Amstrad NC100 Troubleshooting Guide
Revision as of 03:02, 2 October 2026 by Josh (talk | contribs) (New page: NC100 power circuit, warning thresholds, resets, display and card faults)
A working NC100 (German model) at its main menu
Most faults reported on the Amstrad NC100 are power faults: flat or leaking AA cells, a dead lithium backup cell, the wrong adaptor, or a software lock-up that needs a reset. Amstrad published user-level instructions; the board-level detail here comes from Hans-Jürgen Böhling's surgical guide and from the hardware chapter of Robin and Chris Nixon's Advanced User Guide.[1][2][3] Procedures are in the Amstrad NC100 Maintenance Guide.
How the power circuit works
Böhling's power supply diagram shows the 6 V DC adaptor input passing through fuse F301, and the four AA cells and the lithium cell feeding a DC/DC converter and battery-level detector. The converter produces +6 V, +5 V, a lithium-backed 5 V line (5VBK) for the RAM and clock, and −15 V for the LCD. A push switch, S301, sets a flip-flop (IC313A) that switches the converter on; the custom chip's POFF line resets it, and the clock's alarm output is wired to the same set input.[2]
The battery-level signals go to the custom chip and can be read at I/O port &A0. The two sources give different thresholds:
Battery warning thresholds
Signal Böhling's power diagram Nixon, port &A0
Main cells low BD1: four AA below 4.2 V; BVD2: below 3.2 V Bit 3: below 3.2 V, though "tests show this may be nearer to 4.2 volts in practice"
Lithium cell low BD2: below 2.3 V Bit 2: below 2.7 V
Mains adaptor – Bit 5: adaptor below 4 V
Memory card battery – Bit 4: 1 if the card battery is good
Sources: Böhling's diagram[2] and Nixon's port description.[3]
Power faults
Power faults
Symptom Probable cause Action
Dead on batteries and on the adaptor Lock-up, fuse F301, the S301/IC313A switch-on circuit Try the reset below. Then measure the AA cells and the adaptor output, and check F301 with the case open
Works on the adaptor, dead on batteries Flat or reversed cells, corroded contacts Fit fresh LR6 cells the right way round; clean the contacts
Works on batteries, dead on the adaptor Adaptor, lead, adaptor socket Use only the supplied adaptor; Böhling gives the input as 6 V DC. Measure its output and inspect the socket
"battery is low, please switch off and replace battery" Main cells low Replace the four AA cells
"Lithium battery is low" Backup cell low Replace the CR2032 with good AA cells fitted or the adaptor connected
Memory lost after a battery change Dead or missing lithium cell, or all sources removed together Replace the CR2032; restore files from a card or another computer
Batteries run down quickly Automatic power-off set to 0, serial port use, NiCd cells Set the power-off delay to 1 to 5 minutes; use the adaptor for serial transfers
The messages and remedies are Amstrad's.[1] NiCd cells give about 5 hours against 35 to 40 hours for alkaline cells, so a short run time on rechargeables is not a fault.[1]
Lock-ups and reset
The documented reset erases everything in the Notepad's memory, including the password, but leaves the contents of a memory card alone: switch off, then hold down Function, Stop and the ←Del key on the right while switching on. A long beep confirms the reset. Sticky shift cannot be used for it.[1]
Nixon reports two further cases. A crash can leave the machine returning to the menu but blanking the screen when BASIC is entered; switching off and on again and pressing Function and B once more may clear it. Some crashes lock the machine so that no key combination works. The cure is to remove the four AA cells, the adaptor lead, the lithium cell and any memory card, press the power key repeatedly for a minute or two to drain the remaining charge, then refit everything. This erases all data in the machine.[3]
Display
Display faults
Screen blank or faint, machine beeps at switch-on Brightness control Adjust the control on the right-hand edge
Blank screen after the case has been opened Display flat cable not seated Reseat the cable in its socket on the main board
Blank screen, machine otherwise working LCD supply Böhling's diagram shows a −15 V supply for the LCD from the DC/DC converter; check for it at the display connector
Sources: Amstrad's setting-up pages[1] and Böhling's guide.[2] The NC100 display is not backlit.[4]
Memory cards
  • Only SRAM cards work; flash cards do not.[2]
  • A new card must be formatted from the stored-documents menu.[1]
  • The card's battery state and write-protect switch are reported to the Notepad through port &A0. Check both when a card will not save or loses its contents.[3]
Serial and printer ports
The serial port uses a µPD71051 UART (IC308) and a µPD4711 line driver (IC309); the parallel port is driven by the custom chip.[2] If a serial transfer produces rubbish, Amstrad's manual points to mismatched baud rate, data bits, stop bits or parity.[1] The printer can be set to the serial or the parallel port in the printer settings.[1]
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 Amstrad plc, Amstrad Notepad Computer user manual. Hosted as File:Amstrad Notepad Computer User Manual.pdf, described at Amstrad Notepad Computer User Manual. Setting up pp. 1–2; mains adaptor p. 4; powering the Notepad p. 43; automatic power off p. 44; memory cards p. 47; resetting p. 60; serial transfers p. 109.
  2. ↑ 2.0 2.1 2.2 2.3 2.4 2.5 Hans-Jürgen Böhling, A Surgical Guide To The Amstrad Notepad Computer. Community document, hosted as File:Amstrad NC100 Surgical Guide.pdf, described at Amstrad NC100 Surgical Guide. IC table, power supply block diagram, opening the case, PCMCIA slot.
  3. ↑ 3.0 3.1 3.2 3.3 Robin Nixon and Chris Nixon, The Amstrad Notepad Advanced User Guide (Sigma Press, 1993), pp. 155–156 (port &A0, memory card and battery status) and pp. 187–188 (reset and lock-up recovery). Scan at archive.org. Retrieved 2026-10-02.
  4. ↑ Wikipedia, "Amstrad NC100". Retrieved 2026-10-02. The unlit 80 × 8 display.
