Amstrad 6128
Revision as of 23:20, 24 September 2026 by Josh (talk | contribs) (STUB EXPANDED: replaced a 126-byte informal note with a real article sourced entirely to the CPC6128 service manual hosted here - Z80A/128K as two banks/48K ROM, the three display modes, the 3-inch drive at 12 ms step and 30 ms settle, and the point that matters most for repair, that the machine has no internal PSU and needs BOTH 5 V and 12 V from the monitor)
Amstrad CPC 6128
DeveloperAmstrad
ManufacturerAmstrad Consumer Electronics plc
TypeHome computer
CPUZilog Z80A @ 4 MHz
Memory128 KB RAM, as two 64 KB banks (over 41 KB free in BASIC; 61 KB TPA under CP/M Plus)
StorageIntegrated 3-inch disc drive, Hitachi/Panasonic standard
Display160×200×16, 320×200×4 or 640×200×2 from a 27-colour palette
SoundGeneral Instrument AY-3-8912, three voices, eight octaves
GraphicsMotorola 6845 CRT controller
ROM48 KB — operating system, Locomotive BASIC and the disc extensions
Input74-key keyboard
Power5 V and 12 V DC from the monitor. No mains connection and no internal power supply
OS / FirmwareAmstrad firmware with Locomotive BASIC; AMSDOS; CP/M Plus supplied
Model no.CPC 6128
The Amstrad CPC 6128 is the disc-based member of the Amstrad CPC range: the same architecture as the Amstrad CPC 464, with 128 KB of RAM in place of 64 KB and a built-in 3-inch disc drive in place of the cassette deck. It was sold as a complete system with either the GT65 green monitor or the CTM644 colour monitor.
The figures on this page are Amstrad's own, from the CPC6128 Micro Computer / CTM644 Colour Monitor / GT65 Green Monitor Service Manual hosted on this wiki.[1]
The monitor is the power supply
The CPC 6128 has no mains connection and no internal power supply. Amstrad's technical specification gives the power supply as "Screen System: 240 V AC 50 Hz (keyboard and disc drive power supplied by screen system)", and lists two separate connections on the computer:[1]
  • a 5 mm socket for the 5 V supply, which Amstrad describes as "supplied exclusively from monitor"
  • a 5 mm plug and lead that connects to the 12 V (disc) power socket on the monitor
Both are needed. A 6128 that boots but whose drive does nothing is very often missing the 12 V lead, not suffering a drive fault — check that before opening anything. And because the supply lives in the monitor, a "dead computer" on a CPC 6128 is a monitor fault until proved otherwise; the monitor sections of the service manual carry their own parts lists and voltage charts for exactly this reason.
From Amstrad's technical specification:[1]
  • Z80A at 4 MHz
  • 128 KB of RAM arranged as two 64 KB banks — over 41 KB available to the user in BASIC, 61 KB TPA under CP/M Plus
  • 48 KB of ROM containing BASIC, the operating system and the disc extensions
  • 6845 CRT controller; AY-3-8912 three-voice, eight-octave sound generator; 8255 parallel I/O
  • 74-key keyboard — QWERTY with a numeric cluster, cursor and copy cursor, return, enter, shift, caps lock, tab, delete, clear and control
  • Three display modes: 4 colours from 27 at 320 × 200, 2 from 27 at 640 × 200, and 16 from 27 at 160 × 200
  • Expansion for up to 252 additional 16 KB ROMs
  • External sockets: PCB edge connectors for general-purpose expansion and for the Centronics printer port; a second disc drive socket (DI-2 lead); a 9-pin D-type joystick socket; a 6-pin DIN for RGB and sync or luminance and sync; a 5-pin DIN for an external cassette recorder (CL1 lead); a 3.5 mm stereo socket for sound out
The disc system
Amstrad's own disc specification:[1]
  • A 3-inch system conforming to the Hitachi/Panasonic standard
  • The software is configured for a 12 ms step rate and a 30 ms settling time
  • The system is designed to control a maximum of two drives
  • CP/M usually assumes an 80-column screen, and Amstrad notes that the 6128's 80-column mode is a prerequisite for most CP/M applications
A second drive attaches through the disc drive 2 socket. The external FD-1 drive used with the Amstrad CPC 464 has its own integral mains power supply, so it is not powered from the 6128.
Servicing
The service manual carries, for the computer: a basic hardware analysis page, function diagrams, a software errors page, a four-page diagnostic flow chart, four pages of alignment checks, the main PCB layouts, the CPU circuit diagram, and the electrical parts list giving value, circuit reference and Amstrad part number for every component. For the monitors it carries separate circuit diagrams, PCB layouts, alignment instructions, voltage charts and parts lists.[1]
Later main-board revisions are documented separately in the amendment volume: where a board does not match the original manual's drawing, check the amendment before concluding it has been modified.
  1. ↑ 1.0 1.1 1.2 1.3 1.4 Amstrad Consumer Electronics plc, CPC6128 Micro Computer / CTM644 Colour Monitor / GT65 Green Monitor Service Manual. Hosted at Amstrad CPC 6128 Service Manual. Source for the technical specification on the back page, the CPC6128 electrical parts list (page 21), the basic hardware analysis and diagnostic flow charts (pages 4 and 8–11), the alignment checks (pages 12–15) and the separate GT65 and CTM644 parts lists and voltage charts (pages 22–28).
