StyleWriter Service Source
Revision as of 19:27, 1 October 2026 by Josh (talk | contribs) (Update links to Color StyleWriter 4100 and 4500 Service Source after page move)
The StyleWriter volume of Apple's Service Source is the service manual for the original Apple StyleWriter, a serial bubble-jet ink-on-demand printer that runs from an external AC power adapter. The PDF has 79 pages and a text layer; it was produced in FrameMaker 5.0.1.
Contents
  • Basics: Introduction (p. 3)
  • Specifications: Characteristics, Graphics, Paper Handling, Ink Cartridges, Environmental, Electrical, Physical (pp. 5–11)
  • Troubleshooting: General, then symptom charts for Preliminary Checks, Status Light, Printing, Carrier Movement, Paper Feed and Miscellaneous (pp. 13–25)
  • Take Apart: Lower Access Cover, Front Access Cover, Platen Cover and Rollers, Logic Board, Fuse (p. 43), Printer Frame Assembly, Operations Panel Assembly, Cartridge Hook, Forms Thickness Lever, Paper Sensor, Output Tray Size Extension, Extension Guide/Rod Support, Output Tray and Base, Rear Cover (pp. 27–71)
  • Additional Procedures: Revision Identification (p. 74)
  • Exploded View (p. 79)
Specifications, as printed
Item Value
Print method Serial bubble jet, ink-on-demand
Print head 1 × 64 nozzles; life approximately 500 pages (normal mode)
Throughput 1/3 page per minute (Best), 1/2 page per minute (Faster)
Resolution 360 dpi (Best), 180 dpi (Faster)
Input buffer 8 K
Power source 120 V AC 60 Hz (US/Canada); 120 V AC 50/60 Hz (Japan); 240 V AC 50 Hz (UK/Australia); 220 V AC 50 Hz (Europe)
Power consumption 23 W maximum at 120 V; 25 W maximum at 220 V
Paper LTR, LGL, A4; 16–24 lb; 50-sheet capacity
Envelopes Commercial No. 10 only (4.1 × 9.5 in)
Environmental 15–30 °C, 20–70 % RH non-condensing, under 50 dB
Dimensions and weight 32 × 33.6 × 23 cm; approximately 3.4 kg
Service information
The logic board carries a 2.5 A fuse. The "No lights or movement" chart replaces the AC adapter and then the fuse; the "No status lights" chart goes on to the logic board and the operations panel. The fuse is reached by prying up two tabs on the bottom of the printer and lifting the logic board cover (Take Apart, Fuse).
Revision A and Revision B logic boards and printer frames must be replaced like for like. The Revision Identification procedure (Additional Procedures) tells them apart in two ways. With the carriage worm screw turned so the V-groove of the large grey gear faces up and the carriage hook assembly slid left, the gear next to the spring at the right-hand end of the worm screw is black on Revision A and grey on Revision B. The Revision A logic board is marked QG2-5053 and the Revision B board QG2-2403.
The exploded view gives part numbers for the modules, among them the logic board (661-0629), printer frame assembly (661-0630), fuse (941-5224), operation panel assembly (982-0062) and paper sensor (890-0286).
There is no schematic, component-level parts list or internal voltage table, and nothing on the AC adapter beyond replacing it.
Download: stylewriter.pdf (583 KB)
