Atari Jaguar CD Capacitor Replacement Guide
The Atari Jaguar CD main board (assembly 700037) carries about sixteen aluminium electrolytic capacitors. The values below come from ZedLabz's capacitor kit list, a vendor source, and not from Atari documentation. The positions were checked against the designators printed on the board in Evan-Amos's photograph of a Rev. E board.[1][2] For the console, see the Atari Jaguar Capacitor Replacement Guide.
Capacitor list
[edit | edit source]| Ref | Value | Rating | On the Rev. E board photograph |
| C8 | 47 µF | 25 V | Beside R15 and R16, between the two TDA7073AT chips |
| C10 | 22 µF | 25 V | Below the lower TDA7073AT |
| C12 | 22 µF | 16 V | Below the TDA1302T, near the six-wire transport plug |
| C21 | 22 µF | 25 V | See note below |
| C23 | 33 µF | 10 V | Left edge, below the TDA1301T |
| C24 | 33 µF | 10 V | Top left, above the TDA1301T |
| C35 | 47 µF | 10 V | Below the LM2941T regulators |
| C36 | 47 µF | 10 V | Below the LM2941T regulators |
| C39 | 47 µF | 25 V | Below the LM2941T regulators |
| C42 | 1 µF | 50 V | Top left, beside C24 |
| C47 | 1 µF | 50 V | Top right, beside the SAA7345GP |
| C48 | 4.7 µF | 50 V | Near the SAA7345GP |
| C54 | 4.7 µF | 50 V | Near the SAA7345GP |
| C58 | 1 µF | 50 V | Beside the Atari 500490 ASIC |
| C59 | 47 µF | 10 V | Beside the Atari 500490 ASIC |
| C73 | 10 µF | 25 V | Bottom right, beside the power socket |
Values and ratings are ZedLabz's.[1] The positions are from the silkscreen in the photograph.[2] On that board the largest capacitor beside the TDA1302T is marked C22, a designator the kit list does not contain; the list instead has a C21 of 22 µF 25 V. Read the markings on your own board before ordering.
Procedure
[edit | edit source]See Recommended Tools for equipment and Capacitor Failure Symptoms for what a failed part looks like.
- Remove the CD unit from the console and unplug its adaptor.
- Remove the seven case screws from the underside and lift off the top cover, keeping the lid-sensor post.[3]
- Remove the four board screws, unplug the lid switch lead and lift the board out.[4]
- Most capacitors can be reached with the transport in place. If you take it out, note its wiring first; see Atari Jaguar CD Laser Replacement.
- Replace one capacitor at a time, matching the polarity marking on the board.
- Refit the board and the cover, guiding the lid-sensor post into its hole.[5]
Graeme Hinchliffe notes that a capacitor beside the six-wire transport socket makes the plug awkward to refit; start the end nearest the capacitor first.[5]
[edit | edit source]- Atari Jaguar CD
- Atari Jaguar CD General Maintenance
- Atari Jaguar CD Troubleshooting Guide
- Atari Jaguar Capacitor Replacement Guide
- Capacitor Failure Symptoms
[edit | edit source]- ↑ 1.0 1.1 ZedLabz, "Capacitor kit for Atari Jaguar CD", kit contents (retrieved 4 October 2026). Vendor source.
- ↑ 2.0 2.1 Evan-Amos, photograph of the Jaguar CD main board, assembly 700037, label "700037 REV E", 20 June 2014. Hosted here as File:Atari Jaguar CD main board (700037 Rev E).jpg.
- ↑ Graeme Hinchliffe, "Replacing Atari Jaguar CD Unit Laser Transport - page 2", 2002. Personal repair guide.
- ↑ Graeme Hinchliffe, "Replacing Atari Jaguar CD Unit Laser Transport - page 3", 2002. Personal repair guide.
- ↑ 5.0 5.1 Graeme Hinchliffe, "Replacing Atari Jaguar CD Unit Laser Transport - page 5", 2002. Personal repair guide.
