 72-pin SIMM - with a...)
     18:20  Macintosh Color Classic diffhist +1,501 Josh talk contribs (Rebuilt against Apple Color Classic Service Source: codename field held LC III/Performa 250 (codename is Slice); dimensions corrected to Apple 14.5x9.9x12.6in and weight 22.5-23.2lb; FPU is a logic-board socket not a PDS option; added J10 both-or-neither SIMM rule, J9 VRAM slot, 3.0V battery threshold and the fact that Apples Adjustments chapter is geometry/video/convergence only; DELETED unsourced 100W PSU prose duplication and stray Classic copy; release_date fixed; refs and reflist)
     18:18  Macintosh Classic II diffhist −1,624 Josh talk contribs (Rebuilt against Apple Classic/Classic II/Performa 200 Service Source: DELETED fabricated memory map, V8 Lite/MEMCjr chipset claims, 53C96 and Egret attributions, ROM module table, MacBench comparison table, Paris codename/Eiffel silkscreen, JP3 debug jumper and the cold-start easter egg; SIMM speed 80ns -> 120ns or faster, single SIMM claim corrected to a pair, dimensions/weight/model number corrected; region-specific analogue board warning added; release_date parameter fixed; refs and reflist)
     18:18  Macintosh Classic diffhist −586 Josh talk contribs (Rebuilt against Apple Classic/Classic II/Performa 200 Service Source: DELETED fabricated memory map, ROM SIMM module table, SWIM-II/53C80 detail, MacBench benchmark table, Seattle/LittleFish codenames and MacsBug easter egg, and the 512KB 32-bit-clean/HFS+ ROM claim; CPU 8MHz -> 7.8336MHz, ONE ADB port (not two), Apple dimensions and 100W; predecessor SE/30 -> SE; added the real Command-Option-X-O ROM disk; fixed red link to a nonexistent Troubleshooting page; release_date parameter fixed; re...)
     18:17  Macintosh SE/30 diffhist +285 Josh talk contribs (Rebuilt against Apple SE/30 Service Source + Guide to the Macintosh Family Hardware: release date was 16 January 1986 (wrong; 19 January 1989), CPU 16.667MHz -> 15.667MHz, ROM 512KB -> 256KB, weight 19.5lb -> 21.5lb, RAM 128MB claim qualified against Apple 32MB; DELETED fabricated memory map, ROM module table, SCSI/sound path detail, JP13 and chess-tone easter egg; pseudo-slot video explained from Apple ch.12; chip location map from the hosted 050-0253-01 redraw; refs and reflist)
     18:17  Macintosh SE diffhist −4,570 Josh talk contribs (Rebuilt against Apple Macintosh SE Service Source: DELETED fabricated memory map, ROM v5.3-v5.6 table, PDS card list, RC filter values, environmental table, 150W max power, 1.5 million units and the ROM easter-egg address; Apple specs added (100W max, 90-140/170-270VAC, 17-21lb, four-voice sound); three-assembly construction (analogue board + separate PSU + video board) documented; FRU/board numbers; release_date parameter fixed; refs and reflist)
     18:16  Macintosh 512Ke diffhist −1,366 Josh talk contribs (Rebuilt: DELETED fabricated memory map, v3.4 ROM module table, 800KB format detail, MC6883 PAL/LM380 sound path and the easter egg; codename field held a model number; SCSI Manager in ROM clarified (no SCSI hardware); 4.5V alkaline PRAM cell and the 128K/512K voltage procedure cross-referenced; refs and reflist)
     18:16  Macintosh 512K diffhist +508 Josh talk contribs (Rebuilt against Apple Macintosh 128K/512K Service Source: DELETED fabricated memory map, ROM module layout, video timing table, sound path (LM380/MC6883 PAL), HN462716 ROM claim and the startup-chime easter egg; specifications now Apple-sourced (64KB ROM, 60W, DE-9 serial, RJ-11 keyboard); release_date parameter fixed; real 26LS30/CR18 faults from Dead Mac Scrolls; refs and reflist)
     05:53  Apple III 2 changes history +12,000 [Josh (2×)]
05:53 (cur | prev) −22 Josh talk contribs (Remove unsourced codename; every remaining figure on the page is cited)
05:47 (cur | prev) +12,022 Josh talk contribs (Rewrite from Apple's own manuals; every figure now cited, unsourced figures removed)
     05:48  Apple III Plus diffhist +6,337 Josh talk contribs (Rewrite from Apple's own manuals; every figure now cited, unsourced figures removed)
     05:46  Apple IIGS diffhist +11,309 Josh talk contribs (Rewrite from Apple's own manuals; every figure now cited, unsourced figures removed)
     05:44  Apple IIc Plus diffhist +4,948 Josh talk contribs (Rewrite from Apple's own manuals; every figure now cited, unsourced figures removed)
     05:43  Apple IIc diffhist +7,611 Josh talk contribs (Rewrite from Apple's own manuals; every figure now cited, unsourced figures removed)
     05:41  Apple IIe Platinum diffhist +1,540 Josh talk contribs (Rewrite from Apple's own manuals; every figure now cited, unsourced figures removed)
     05:41  Apple IIe Enhanced diffhist +3,442 Josh talk contribs (Rewrite from Apple's own manuals; every figure now cited, unsourced figures removed)
     05:41  Apple IIe diffhist +7,118 Josh talk contribs (Rewrite from Apple's own manuals; every figure now cited, unsourced figures removed)
     05:41  Apple II Plus diffhist +6,737 Josh talk contribs (Rewrite from Apple's own manuals; every figure now cited, unsourced figures removed)
     02:27  Retrobrite 2 changes history −132 [Josh (2×)]
02:27 (cur | prev) −29 Josh talk contribs (Fix the 6 per cent row of the hazard table: at 6 per cent the classification is Eye Irrit. 2 (H319), not Eye Dam. 1, which applies from 8 per cent)
02:15 (cur | prev) −103 Josh talk contribs (Remove self-referential wording per house rule)
