Apple AudioVision 14 Display Troubleshooting Guide
Fault-finding for the Apple AudioVision 14 Display, from Apple's Service Source.[1] Apple lists cures in order of likelihood; refit the original module before moving to the next cure if a replacement did not help. The hardware cures name only two modules, the main board and the CRT, plus the audio parts.
The CRT keeps a charge after switch-off. Follow the CRT Discharge Procedure before working inside, and do not wear a grounding wrist strap until the CRT has been discharged.[2]
Picture faults
[edit | edit source]| Symptom | Cures, in Apple's order |
| No raster, LED off | Check the video cable is connected. Check the power cable and power switch. Check all connections on the main board. Replace a blown fuse. Replace the main board |
| No raster, LED on, CRT heater glowing | Check the video cable. Adjust contrast and brightness. Check the computer's video with a known-good monitor. Check all main board connections, making sure the video connector is secure and its wires are inside the plastic connector. Do the video adjustments. Replace the main board. Replace the CRT |
| Raster too short, tall, narrow or wide | Adjust the size controls. Replace the main board |
| Raster not centred | Move the display away from other monitors, fluorescent lights and electrical equipment. Adjust the centring controls. Replace the main board |
| Horizontal or vertical linearity bad | Replace the main board |
| Abnormal or distorted raster | Move the display. Do the geometry adjustments. Replace the main board. Replace the CRT (rarely needed) |
| Whole raster tilted | Move the display. Do the geometry adjustments, then the geometric distortion adjustments. Replace the main board |
| Picture breaks into diagonal lines, rolls vertically, or breaks and rolls horizontally | Check the computer's video with a known-good monitor. Replace the main board |
| Black raster with a single vertical or horizontal line | Replace the main board. Replace the CRT |
| Picture too dark, too bright or washed out | Adjust contrast and brightness. Check the video with a known-good monitor. Do the video adjustments. Replace the main board. Replace the CRT (rarely needed) |
| Out of focus | Do the focus adjustment. Replace the main board. Turn the focus controls to their limits: if one part of the screen stays out of focus, replace the CRT |
| Predominant colour tint | Check the video card. Do the video adjustments. Replace the main board. Replace the CRT if a red, green or blue tint cannot be removed |
| Out of convergence | Check the video with a known-good monitor. Do the convergence adjustments. Replace the main board. Replace the CRT |
The adjustments are on the general maintenance page.
Sound
[edit | edit source]Apple's audio chart deals only with settings; it lists no hardware cure.[1]
| Symptom | Check |
| Sound from only one speaker | A sound output option may be set to stereo on a computer with mono output only |
| Built-in microphone does not record | Press the microphone button on the keypad (the microphone LED lights when it is on). Make sure the display is selected as the sound input and playback source |
| No sound or volume too low | Check external sound sources are connected to the display's sound-out port. Press the volume key. Turn mute off. Turn the microphone off |
If the settings are right and a speaker is still silent, the speakers (922-0387), the audio enclosure with its sound board (922-0386) and the microphone (922-0389) are separate service parts.[3]
Miscellaneous
| Picture jitters or flashes | Move the display away from other monitors, fluorescent lights and electrical equipment. Check the ground cables. Replace the main board |
| Shuts down intermittently; flashing or wavy screen; high-pitched noise; does not degauss | Replace the main board |
| Black spots (burnt phosphor) | Replace the CRT |
| ADB devices do not work or work erratically | Replace the keyboard cable, keyboard, mouse or other ADB device |
| A Logitech mouse moves nothing but the keyboard works | Some Logitech mice are incompatible with this display; the display is not at fault |
| Thin horizontal line about a third of the way up | Not a fault: the support wire of the Trinitron aperture grille on displays smaller than 15 in. It cannot be adjusted out or removed by replacing modules |
Fuse
[edit | edit source]The mains fuse is on the main board: Apple part 922-0502, 4.0 A, 250 V. Remove the rear cover, discharge the CRT and remove the anode cap, then lever the fuse out with a small screwdriver.[3][4] Apple's specification says it should be replaced with the same type by a qualified technician.[5]
Removing the main board
[edit | edit source]The main board comes out after the audio enclosure and the video cable. Apple's order:[2]
- Remove the rear cover, discharge the CRT and remove the anode cap.
- Cut the tie wrap on the yoke and ground cables, disconnect the two ground cables from the degauss panels and the four-wire CRT cable from BD1, and pull the video board assembly straight off the CRT neck: twisting or bending it can crack the neck.
- Disconnect the degauss cable from BP2. Remove the four self-threading T-15 screws holding the base assembly to the bezel and lift the CRT assembly off the base onto a pad, minding the LED and microphone cables.
- Release the cables from the B5 audio board (microphone at B5, front panel at B3, video at B4 and B10, four-wire cable at B8) and the audio ground cables from HP5 and HP6 on the main board. Loosen and pull out the two screws holding the base to the audio enclosure and slide the enclosure out.
- Remove the screw holding the video cable to the EMI shield, unplug the cable from BV1 and lift out the strain relief plate.
- Remove the two main board mounting screws, unplug BP3 and BP4 (on/off switch), BP5 and BV4 (audio), release the rear and then the front latches, and slide the board back off its mounting tabs.
After a new main board is fitted, Apple calls for the video (cutoff) adjustment.[2]
[edit | edit source]- Apple AudioVision 14 Display
- Apple AudioVision 14 Display General Maintenance
- Apple AudioVision 14 Display Service Source
- CRT Discharge Procedure
[edit | edit source]- ↑ 1.0 1.1 1.2 1.3 1.4 1.5 Apple Computer, Apple AudioVision 14 Display (Service Source), hosted as File:Audiovision 14 display.pdf. Troubleshooting: general p. 1, symptom charts pp. 2-13 (PDF pp. 14-26).
- ↑ 2.0 2.1 2.2 Apple AudioVision 14 Display Service Source, Take Apart, pp. 1-53 (PDF pp. 28-80).
- ↑ 3.0 3.1 Apple AudioVision 14 Display Service Source, Exploded View (PDF p. 121).
- ↑ Apple AudioVision 14 Display Service Source, Take Apart, Fuse, pp. 52-53 (PDF pp. 79-80).
- ↑ Apple AudioVision 14 Display Service Source, Specifications, Electrical, p. 5 (PDF p. 10).
