Acorn J233
Acorn J233 StrongARM Risc PC
Acorn's brochure photograph of the J233
ManufacturerAcorn Computers
TypeDesktop computer
ReleasedSeptember 1997[1]
CPUStrongARM at 233 MHz
Memory32 MB DRAM (one further SIMM socket); 2 MB VRAM
Storage1.7 GB IDE hard disc; 1.6 MB 3.5-inch floppy; x24 ATAPI CD-ROM
DisplayVIDC20, up to 1280 × 1024 at 256 colours
Sound16-bit stereo
ROM4 MB, RISC OS 3.7
PowerIntegral 103 W switched-mode supply, switchable 110 to 240 V AC
Dimensions355 × 383 × 117 mm (one slice)
WeightAbout 3.75 kg
OS / Firmware—
Model no.SRP41
The Acorn J233 StrongARM Risc PC is a version of Acorn's 233 MHz StrongARM Risc PC sold from September 1997 with Acorn's web browser and a Java virtual machine installed on the hard disc. Chris Whytehead records that the bundled software was the only difference from the standard 233 MHz StrongARM Risc PC launched at the same time, and that the software was also sold separately on the Browse and Riscafe update CDs. Its sales code was SRP41, "J233 Java Risc PC".[1][2]
Specification
J233 technical overview (Acorn leaflet AGP24.79.50)
Area Detail
Processor StrongARM at 233 MHz; OpenBus slot for a 486/5x86 PC card
Chip set IOMD I/O and memory controller; VIDC20 video controller
Memory 32 MB DRAM, one further SIMM socket; 2 MB VRAM; 240 bytes of battery-backed CMOS RAM; 48-bit unique identifier
ROM 4 MB page-mode ROM with RISC OS 3.7
Expansion Two 32-bit EASI slots per slice, up to eight in total; dedicated network card slot
Drives 1.7 GB IDE hard disc; 1.6 MB 3.5-inch floppy; x24 ATAPI CD-ROM
Ports 9-pin RS232; 25-pin parallel; 15-way high-density monitor; internal genlock port; 3.5 mm stereo output for 32 ohm headphones or line level
Software Java 1.0.2 virtual machine; HTML 3.2 browser; mail and news clients; Omniclient II network access
Input 102-key PS/2 keyboard; three-button PS/2 mouse
Power Integral 103 W switched-mode supply with IEC inlet and outlet, switchable 110 to 240 V, 50 or 60 Hz
Source: Acorn's leaflet.[2] Chris Whytehead gives RISC OS 3.71 for the September 1997 machines; the leaflet says RISC OS 3.7.[1][2]
Wikipedia's Risc PC timeline also places the J233, with a 233 MHz StrongARM and the browser and Java software, in 1997.[3]
Hardware and repair
The J233 is built on the same Risc PC architecture as the Acorn Risc PC 600 and Acorn Risc PC 700: the IOMD and VIDC20 chips, EASI podule slots in stacking slices, a separate network slot and a 103 W supply.[2] The StrongARM processor is on a plug-in CPU card. Chris Whytehead's own 233 MHz StrongARM Risc PC (an SRP26, not a J233) has main board 1208,000 issue 3, the board used in the Risc PC 700, with RISC OS 3.70 ROMs, a Sony CD-ROM and floppy drive and a 103 W supply.[4] The Risc PC 700 guides cover the shared hardware:
Acorn's Risc PC Technical Reference Manual describes the IOMD/VIDC20 system, the backplanes, the power supply and the power-on self test; it predates the StrongARM card.[5] Like other Risc PCs, the StrongARM machines are held back by the 16 MHz system bus when the processor works from main memory.[3]
  1. ↑ 1.0 1.1 1.2 Whytehead, Chris. "Acorn J233 StrongARM Risc PC", Chris's Acorns, The Centre for Computing History (retrieved 2026-10-02). Launched September 1997 alongside the upgraded StrongARM Risc PC (233 MHz StrongARM, RISC OS 3.71, more memory, larger disc, CD-ROM); the only difference was the bundled !Browse and Java on the hard disc; model SRP41 "J233 Java Risc PC".
  2. ↑ 2.0 2.1 2.2 2.3 2.4 Acorn Computers, Acorn J233 StrongARM Risc PC, leaflet AGP24.79.50, 1997. Hosted on this wiki: File:Acorn J233 StrongARM Risc PC brochure (AGP24.79.50).pdf. Feature list p. 1; Java and web browser p. 2; technical overview p. 4 (processor, OpenBus PC card slot, IOMD and VIDC20, memory, ROM, CMOS RAM, unique identifier, expansion slots, network slot, drives, ports, screen modes, software, dimensions, weight, 103 W supply, approvals).
  3. ↑ 3.0 3.1 "Risc PC", Wikipedia (retrieved 2026-10-02), timeline: 1996 200 MHz StrongARM upgrade; 1997 "Acorn launch Acorn J233 StrongARM Risc PC, featuring an uprated 233 MHz model of StrongARM and including Browser and Java software"; the 16 MHz system bus as the design's main limit with StrongARM.
  4. ↑ Whytehead, Chris. "Acorn StrongARM Risc PC", Chris's Acorns (retrieved 2026-10-02). StrongARM Risc PC model list (SRP05 to SRP26); his SRP26 233 MHz machine: Acorn 233 MHz StrongARM CPU card, issue 3 main board 1208,000 with 16-bit sound, IOMD21, VIDC20, SMC FDC37C665GT, RISC OS 3.70 ROMs, Sony CDU311 CD-ROM, Sony MPF920-H floppy drive with its front flap spring broken, Seagate ST31276 hard disc, 103 W supply; some CPU cards were 160 MHz parts overclocked to 202 MHz.
  5. ↑ 5.0 5.1 Acorn Computers, Risc PC Technical Reference Manual, part no. 0497,057, issue 1, September 1994, hosted on this wiki.
