Category:Psion
Psion
British Pocket Computers, Organisers and Palmtops from the Original 1984 Organiser to the netBook
Welcome to the Psion category! Psion Plc was the British company that defined the pocket-computer category in the 1980s and 1990s. The line begins with the Organiser in 1984 โ€” the first electronic organiser โ€” and runs through the Series 3 and Series 5 clamshell palmtops, the Revo, the netBook, and the Workabout ruggedised industrial PDA. This category collects maintenance, troubleshooting, and recap guides for the entire Psion line.
Each system features:
  • Hinge, ribbon and keyboard repair on the Series 3 and Series 5 clamshells
  • SSD pack repair and Datapak / Rampak replacements for the Organiser II
  • Battery, NiMH replacement and PCB cleaning across all generations
  • EPOC and SIBO ROM/flash documentation for restoration
๐Ÿ“Ÿ Organiser (1984-89)
Model Maintenance Troubleshooting Capacitor Guide SSD / Pack Service
Psion Organiser Psion Organiser General Maintenance Psion Organiser Troubleshooting Guide Psion Organiser Capacitor Replacement Guide Psion Organiser Datapak Repair
Psion Organiser II Psion Organiser II General Maintenance Psion Organiser II Troubleshooting Guide Psion Organiser II Capacitor Replacement Guide Psion Organiser II Datapak Repair
๐Ÿ’ป Series 3 (1991-98)
Model Maintenance Troubleshooting Hinge / Ribbon Repair
Psion Series 3 Psion Series 3 General Maintenance Psion Series 3 Troubleshooting Guide Psion Series 3 Hinge Repair
Psion Series 3a Psion Series 3a General Maintenance Psion Series 3a Troubleshooting Guide Psion Series 3a Hinge Repair
Psion Series 3c Psion Series 3c General Maintenance Psion Series 3c Troubleshooting Guide Psion Series 3c Hinge Repair
Psion Series 3mx Psion Series 3mx General Maintenance Psion Series 3mx Troubleshooting Guide Psion Series 3mx Hinge Repair
Psion Siena Psion Siena General Maintenance Psion Siena Troubleshooting Guide โ€”
No capacitor guides are listed for the Series 3 family. These are low-voltage SIBO machines running from two AA or AAA cells through switch-mode converters, with no bulk electrolytic smoothing stage and no community history of recapping โ€” the faults people actually report are the hinges, the button bar, the screen ribbon, the battery lead and the SSD door sensing. The reasoning, and the two situations where capacitor work is justified, are in Psion Series 3a General Maintenance. The Siena has no clamshell hinge failure comparable to the Series 3's, so no hinge guide is listed for it.
๐Ÿ’ป Series 5 / Revo (1997-2000)
Model Maintenance Troubleshooting Capacitor Guide Hinge / Ribbon / Battery
Psion Series 5 Psion Series 5 General Maintenance Psion Series 5 Troubleshooting Guide โ€” Psion Series 5 Hinge Cable Repair
Psion Series 5mx Psion Series 5mx General Maintenance Psion Series 5mx Troubleshooting Guide Psion Series 5mx Capacitor Replacement Guide Psion Series 5mx Hinge Repair
Psion Series 5mx Pro Psion Series 5mx Pro General Maintenance Psion Series 5mx Pro Troubleshooting Guide โ€” see Psion Series 5mx Hinge Repair
Psion Revo Psion Revo General Maintenance Psion Revo Troubleshooting Guide โ€” Psion Revo Battery Replacement
Psion Revo Plus Psion Revo Plus General Maintenance Psion Revo Plus Troubleshooting Guide โ€” Psion Revo Battery Replacement
The Psion Series 5mx Capacitor Replacement Guide covers the whole EPOC platform, including why none of these machines is a recap candidate and the three situations where capacitor work is nevertheless justified. The 5mx Pro is mechanically a Series 5mx, so it shares that machine's hinge guide rather than having its own. The Revo and Revo Plus have no clamshell ribbon failure โ€” their defining repair is the pair of soldered-in NiMH cells, so a battery replacement guide takes that column instead.
๐Ÿ’ป Series 7 / netBook (1999-2003)
Model Maintenance Troubleshooting Battery Service
Psion Series 7 Psion Series 7 General Maintenance Psion Series 7 Troubleshooting Guide Psion Series 7 Battery Service
Psion netBook Psion netBook General Maintenance Psion netBook Troubleshooting Guide Psion netBook Battery Service
Psion netBook Pro Psion netBook Pro General Maintenance Psion netBook Pro Troubleshooting Guide Psion netBook Pro Battery Service
No capacitor guides are listed for the Series 7, netBook or netBook Pro. Detailed research across the surviving community record โ€” the contemporary Series 7 FAQ's own hardware fault list, PsionWiki, the OpenPsion netBook HOWTO, comp.sys.psion, HPC:Factor and the modern collector write-ups โ€” found no report of a failed capacitor, a bulging or leaking electrolytic, or anyone recapping one of these machines. The faults the community actually documents are the screen cable, the battery-catch microswitch, the CompactFlash drawer, PC Card current draw and, on the netBook Pro, the hinges. The reasoning, and the two situations where capacitor work is justified, are in the Psion Series 7 Troubleshooting Guide. The Series 7 and netBook share one battery pack, so the rebuild procedure is written once on Psion netBook Battery Service and cross-referenced; the netBook Pro takes a different pack and has its own procedure.
๐Ÿ› ๏ธ Workabout (industrial)
Psion Workabout Psion Workabout General Maintenance Psion Workabout Troubleshooting Guide Psion Workabout Capacitor Replacement Guide
Psion Workabout mx Psion Workabout mx General Maintenance Psion Workabout mx Troubleshooting Guide Psion Workabout mx Capacitor Replacement Guide
Psion Workabout Pro Psion Workabout Pro General Maintenance Psion Workabout Pro Troubleshooting Guide Psion Workabout Pro Capacitor Replacement Guide
๐Ÿ–ฅ๏ธ All Psion
๐Ÿงช Tools & Procedures
๐Ÿ› ๏ธ Service Manuals & Documentation
  • Psion Series 5 Service Manual โ€“ Psion's own 46-page service manual (November 1997): circuit description, exploded views with part numbers, disassembly and reassembly, and the factory Final Test fault codes. Applies mechanically to the Series 5mx as well.
  • Psion Organiser II Spare Parts List โ€“ Psion's exploded diagram and component-level parts lists, including every capacitor designator, value and part number for the Organiser II boards.
  • Service Manuals โ€“ Cross-manufacturer manual collection.
  • Capacitor Replacement Guides โ€“ Model-specific capacitor specs.
๐Ÿ” See Also
Pages in category "Psion"
The following 60 pages are in this category, out of 60 total.
P
Media in category "Psion"
The following 22 files are in this category, out of 22 total.
